Question about Amcor PLM-14000E Portable Air Conditioner
Air condition leakes water
My amcor portbale windowless air condition works usually for a few minutes, and then i need to drain the water. but draining is a pain in the neck too. if i am moving the air conditioner to where i want to drain it into it leaks water.
i was thinking about connecting a hose for continuous draining
Your thoughts?
Thanks
  • 478 Answers
You can get a small condensate pump, and run the hose to a drain like a sink or toilet, you may have to trick the switch if you have to put the pump inside, where the bucket would fit.
Posted on Jul 08, 2010
I have a portable roam air condition i dont know where to add the water
You don't account unit takes out humanity in th he air to cool house or rooms you need to drain the water to outside
Apr 12, 2014 | Amcor PLM-14000E Portable Air Conditioner
The condensation tank is filling and causing the unit to shut down every two hours. The internal pump that sprays water (from the collection tank to the exhaust vent) is apparently not working. Will this...
Shut it down until you get the drain working again. That spray is what helps save you a few buck on your Cooling bill. Let that excess water get in your house then maybe kiss your pocket book goodbye
Sep 10, 2013 | Amcor PLM-14000E Portable Air Conditioner
NanoMax Portable Air Conditioner does not drain and unit's red light continues to come on with unit cutting off in a matter of minutes. Unit is less than 3 years old. Purchased from HSN or QVC, which...
There is a drain plug for the water on the rear lower back of your unit. You have to pull that plug out and it should drain the water out. The water is from condensation of the air you are conditioning. Probrably in the lower middle portion. Unscrew the cap and pull on the black plug. If it is plugged you need to take a small hanger and gingerly move it back and forth in the drain opening until the accumulated water drains.
Aug 02, 2011 | Amcor Heating & Cooling
My amcor is leaking water!
Please be a little more specific because Air Comditioners do in fact collect moisture from the air. This water collects in the drain pan and drained ouined off outside. If the leak is inside, the unit is not tilted to direct the water towards the drain hole.or the drin itself is plugged .Check and let me know if the problem still exists. :-) Ned
Jul 06, 2011 | Amcor Heating & Cooling
My amcor air conditioner is leaking water all over the floor. I drain it and it will only last less then 24 hours till it turns off, leaks all over an needs to be drained. Help!
I figured out the problem. My Amcor portable started leaking after the fill light came on for the first time in years. After doing some research I saw that it uses the water to cool some other part of the system to evaporate out the exhaust. So I took the ******* apart and messed with things. Finally I started pouring water into different trays and noticed it would not drain down from the top tray even when running. So I removed the top part and found the drain hole. Blasted that sum ***** with some compressed air and WAMMO it works again.
-madmanmarz
Jul 06, 2011 | Amcor PLM-14000E Portable Air Conditioner
Amcor AmcorAire UCHW-H12AF2 Split System Air Conditioner leaks water in side the room. after the drain hose was change and clamped.
I had the same problem. The insulation on the coper line was loose and the pipe was exposed. The water was condensation , not water from the drain.
Aug 25, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
No power to portable air condition
If the filters are clogh with dirt , the unit breaker will shut it off ,it's avery common problem , but if after the filters were cleaned it keeps shutting off , could be a bad fan motor or the compressor itself could be grounded.
Oct 25, 2009 | Amcor Heating & Cooling
Water leak
First you have to unplug or "off" the circuit breaker, then install the drain hose.
Oct 24, 2007 | Amcor AL10000E Air Conditioner
Amcor PLM-14000E Portable Air Conditioner Logo
550 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
