Question about Dryers
Affinity Dryer Glacier Blue Model LEQ 7000 EGO New Tumbler doesnt work!!
Set up, heats up, doesnt tumble?!!!!!
Illeagle
  • 525 Answers
SOURCE: how do you replace the
The fuses or breaker is located in your homes fusebox. An electric dryer requires 240 volts and 2-30amp fuses, or 1-30amp breaker. Locate your fusebox and determine if you have fuses or breakers. If fuses, then I recommend changing both 30 amp fuses to eliminate any possibility of being wrong. If it uses a breaker,(If not labled, look for the number 30 on a breaker). Flip the breaker to the OFF position, then back to the ON position. Repeat this action if there are more than 1-30 amp breakers and your dryer still doesn't heat.
Posted on May 26, 2008
captaynkyrk
  • 170 Answers
SOURCE: Dryer doesn't tumble
If you need to replace the belt here's how: remove the front panel. you may need to remove a kick panel below the front panel. the top panel connects to the front panel by some plastic push in retainers (you can loosen them with a screwdriver) You need to prop the top panel up. the belt goes over the top of the drum down to a drive wheel that is located at the bottom of the dryer.
Posted on Jul 07, 2008
TheMobilian
  • 8220 Answers
SOURCE: tumbler
You may have had a wheel lock up on the dryer. This could cause the belt to break. Is the drum hard to turn? Is this a gas dryer? use this PAGE as a guide to help you get into the dryer and a lot more
Posted on Mar 02, 2009
dragonsthatk
  • 547 Answers
SOURCE: Frigidaire affinity dryer doesn't have heat but it tumbles, stops
clean air duct
Posted on Mar 13, 2009
dniro592006
  • 121 Answers
SOURCE: The dryer doesn't tumble
first see if your belt has broken on drum and then see if motor is working
Posted on Jun 12, 2009
Maytag neptune dryer heats but wont tumble
When you spin it by hand, is there resistance? Can you hear the motor turning? In fact, when you switch it on and it starts to heat, can you hear the motor turning, or is it silent?
Sounds like the belt is broken, in which case there will be little resistance.
If there is resistance, it may be the motor or circuitry controlling the motor.
Aug 24, 2015 | Maytag Dryers
Dryer shuts off after 5 seconds then beeps 3 times
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle.
Apr 03, 2015 | Frigidaire FARE1011MW Affinity High...
Dryer that wont stop tumbling
Well we know the door switch is functioning properly so that usually just leave a timer issue.
Dec 05, 2014 | Dryers
My Frigidaire Affinity dryer won't tumble; it just hums
Thats not even a question Stupit!!!! A good hummer is good for you ********!!!!
Aug 04, 2012 | Frigidaire GLEQ2152ES Electric Dryer
My dryer is 4 years and the heater wont heat up but the tumbler tumbles
First check your dryer vent, make sure that it is venting properly. If that doesn't work then it is your dryer heating elements.
Apr 27, 2011 | Frigidaire Dryers
My dryer no longer heats
Small Diagnostics: is the gas line open, does the dryer still operate (tumble) but it does not heat, does the exhaust blow air out if so then the gas delivery, motor, vacuum motor are possibly working properly.
website http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170716&diagram_id=28476104#d28476104
Issues might then be in the ducting or the heating unit, this is the schematic of the gas line, heating, and ducting within the core of the dryer: If you take a close look at number 16 which can be seen inside the tumbler, Sometimes the port/ matrix of small air vent can clog up due to lint. Make sure that vent is not blocked. This prevent hot air from coming into tumbler.
When a unit over heats or fails it could be related to the high limit thermostat which is a sensor that get tripped or blows when it reached its limit check and see if its fried/ burnt (number 17).
Diagram number 2: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170716&diagram_id=28476105#d28476105
This one contains or blown out thermostat fuses check and see if they are OK on diagram 2, Part number 8 Tstat and 10 thermal fuse.
Hopefully this help.
Jan 10, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer will not stop running
Your machine may have a feature called wrinkle guard or wrinkle shield, which basically keeps tumbling the clothes without heat to prevent wrinkles from setting in. Turn that feature off and see if that does the trick.
May 15, 2010 | Frigidaire Electric Dryer
Gas dryer's start button doesn't stay engaged
bad start switch on motor, rare. that model # came up as maytag range not a dryer.
Jul 19, 2008 | Dryers
Dryers Logo
83 people viewed this question
Top Dryers Experts
