Drum rotation button does not light up thereforeeeee image position does not move
  • 2,272 Answers
Keep the machine ON.Remove all the cartridges and drum unit carefully out of the unit.Then turn the unit off.Then check inside is there any thing blocking the drum to move fluently.Many a times a piece of paper or any waste object gets in the unit and that sops the drum .Clean and clear everything if noticed.Then check the drum and cartridge itself properly for any dust object.Then turn the unit On.Then insert the cartridges as well as drum unit in the unit.Then check.If still the same problem Then this error is related to either the control panel of the unit or the drum unit itself needs to be replaced. If the control panel is faulty then it has to be checked for the internal wires and connections in the control panel.Any of the wire got loose or short.This has to be repaired. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jul 08, 2010
  • mariack Jul 08, 2010
    If any of the parts need to be replaced, where can I find parts for this machine? This is a printer copier.
The light before the print cartridges is lit up. What does that mean?
I'm not following your very brief non descript description.
But I'll try.
The Print Cartridge lights are at the top of the control panel.
The bottom button is the Rotate Carousel
Now below that is the IMAGING DRUM light
Now if you meant to write "below' instead of before, then we are in business.
If that light is Blinking it means that the drum is empty or missing.
Replace the drum
Jan 20, 2011 | HP LaserJet 2550n Printer
Se puede resetear el contador de los tambores de la oki c3400n
Trata esto:
When installing the C3400n printer, or when replacing the toner cartridge, be sure to fully insert the toner cartridge into the image drum, and make sure the blue lever is pushed ALL THE WAY toward the back of the printer (fully locked position). If it is not fully closed (locked), a "toner sensor" or "toner empty" message may result. Note: (Picture at bottom shows incorrect position of locked toner cartridge that may result in either of these messages).
Installation Procedure of Image Drum and Toner Cartridge:
          0.408?openelement&fieldelemformat=gif
    >> Insure the toner is fully locked, see photo below showing the correct and incorrect positions of the locked toner cartridge.
CORRECT (Fully rotated to lock position)
    91.28a2?openelement&fieldelemformat=gif
INCORRECT (Not fully rotated to lock position)
179.32a2?openelement&fieldelemformat=gif
Dec 01, 2010 | OKI C3400n Laser Printer
When turned on, the drum makes a grinding noise as
The main bearing may be worn out at the back of the drum allowing the drum to wobble.Reach inside the drum and lift upward. If you can move it up and down this is probably the problem.
Nov 05, 2009 | Whirlpool LER4634J Electric Dryer
Hi, The dryer drum does not start when the start button is pushed unless I rotate the drum to a specific position.
When we had this problem the solution was to replace the motor, the electric coil in the motor had a flat spot which would not make contact and let the motor start. By moving the drum you are advancing the motor away from the flat spot. Hope this helps.
Jul 12, 2009 | Asko T721 Electric Dryer
Hp clj 4550n printing blank pages
Replace the transfer belt. Known issue with this machine.
Hope this helps
May 12, 2009 | HP Color LaserJet 4550n Printer
Orange light is flashing and printer is not printing. It is not the crescent , not the triangle, but the one abve the triangle and below the colored catridge rotation button.
Imaging drum is empty or missing (Error 40204) Light pattern c00187081.jpg Description The imaging drum is empty or missing. The imaging drum light is blinking, and then printer stops printing. An error 40204 is written to the event log. The printer cannot detect the imaging drum correctly. Action
  1. Reinsert or replace the imaging drum.
  2. If the imaging drum light is still blinking but the Attention light is not on, turn the printer off, and then back on.
  3. Repeat Steps 1 and 2 with a new imaging drum.
  4. If the problem continues, contact HP Customer Care at http://www.hp.com/support/clj2550 or see the flyer that came in the printer box for other contact information.
Imaging drum e-label reader is faulty (Error 10004) Light pattern c00187081.jpg Description The imaging drum light is blinking, and then printer stops printing. An error 10004 is written to the event log. The imaging drum e-label reader is faulty and the printer cannot detect the imaging drum correctly. Action
Apr 27, 2009 | HP Color Laser 2550N Printer
Replacement drum for Q3964a
HP Color LaserJet 2820 and 2840 AiO Series Products - How to Replace the Imaging Drum Replace the imaging drum
  1. Push the scanner-release button to open the scanner assembly. Figure 1: Example of scanner release button location c00364331.gif
  2. Open the top cover. Figure 2: Example of top cover being opened c00364332.gif
  3. Grasp the imaging drum handle, and then rotate the drum until the handle is at the top.
    NOTE: The drum may be a snug fit. If needed, gently apply some force while rotating and removing the drum. Figure 3: Example of imaging drum rotation c00364333.gif
  4. Lift the imaging drum straight up to remove it from the device. Figure 4: Example of imaging drum removal c00364334.gif
  5. Remove the new imaging drum from its packaging.
  6. Place the imaging drum on a firm surface, and then pull the orange rings to remove the shipping pins. Figure 5: Example of shipping pin locations c00364335.gif
  7. Remove the orange shipping lock on each end of the imaging drum, and remove the two orange shipping spacers. Figure 6: Example of shipping lock and spacer locations c00364336.gif
  8. Remove the orange cover from the imaging drum. Figure 7: Example of orange cover location c00364337.gif CAUTION: Do not touch the surface of the roller or expose the roller to light for an extended period of time. Doing so could cause print-quality issues.
  9. Align the arrows on the side of the imaging drum with the arrows inside the printer. Figure 8: Example of arrow location c00364338.gif
  10. Lower the imaging drum into the printer, and then press it firmly into place. Figure 9: Example of imaging drum installation c00364339.gif
  11. Close the top cover and the scanner assembly.
Feb 27, 2009 | HP LaserJet 2840 All-In-One Printer
No washing
there may be some loose connection between the board and the rotating drum.....try to fix it properly
Jan 02, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
14 people viewed this question
jasbo
jasbo
