Question about Vacuums
Recently I purchased Sanyo Eneloop NC-MQN04ES Charger. I need the user manual for this charger. How many hours does it takes to charge 4 aa and aaa Batteries. I charged it for more than 6 hrs. But the led keeps on glowing. Pls help me. Want to know weather the led goes off or on once it has completed charging. Thank you.
This is from the user 's manual i just copy paste it
Specification: Voltage : AC 220V - AC 240V,
Input : 50/60 Hz 6W,
Output : DC 2.4V 220-280mA x2 (AA),
100-140mA x2 (AAA),
LED indicator : ON - charging OFF - Timer off (approx 16hours) Battrey/Charge Time Approximate Hours :
-Eneloop Ni-MH AA (typ 2000mAh) 10(h),
-Eneloop Ni-MH AAA (typ 800mAh) 8(h),
-Ni-MH AA (typ 2700mAh) 13(h),
-Ni-MH AA (typ 2500mAh) 12(h),
-Ni-MH AA (typ 2100mAh) 10(h),
-Ni-MH AA (typ 1700mAh) 8(h),
-Ni-MH AAA (typ 1000mAh) 10(h),
-Ni-MH AAA (typ 900mAh) 9(h),
-Dimension : 118 x 75 x 40 mm
Posted on Oct 12, 2010
When I press the trigger the green light comes on but motor does not
Hi Peter, it's Jack at Dyson.
From what you're describing, it does sound as if your DC35 needs to be recharged. When the machine is charging, the LED on the charger will illuminate, but the LED on the machine itself will not. When the LED on the charger goes out, the machine is fully charged - this will take 3.5 hours from depleted.
Please try connecting your DC35 to the charger cord and allowing it at least 3.5 hours to charge until the LED on the charger goes out, then test your machine. If it's still not running at this point, we will need to talk you through some simple diagnostic checks when you have your machine to hand. This will help determine whether there's an issue with the main body, battery or the charger itself.
You can reach our experts by calling the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Feb 09, 2015 | Dyson DC35 Digitial Slim Animal Cordless...
Will not charge the charging light is flashing
I'm not familure with your device but this is battery charging101. For a battery to charge the input voltage must be higher than the operating voltage of the battery. An example of this is your car. You have a 12 volt battery in your car and the alternator applies 13.4 volts or so to charge it. It is the same with any battery charger be it phone, laptop, chordless drill or small AA,AAA,C,D battery charger, that being said is the Dyson charger a seprat device? If so it can easily be tested at Batteries Plus, Any big box auto parts store, any high school electronics class. Check your owners manual it should give you the operating voltage, check that against what you discover about your charger. The charger only needs higher voltage output than the battery it doesn't have to bee a lot more. If you have further ? Email me at bret610@icloud.com good luck. Ps, you can by a reasonably accurate and easy use volt meter at W-mart for under $20. I am attacking video from u tube as to usage it's not difficult and well worth the money.
Sep 28, 2014 | Dyson Animal Bagless Cordless Hand Vacuum,...
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Jul 28, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
I have an Energizer Model CHDC7 battery charger for AA/AAA batteries. I'm not sure how to use it. Specifically, when batteries are inserted and plugged in, it displays flashing green lights over all...
Nickel-Metal Hydride (NiMH) batteries are usually charged in pairs in consumer chargers. The CHDC7 can charge two or four batteries at a time. Their position in the charger is important (see the link at the end of this note). Each battery has a separate pair of green LEDs. There are no other LEDs on this charger. The LEDs light up to show the state of charge. Flashing means it is charging. Solid means it has reached that level of charge (ie, 1 LED = half charged, 2 LEDs = fully charged). The batteries will get warm but not uncomfortably so. After some practice you will be able to tell if they are getting too hot (which may signal a worn-out battery which should then be replaced). Like all rechargeable batteries, NiMH batteries have a finite life (measured in number of times they've been discharged and recharged). IMHO, they should also be used and charged in matched pairs. I mark them when I take them out of the box and keep them paired in use and in charging for maximum life. Yes, the devices that use 3 batteries are a pain to deal with. LOL. All details can be found on this Energiser data sheet: http://data.energizer.com/PDFs/chdc7_instructions_english.pdf
P.S. The CHDC7 remains open for charging. Closing it for storage is optional but minimizes the space it takes up.
Jul 30, 2011 | Vacuums
Dirt devil doesn[t hold charge
Try running the battery all the way down by letting the vacume run in a corner or another room and even when it stops leave it on for a hour to drain the battery. Then shut the switch off and try charging the battery. Make sure the charger is putting out enough volts by looking at the rated output of the charger and while it is plugged in check it with a volt meter. If it does not hold a charge and the charger is putting out the right voltage you need to purchase a new battery for the vacume
Mar 18, 2011 | Dirt Devil Easy Lite Quick Vacuum
Old or New battery not charging...or so it seems (Discovery 4XXX)
the charger is not charging its not putting any thing out into the batterys the charger clock is working but your not getting any charge from it
Mar 21, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
Very short vacuum cycle time.
the charger sounds like its out take to service center.
Nov 29, 2009 | Roomba Pro Elite Bagless Robotic Vacuum
Roomba scheduler
Probably have a bad battery pack, your owner manual should tell you how to replace it.
Feb 11, 2008 | Vacuums
Vacuums Logo
1,195 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
