Question about AMD eMachines Desktop System w/ 17'' CRT Display, 2.0 GHz Athlon 64 3000+ (W3400)
Emachine W3400/ front panel connections
I am trying to hook up the front panel connectors to the mother board there are three wires to hook up. the power switch, power L.E.D. and h/d L.E.D.
the problem is there are eight identical sockets on the motherboard(RS480M).
  • original4u8 Jan 18, 2009
    anyone kno of a manual telling where to place the cables. or could some one go into better details?
They have to be plugged in horizontally although it is possible to plug them in vertically because the pins are evenly spaced either way. they are color coded just not like you would expect for example one plug has a green wire and a white wire the green side goes to the green pin and the white side goes to a green pin with a white cross you have to look close because there are several green pins which is what threw me off do this with all three plugs
Posted on Apr 19, 2008
How to hook up the face plate of a emachine w3400 Wich includes 3 wires 1 power butten and 2 led lights
Look at the pinout of the Front Panel header, of the eMachine W3400's motherboard.
The plastic front of the computer is the Front Panel.
The area of pins on the motherboard, that the cables (Wires) from the Front Panel connect to,
is the Front Panel header.
The motherboard for an eMachines W3400 desktop computer is an MSI ms-7145
(Micro Star International)
Orient the motherboard in your view so that we are both looking at it the same way.
Processor to the Top, Ram Memory slots to the Right, white PCI slots (3) to the Bottom.
JFP1 is the Front Panel header.
(Junction Front Panel 1)
JFP1 is on the Bottom Right corner. There are two columns of pins arranged vertically.
(The JFP1 header runs parallel to the Right side of the motherboard)
The Left side column of the JFP1 header is numbered Odd.
Starting at the Top and going Down, the pins are numbered;
1, 3, 5, 7, and 9
The Right side column is numbered Even.
Starting at the Top and going Down, the pins are numbered:
2, 4, 6, and 8.
There is NO Pin 10
A) Pins 1 and 3 are for the HarDDrive Activity LED light. (HDD)
If the LED light is dim will operating switch the wires around
B) Pins 5 and 7 are for the Reset switch. (Reset button)
> IF Used
C) Pin 9 is Not used. (NC. No Connection)
D) Pins 2 and 4 are for the Power On LED light (If dim switch the wires around)
E) Pins 6 and 8 are for the Power On switch. (Power On button)
Trace the wires back to the Power On switch. Even if it means temporarily removing part of the Front Panel to see.
Same with the LED lights.
See which wires go to the Power On LED, and HDD Activity LED. (Harddrive Activity LED)
Follow the 3 wires, and tell me where they go to on the Front Panel.
USB port?
Memory Card Reader?
Firewire port? (a1394)
Nov 27, 2010 | AMD eMachines Desktop System w/ 17'' CRT...
Need picture of mother board for Emachine C2825
I've built a PC myself, each connector had text on it to say what it was and one arrow on it in relief, don't know wether that indicated plus or minus anymore.
Anyway, I recommend you just plug them in, and try to boot the PC. If it doesn't boot, switch the Power SW connector around, then it should boot. Do the same with the LED connectors, and it should work just fine!
Good luck,
Yannick.
Jul 13, 2009 | Intel D845GVSR Motherboard
I have emachine w3400 not powering . plz help
I found this right on this website, hope it works!
As for the fans, make sure your connections are tight and in the proper sockets.
Jul 09, 2009 | AMD eMachines Desktop System w/ 17'' CRT...
Computer will not start
first you connect your harddisk data cable to mother board
connect your hard disk powercode using smps
connect smps 24pine connector threw mother board
connect 12v connector threw mother board
connect cpu&external fan connections
also connect the front panel connections on mother board using mother board details
Jun 17, 2009 | ASUS A7N8X Motherboard
T6410 EMACHINE TRYING TO CONNECT START BUTTON
The motherboard in your computer is an MSI MS-7145, which is also called RS480M. You can download a copy of the manual here. The front panel connections are on page 2-20.
Looking at the header JFP1, pins 1 through 9 (odd numbers) are the front row, pins 2 through 10 are the back. Pin 10 is the missing pin. The power switch connects to pins 6 and 8. The power LED connects to pins 2 and 4. The HDD LED connects to pins 1 and 3. The reset button, if used, connects to pins 5 and 7.
May 13, 2009 | E-Machines eMachines Desktop PC
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
Where to hookup front panel (PIII-3754LMR - AMPTRON)
Front Panel Connector The front panel header is where the connectors of hard disk drive activity lights, case speaker, reset button, power on/off button, computer power on light, and key lock, are connected to make them function smoothly. In the past days, users always have difficulty connecting the front panel due to a lack of standard location on the motherboard. Today, AOpen integrated all these disorder but essential front panel connectors into one 20-pin connector for easy usage. Connecting the front panel would no longer be the headache of installing motherboard anymore. Below is a view of this user-friendly front panel connector of AOpen motherboard.
please rate this post.
or donate on madridtelecom@gmail.com
Feb 08, 2009 | Intel Motherboard
Emachines computer not turning on
IS ALL CONNECTION CORRECT, TYPE IN
EMACHINE COMPUTER DOWNLOAD DRIVES
ENTER
SEE IF ANY OF THIS INFO CAN HELP YOU
THE MAIN SWITCH FROM THE PANEL ON THE FRONT OF YOUR COMPUTER DIDNT MATCH YOUR NEW MOTHERBOARD CONFIGURATION
START BY REMOVING ALL WIRES AND CONNECTORS EXCEPT POWER ONE, SEE IF SYSTEMS TURNS ON, THE POWER SWITCH MAYBE THE PROBLEM, RESET SWITCH, ANY EXTRA CARD YOU PLUG INTO YOU MOTHER BOARD
*********REMOVE ANYADD ON CARD ANY ADAPTER DEVICE ALSO,
ADD ONE WIRE AT A TIME UNTIL ALL WIRES ARE CONNECTED
CANDYMANCANDY
Jan 27, 2009 | E-Machines (308714) Motherboard
Trying to hook the motherboard back in
it varys on each machine , but on the mother board their is a group of pins stickin out one or 2 have jumpers leave them alone! go to the pins left bare their is minenute abreviations next to the pins they will giv you an idea of what 2 do ,also look for colour coding.
Jan 17, 2008 | AMD eMachines Desktop System w/ 17'' CRT...
Emachines problem... PSU works but comp doesnt turn on
Hi, Did you just add the second CD? If you did you may need the driver for the mother board? Make sure the power cord for the cd has voltage plug it into the DVD drive also check the cable make sure red stripe is on the correct side of drive. You can download the driver at http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T-Series&model=T2672 User guide is there as well. The start button has a pair of wires with a small pin connector on it. This will connect to the motherboard if there is a 3 pin set you might try moving to the other pin. The new power supply also has to provide a start voltage? Your power supply may not be compatible or it may put the voltage on the third pin.
Aug 22, 2007 | E-Machines eMachines Desktop PC
AMD eMachines Desktop System w/ 17'' CRT Display, 2.0 GHz Athlon 64 3000+ (W3400) Logo
1,193 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
