Question about Danby Heating & Cooling
I purchased a danby Airconditioner Model DAC 14004D, I inadvertently pluged it into a 220 volt outlet for a few seconds and now when I press power nothing comes on. Do you think it is reparable
  • 455 Answers
Hello Mocan Sorry to hear that happend! There should be a FUSE inside the unit ,but it is single use fuse and needs a new fuse.Worth repairing.
Posted on Jul 08, 2010
  • mocon Jul 08, 2010
    I checked the fuse and it is good could it be something else
Is the Hunter portable AC High Effiency Model 31125 to be plugged into a 220 outlet only?
if the plate on the side says 220 volts then it will only work on 220 -250 volts outlet
at a 110 volts outlet it will fail and at anything more than 250 volts it will burn up
Apr 20, 2016 | Hunter Heating & Cooling
Tip
How to convert 220 volts to 110 volts for the iPod Touch
<p> <p>The battery of an iPod Touch prepared for use in the United States is designed to be reloaded from the current supplied by a 110-volt electrical system. Power is transmitted to the battery charger with an iPod battery, which are connected via a USB cable and then connected to a 110 volt outlet. To use the power of a 220 volt outlet with an iPod Touch, set the current 220 volts to 110 volts. A conversion adapter voltage, also known as "Step Down Transformer," it is necessary and can be obtained from an electronics store, a hardware store and even some drug stores. <br /> <p><br /> <p>1. Place the 220-110 voltage converter card (aka, "Step Down Transformer") next to a 220 volt outlet. Plug the adapter into the outlet. <br /> <p><br /> <p>2. Connect the end of a USB cable to the USB connector USB iPod charger iPod. Connect the other end of USB cable into your iPod's own socket on the bottom of the iPod Touch. <br /> <p><br /> <p>3. Plug the iPod into the 110 volt outlet in the battery adapter for the iPod Touch. <br /> <p><br /> <p>4. Unplug the charger from the iPod adapter and the adapter from the outlet when the battery is charged. Unplug the USB cable from the iPod charger and iPod Touch. <br />
on Aug 09, 2011 | Apple iPod touch
I have brought my wok over from the UK but i have lost the electric lead firstly where can i buy one from and secondly will it be compatable with my appliance
Firstly is the WOK 220 Volt or 110 volt which is north American because if not 110 it will not work without serious house rewiring to provide you with a 220 volt outlet and then if you find a cord it will need to have the correct end for the 220 outlet you have wired in or you will have to have a compatible outlet to your cord.
Sep 21, 2014 | Rival Kitchen Appliances - Others
LG airconditioner with reset botton on power cord 220. After a lightning storm. Airconditioner wont come on.There is power to the outlet but no power in the cord past the reset unit. should I replace that...
Yes replace reset cord. also see an electrician about a surge suppressor for your home this one item will save you alot of money and appliances
Aug 24, 2012 | Heating & Cooling
We have just moved a freezer and pluged it in but it doesnt turn on. it is pluged into an outlet with power i tested that
The Danby freezer(DUF808WE) doesn't work from yesterday, even proper plugged in?
I already check electrical outlet. How can I fix it?
Jul 08, 2011 | Danby Freezers
Inadvertently plugged in device to a 220 outlet verus a 110.
Hi...
I'm not sure about this model but most have a "universal switcher" power supply inside that works up to 220 volts.
Also ( with NO power connected ) take the cover off and check for a glass fuse ( 20mm long) . See if that has blown . Radio Shack has plenty of fuses
Apr 17, 2010 | Toshiba SD-2800 DVD Player
I have a brother printer and I pluged in to 220
Connecting it on a wrong power outlet like what happen will cause a major problem on your device , since your device is made for 110 and you connect it to a 220 this can still be fix and it needs a part replacement so better take it to a service center to have it check and have the burned part replace....
Aug 10, 2009 | Office Equipment & Supplies
Wii got pluged to a 220 volt outlet
I'm going to go ahead and say it probably fried the Wii. I would maybe try getting a new adapter either way if it's at reasonable cost and see if it works again though.
Jul 19, 2009 | Nintendo Wii Console
Compag presario will not start
Try the following possible solutions:
1. Unplug the power from your computer for 15 minutes.
2. If your computer is plugged in via a surge protector, plug your computer into the power outlet directly, maybe you are dealing with a faulty surge protector.
3. Near the plug where the power plugs into the back of your computer, there is a little switch where you can choose between 120 volts (USA) and 220 Volts (Europe) as input. Make your this did not inadvertently get changed to 220 Volts.
If neither one of these solves your problem, please let me know so I can assist you further. Also, how old is this computer?
Thanks for using the fixya forums!
Mar 30, 2009 | Compaq Computers & Internet
Maytag neptune dryer MD6
All you need to do is check the element for continuity with an ohm meter, if it has continuity the element is good. The dryer also will run on 110 volts of power but it needs 220 volts too run the element, so check and make sure all the conections on your cord are secure and that you have 220 at your wall outlet.
Jun 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Heating & Cooling Logo
121 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
