Question about Roper RES7646KQ Electric Dryer
Hello, i have a roper electric dryer that just hums when i try to start it. i checked the belt etc and they were ok. i took the drum and belts etc out and put everything else back together and i still just get a hum. bad motor or switch? thank you bill
  • 259 Answers
Bill. You may very well have a bad motor, or possibly a blown thermal fuse. You will want to try to determine where the hum sound is coming from to figure out where your problem is.
If you have the drum and everything out and you try to start it and hear the hum coming from the motor, try turning the motor shaft by hand to see if it may have been bound up by something (like a pencil or sock falling down the lint chute).
If the hum is coming from the timer area only, then I would be checking the thermal fuses in the back of the dryer located on the blower outlet, and on the heater housing. The one on the blower outlet should be a skinny white one with two wires, the one on the heater is on the top of the heater element and also has two wires going to it.
You can check the thermal fuses easily by bypassing them and then checking to see if the dryer starts. DO NOT leave them bypassed as they are safety items to prevent the dryer from catching fire.
Good luck with this!!
Posted on Jul 08, 2010
Just fitted a new belt to my dryer now it wont turn have checked for any loose wires
Are you sure you have the belt on correctly? When you start it does the motor run or try to run? Does it hum or buzz when trying to start? Take the belt off & start it see if the motor runs if it does check if drum, belt and idler pully are installed correctly.
Check the drum rollers and drum glides be sure the drum turns ok. Be sure everything is installed correctly & turns OK . Are you getting power? Hard to tell what is wrong without much information about what is going on. You might check the front panel & see if it is binding on the drum not letting it turn. Hope there's something here that will help you.
Jun 02, 2014 | Frigidaire Electric Dryer
Dyer will not start hum when pushing start button
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Oct 04, 2010 | Roper REX4634KQ Electric Dryer
Roper dryer electris squeels loudly but runs and drys
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine.
Note: This method works with most front loading machines.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical consol with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Sep 09, 2010 | Roper REX4634KQ Electric Dryer
Roper dryer will not tumble when start button is pushed, just makes a loud humming sound and starts to tumble but stops after about 2 seconds.
Your problem sounds like maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please rate me,
Thank You
May 14, 2010 | Roper REX4634KQ Electric Dryer
How to replace a dryer belt on a roper dryer
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT. If you have to replace your drum belt and if you have a front loading machine. Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum. Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn. While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good luck, I hope this helps Please do not forget to rate me Thank you
Apr 08, 2010 | Roper REX4634KQ Electric Dryer
I want to know how to put the belt on my roper dryer model is RES7646KQ2
This method works on Whirlpool,Kenmore, but I am not l00% sure of Roper, you might give it a try.
Good luck,
I hope this helps
Thank you
Dec 03, 2009 | Roper RES7646KQ Electric Dryer
Doesn't start hear a hum
the humming sound is from the motor,check the blower wheel to make sure nothing is jammed in it,spin the drum with your hand and see if blower wheel and belt are spinning with the drum if they are you have a bad motor
Nov 08, 2009 | Roper REX4634KQ Electric Dryer
Dryer hums when turned on tub does not turn what could be wrong?
Sounds like your problem may be a broken belt, or the belt has slipped off of the motor pulley, or idler arm pulley.
If you have to replace your drum belt or check the other pulleys and if you have a front loading machine.
Good luck,
I hope this helps
Oct 31, 2009 | Roper REX4634KQ Electric Dryer
When we push the on button, you can hear a hum,
Sounds like the belt that turns the drum has broken. the hum sound is the motor turning. Does it still get hot in the drum? If so then you need a replacement belt ($15-$25).You can open the rear or the dryer to confirm the belt is broken. Be sure to unplug from the wall outlet to avoid electrical shock.
Aug 18, 2009 | Dryers
Roper RES7646KQ Electric Dryer Logo
111 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
