Question about Pioneer DVR-220 DVD Recorder
Pioneer DVR-220 will not power up. Any suggestions.
  • 3 Answers
First check the in line fuse...it sits right behind the electric plug on the chase..You have to remove the screws to open the case to check this....If the fuse is okay, you will have to replace these two capacitors, 10 volt, 3300uf, and 10 volt 1000uf...they are located on the same board that houses the fuse...the two location are c23 and c19 on the power board...
Posted on Aug 12, 2010
HOW TO CHANGE THE REGION CODE ON A DVR-220
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Region code hacks and codes to many popular devices are given.
May 01, 2015 | Pioneer DVR-220 DVD Recorder
DVD player powers on and then returns to standby mode
hi richard.
i have had a look around the internet but all i could find was the is link.but when you go to it its forums that you can go into.so not to sure if it will be off any use,but have a look.
Pioneer DVR 220 DVD Recorder powers on and then returns to standby mode...
Nov 07, 2017 | Pioneer DVR-220 DVD Recorder
I have a Pioneer dvd recorder that had 2 capacitors blow; a 10V 3300uf and a 10V 1000 uf. I replaced them and the recorder powered up fine but now it doesn't recognize if a disc is in it and reads "No...
Check for more damaged Capacitors and check out the resistors and diodes around the damaged caps which you replaced. Check the traces on the circuit board and look for cold solder joints bridges and such. Also... Did you make sure you got your polarity correct on your caps?
Feb 28, 2011 | Pioneer DVR-220 DVD Recorder
Can irecord on my dvr 220 pioneer from my new freeview tv
Yes you can do this. You just need to make sure that the TV outputs its picture on the scart lead that you have connected to the Pioneer unit, and you need to set the Pioneer unit to record from that scart input. Once this is done, it will be able to record whatever you have on the screen. Be aware though, if you turn off the TV it stops outputting its picture to the recorder, and if you change channel, it changes what what the recorder see's too. I hope this helps you. :)
Jul 20, 2010 | Pioneer DVR-220 DVD Recorder
I own a Pioneer DVR-220 dvd recorder and my problem is that the unit will not power up. I've tried disconnecting the ac power cord from the Monster Power power source and connecting the power cord via an...
I replaced two capacitors, (1) 10 volt, 1000uf and 10 volt 3300uf..They both sit on the power board that can be removed from the unit..You will have to unsolder the bad capacitors and put in the replacements..This wasn't hard to do...
Jun 26, 2010 | Pioneer DVR-220 DVD Recorder
No power
DC out put voltage problem
Jun 25, 2010 | Pioneer DVR-220 DVD Recorder
DVR-220-S Capacitor C19
I just purchased the following capacitors from Mouser.com. I bought 2 of each and with shipping it cost me about $10:
C17: 1800uF, 25V, D 15mm L 20mm - 647-UPW1E182MHD6
C19: 3300uF, 10V, D 12mm L 25mm - 647-UHM1A332MHD
C23: 1000uF, 10V, D 10mm L 17mm - 647-UPW1A102MPD
I could not find a replacement for the C24. My C19 blew and after replacing it the DVR came back to life.
Nov 05, 2007 | Pioneer DVR-220 DVD Recorder
Open Questions:
Pioneer DVR-220 DVD Recorder Logo
404 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
