Question about Sony KDS55A2000 55" HDTV
I just replace the lamp but the pic is not comming and its red light flashing three times.
  • 62 Answers
Reseat the lamp and door.
3 blink code means that one of the safty switches is open.
Posted on Jul 08, 2010
Mitsubishi WD-65733 Red light on Replaced lamp twice
I'd just replace my lamp just three days ago and the problem still
exsist
Nov 10, 2013 | Mitsubishi WD-65733 65" HDTV
I have a Sony KDF-60XS955 tv. It won't power on,
I have that manual. There are three lights to the left of the power button. One is labled LAMP. The manual states "The projection lamp, which illuminates the picture, has a limited life. If the screen becomes dark, the color looks unusual, or the LAMP indicator on the front of the LCD projector TV flashes, it is time to replace the lamp with a new one (not supplied). Use a Sony XL-2200 replacement lamp (not supplied) for replacement. Use of any other lamp may damage the LCD projection TV." I also found in a different page " LAMP LED lights up in red when the lamp for the light source has burnt out." I guess burnt out would be extream. I found one other if you had opened the light bulb cover and didn't close it properly. " If the lamp cover is not reattached securely, the self-diagnostic function may be triggered and the POWER/STANDBY indicator flashes three times." You can down the sony manual at http://www.docs.sony.com/release/KDF60XS955.pdf
Jun 02, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
I have a problem with our projector. The model is: PT-D3500E and the serial number is: SH5530059. When you switch on the projector the power light goes green after 25 seconds the power light goes...
If the LAMP INDICATOR flashing red then.
Problem: Lamp circuit failure
Sulution: your two lamps are ok you need to repair the lamp drive circuit this is repairable and if you don't want to repair you buy a new one lamp circuit and install it.
Jan 19, 2011 | Panasonic PT-D3500U Multimedia Projector
First the red bulb light was flashing and there was no picture. So i replaced the burnt bulb. Now when i go to turn the tv on were the red light means off and the green light mean on (that light blinks 3...
Check Lamp Fan if it stops running when Lamp trys to Light ,Then Lamp will not Power up,or Ballast Board itis what powers Lamp on.
Encompass Parts Distribution 1-800-638-3328
Oct 06, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
Sony kdsr50xrb standby light red 3 times
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
NOTE: You may have to replace the lamp also if the issue persists.
Check this Link for more information.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C461251
Good Luck!!!!!!!!!!!!!!!!!!
Sep 16, 2009 | Sony KDSR50XBR1 50" Projection HDTV
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Replaced the bulb, now the tv will turn off and flash red light
3 times red light flash shows that lamp cover is not seated / fixed properly.
Please check lamp cover and fix it securely.
Dec 11, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
No pic...humming noice on 62'' toshiba dlp
was the lamp blown if it was blown you could be hearing the ballast
if the lamp was not blown and the new one did not fix it the red light indicates the door there is a little switch when you put the door back on if you look at it it may need to be adjusted so it will connect with the door if that is not it you could have a fan that is not turn if it is making a real loud constant humming noise while it trying to fire the lamp you probably have a bad color wheel
Nov 19, 2008 | Toshiba 62HM95 62" HDTV
Sony KDF-E55A20 55 in. LCD... Problem red light flashes 5 times
A 5 blink error indicates a bad lamp driver. However a lamp may possibly cause this too. I suggest putting a new lamp in if you have one just to verify the lamp is not the problem. If it still fails with a new lamp then the lamp driver is the problem. This part should be replaced by a Sony authorized servicer. The lamp can be replaced easily by you. The lamp replacement instructions are in the TV's owners manual. Good Luck
Dec 04, 2007 | Sony KDF-E55A20 55 in. LCD Television
Lamp
red light indicates lamp is expired. even though you get temporary light, the lamp is shot. Try BULBMAN.COM for a new lamp.
Sep 25, 2007 | Toshiba TDP-S20U Multimedia Projector
Sony KDS55A2000 55" HDTV Logo
89 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
