Question about Car APS997A Two-Way Remote Start and Security System
I presently have two controllers for my door locks on my 1997 Ford F150 pickup truck that was installed at Best Buy several years ago. One of them will not lock the truck, but will unlock the truck, the other one is working just fine right now. the model number for the remote is AX018T3CL, the 8 might be a B, but it is so small I cannot read it to clear. the FCC ID: BGAOE38. I need to know if I can replace on of them and how much would it be. Rick L. Carmichael
4 Suggested Answers
  • 27 Answers
SOURCE: REMOTE STARTER NOT WORKING COMPLETELY
Here is page 2 of the owners manual, Hope it helps.
This will not start the vehicle if any one of the following situations exists;
The vehicle's hood lid is opened.
The gear shift selector is not in Park.
The brake pedal is depressed.
The safety control switch is in the Off position.
1. To start the vehicle, press and release the transmitter button two times within 2
seconds. The vehicle will start and remain running for the pre-programmed 5,10,15,20 minute run cycle. As a visual indication, the parking lights will flash or remain on depending on the setting by your installation center.
2. When you arrive at the vehicle, turn the ignition key to the ON position (not the spring loaded start position), then step on the brake pedal to disengage the remote starter. The
vehicle will continue to run, but now on it's own power.
NOTE: The engine will stop running before the pre-programmed run cycle has expired if you perform any one of the following functions;
-Press and the button on the keychain transmitter two times within 2 seconds.
-Depress the brake pedal.
-Open the vehicle's hood
-Place the unit in the safety control disabled mode.
PRLED SAFETY CONTROL SWITCH
The Push-Button LED control switch allows you to temporarily disable the remote starting function of the system. This recommended whenever the vehicle is being serviced. To place the system in the service mode:
1) With the system disarmed/unlocked, and the ignition switch off Press and Hold the PRLED on.
2) Turn the ignition switch on, off, on, off, on, off.
3) The LED begins to flash two short flashes followed by one long flashes and continues this pattern until returned to normal mode of operation. This puts the unit into the R/S Override mode indicating that the remote start is in the service mode and will not start from RF or any other input Posse or otherwise.
To Exit R/S Override Mode
1) With the system disarmed, Press and Hold the PRLED on.
3) The LED turns off indicating that the R/S unit is fully functional one again
Posted on Dec 18, 2008
SOURCE: I have the ffc id:
http://www.fixya.com/support/t4105172-audiovox_pursuit_pro_keyfob_reprogram
Try this link
Posted on Dec 13, 2010
  • 5370 Answers
SOURCE: I need a new remote
Yes you can get this remote from the link mentioned below:--- Click this link directly:--- http://www.autotechs.com/items/item1042.htm ------------ Also click this link directly,This is near to identical remote to your remote:--- http://www.autotechs.com/items/item1154.htm ---------- Check out both the links and order your required remote.This will help.Thanks.Helpmech.
Posted on Dec 23, 2010
Diagram
all locations should be located in service manual located in glove box
Jul 21, 2014 | 1997 Ford F150 Regular Cab
I bought a used 1999 Ford F-150 Super Cab pickup a several years ago. The dealer didn't have the '99 owners manuel so they gave me the 2000 yr's manual. Well, I have been pulling a popup camper for years...
All I can tell you, is I would not own any vehicle with a 3.08 Gear
You need at least a 3.90 just to have a nice driver or even consider towing
Oct 13, 2010 | 1990 Ford F150
Firing order for 4.6 97 f150
Several VIN engine there...
1997 Ford F 150 Pickup 4.6 liter CNG SOHC V-8 VIN "9"
and
1997 Ford F 150 Pickup 4.6 liter V-8 VIN "6"
and
1997 Ford F 150 2WD Pickup 4.6 liter SOHC V-8 VIN "W"
Hope this help to solve it. (remember comment and rated this).
May 10, 2010 | 1997 Ford F150 Regular Cab
Serpentine belt configuration
For the 1991 Ford F150:
Click
on the following Free direct Link.
It has several Diagrams including the correct Belt Diagrams for you 1991 Ford F150 with your unspecified Engine Size and various Engine Options.
http://www.2carpros.com/car_repair_information/year/1991/make/ford/model/pickup/1991_ford_pickup_drive_belt_routing_diagram.htm
Apr 13, 2010 | 1991 Ford F150
I need the firing order for a f150 1997 ford pickup 5.4
1997 Ford F 150 4WD Pickup 4.6 liter CNG SOHC V-8 VIN "9"
1997 Ford F 150 4WD Pickup 4.2 liter V-6 VIN "2"
1997 Ford F 150 4WD Pickup 5.4 liter SOHC V-8 VIN "L"
Hope this help (remember rated and comment this).
Mar 21, 2010 | 1997 Ford F150 Regular Cab
How do I find how many gallons my fuel tank is on my 1997 f-150
1997-1998 Ford F150 Pickup Gas Tank -4x2 Regular Cab 6-1/2 Box 179.9
1997-1998 Ford F150 Pickup Gas Tank -4x4 Regular Cab 6-1/2 Box 219.95
1997-1998 Ford F150 Pickup Gas Tank - Super Cab 6-1/2 Box 179.95
24.5 gallons
Hope helps (remember rated this). Good luck
Feb 12, 2010 | 1997 Ford F150 Regular Cab
1997 F150 Pickup door wont open
I believe there is a cable which connects the handle to the latch, they are pron to breaking.
Jun 21, 2009 | 1997 Ford F150 Regular Cab
3rd door on ford f150 will not open
There was something in the paper, maybe a recall on the latch for the 3rd door. There is a clip inside the door that keeps the lockrod in place. You might want to call the dealer about it. I am not sure you can remove the inside panel without having the door open.
May 31, 2009 | 1997 Ford F150 Regular Cab
1997 F150 4.6l cruise control does not work.where do i start?
Does Ford replaced the cruise control deactivation switch.
Vehicles involved in the recall include the following:
1998-2002 Ford Ranger
1992-1997 Lincoln Town Car
1992-1997 Ford Crown Victoria
1992-1997 Mercury Grand Marquis
1993-1998 Lincoln Mark VIII
1993-1995 Taurus SHO
1999-2001 Ford Explorer
1999-2001 Mercury Mountaineer
2001-2002 Ford Explorer Sport
2001-2002 Ford Explorer Sport Trac
1992-1993 E150-350 Vans
1997-2002 E150-350 vans
1993-1997 Ford F-Series pickups
1993 Ford Bronco
1994 Mercury Capri
2003-2004 Ford F0150 Lightning
1995-2002 Ford F53 motor homes.
May 15, 2009 | 1997 Ford Expedition
Ford F150 Pickup 2005 power doors unlock but will not lock
I had almost the identical problem on my 2005 F150 FX4 Extended cab last weekend. The power door locks would not lock using the keypad, remotes, or door buttons. Almost all other functions worked correctly. The doors unlocked, the radio delay functioned, and the interior lights dimmed. When I used the remote the horn would beep twice indicating that a door was open even there was no message on the message center that a door was open. When I used the keypad or remote, I could hear a soft click from behind the seat. I think it was coming from the body security module or body security module - whatever Ford is calling it this year. I pulled the fuse for the Power Door Locks(BSM). As I removed it, I heard a soft click - sort of like a relay resetting. It may have come from the VSM/BSM. It may have possibly been a stuck actuator releasing. I don't think so. It wasn't that load. In any case, everything is functioning correctly now.
Tracy
Oct 29, 2008 | 2005 Ford F-150
Car APS997A Two-Way Remote Start and Security System Logo
Top Audiovox Vehicle Parts & Accessories Experts
xxxxxx xxx
Glen Weitzdoerfer
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
