Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
A green rectangle light will periodically flash in the upper left corner of my LCD TV, what is it?
  • 1 more comment
  • Alex Avila Mar 14, 2012
    Well **** if it's aliens I better pack my bags then.
    Only non aliens and non believers respond please......
  • James Gettemy Mar 14, 2012
    My bags have been packed for years, just in case. JK. Seriously, I think the electronics do a scan every so often and the green box is a visual output showing everything is in order. The only thing that is abnormal with my TV (Olevia) , is that now it seems to overheat because it will shut down and if I try to start it up within seconds, it won't turn on. But if I wait for about 10 seconds, it will start up fine. I don't think it has anything to do with the green light because the green light always came on from when it was new. On the other hand, my aluminum cone hat is due for some service.
    Sergeant:
  • 198 Answers
My tv does the same thing with the small rectangle green light. It will flash for less than a second. I think it is when they are taking a photo of my living room, like when you can take a photo with your xbox kinetic when you jump. Might be aliens. Thanks for any help. getameapizza
Posted on Mar 12, 2012
  • macd_etc Nov 24, 2015
    My Samsung tv does it too but it has no camera so it can't be taking a photo. Sometimes the bar is green, sometimes blue, and sometimes purple.
4 Suggested Answers
SOURCE: Panasonic viera has flashing channel info in upper left corner
I had this exact same issue just yesterday. Channel info would flash intermittently. While set was in this mode, could not enter menu, change channels, etc. from remote or front panel controls. Similar to tjh492, I thought it might be an overheating issue. But unplugging the Viera and waiting for set to cool made no difference.
I then remembered that this issue popped up the instance I surfed to a particular channel (FWIW, 26-3 "Me Too" on Comcast here in Aurora, Illinois, USA). I had a hunch that there might be an issue with the signal on the channel that prevented the Viera from properly syncing, so I decided to unplug the antenna cable. Once I did that, the channel info displayed steady. I was then able to change channels (of course screen was blank as antenna cable was unplugged) and enter the Viera menu. I immediately went to channel set-up and manually removed channel 26-3 from the channel list. After reconnecting cable, Viera was back to normal. Since I'm not a big fan of "Me Too", problem solved :)
Not sure why a digital channel sync issue would effectively make the Viera remote and front panel controls inoperable. Pure speculation, but it could be that the Viera microprocessor was overloaded trying to sync to channel and this prevented any interrupts from remote or front panel controls.
Posted on Jun 24, 2009
SOURCE: Small black box in upper left corner of Sony TV - need to remove
I had a similar problem on my Toshiba Regza but trying my fix couldn't hurt. I use a satellite dish for TV (if you do the same this might work)... I turned off my receiver, took the programming card out, cleaned it with my shirt (especially the part that looks like a computer chip), put it back in the receiver, turned it back on and when everything reinitialized the black rectangle was gone.
Hope this helps.
Posted on Apr 13, 2010
dave1645
  • 834 Answers
SOURCE: Screen has black spot in corner that spreads to entire screen
one of the floresant bulbs has fail there is a place in Haverhill Ma called Tops Electronics that can fix you up really quick but you will have to ship it to them they do good work there
their new name is pinnacle solutions group over 30 year serviceing
Posted on Sep 18, 2009
Hope this helps.
Apr 11, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Small black rectangle in upper left corner of toshiba 52hm85 dlp
Sounds like it is closed captioning coming up. I would go in and verify both your TV's and the Cable/Satellites closed captioning is off.
Mar 06, 2010 | Televison & Video
Jvc 52 inch tv. the picture on the upper left corner drops and is discolored
Hi if your tv is a Dlp or Lcd it will be a problem with the light engine.Basically there's 3 chips green,blue,red that create the image and colors.When they start to go bad or melt you will get color discoloration on corners on the center.You will need to replace the optical block ,you can find it on www.discount-merchant.com www.shopjimmy.com or ebay .Have a blessed day!
Oct 01, 2009 | JVC Televison & Video
Upper left corner is green
Check the mirror in the TV..may have come loose.
Sep 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
An annoying "2" in the upper rigth corner of my TV.
I had the same problem. I manually rebooted the box and the 2 was gone. Hope this helps.
Dec 21, 2008 | Samsung LN32A550 32 in. LCD TV
Light green and pink spots on my hd tv!!!
Tiny particles of dust on the light engine lens can cause this (and was a service call for me about a month ago), or possibly the expensive light engine.
May 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Green dot in upper left-hand corner of screen.
you can try demagnetising your tv screen
Jan 13, 2008 | Emerson EWF2004 20" TV
Receving audio, but no video
This might help you
Proscan 19LA25Q 19" LCD HDTV at Crutchfield.com Proscan 19LA25Q 19' LCD HDTV: Detailed Info, Features and Specs, and Photos. ... Instruction Manual; Product Registration Card; Limited Warranty Card ...
www.crutchfield.com/ISEO-rgbtcspd/App/Product/Item/Main.aspx?i=68319LA25Q - 46k
Oct 06, 2007 | Proscan 19LA25Q 19 in. LCD Television
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
3,012 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
