Question about Kitchen Ranges
Frigidaire classic series. model #fgf366ccb. i'm having problems with the control panel and timer. it will not turn on or do anything. all it is showing is 9.
  • ivonnevr Jul 29, 2008
    frigidaire classic series. model #fgf366ccb. i'm having problems with the door locked. It will not turn on or do anything, all it is showing is F9 and beeping indefinately.
  • Anonymous Mar 22, 2009
    My display doesnt display anything and the oven doesnt work because any button I press wont do anything
I have the same problem - the panel goes out every now and then. I just flip the breaker to kill the power, then restore it again a few seconds later, and all is fine aga (well you have to reset the clock). :)
Posted on Apr 08, 2009
Red glow comes from oven but will not heat up
Posted on Jan 30, 2010
Where can I find a manual for M # FRS26H7CS80 ?
Hello Friend, I am happy to assist you!
It appears that the correct model of your Frigidaire refrigerator is FRS26H7CSB0. I have successfully located the Owner's Guide. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect! - Z
Jul 29, 2014 | Frigidaire Refrigerators
Frigidaire gallery professional series oven I have
Good Afternoon John, I am happy to assist you!
I understand you are seeking a manual and I'm assuming your model number is GLEFM397DS, posted above. If so, I have located the Owner's Guide on the manufacturer website. Here you will be able to access step by step instructions on how to operate the oven. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect!
Sep 16, 2013 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire gallery stove
Hello mnwpictures - Based on the symptoms you are describing the range may either have a faulty EOC (electronic oven control) or a potential wiring failure. Try resetting the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and then turn the unit back on. Does the control panel have a display? If the issue persists, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
May 12, 2013 | Frigidaire Professional Series 24 in....
I have a frigidaire Electrolux gallery series glmv168cqi microwave. The timer counts down, but the oven doesn't turn on. Sometimes when you open the door the fan turns on.
That would be a failing bottom door switch, or its mount.
My help file on door switches is here:
http://031d26d.namesecurehost.com/mwd/doorsw.txt
There's a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Once the control panel has been removed, you can access the door switches for testing and possible replacement.
There should be a technical manual hidden behind the controller or grille, too.
If you need further part ordering help, contact Electrolux:
USA
800•944•9044
Electrolux Home Products
North America
P.O. Box 212378
Augusta, GA 30917
Canada
866•213•9397 (English)
866•294•9911 (French)
North America
6150 McLaughlin Road
Mississauga, Ontario, Canada
L5R 4C2
Apr 22, 2013 | Microwave Ovens
Frigidaire Model FGF366CCB. (~5 yrs. old)...Oven-Broiler does not work. Checked the ignitor and it glows strongly, gas valve does not open. What's a good troubleshooting process?,,,
Using amp clamp with the igniter on should 3.2 amps or higher. Change the igniter, even tho it is glowing it is not pulling enough amps. Common problem and will fool you.
Feb 01, 2010 | Kitchen Ranges
I am trying to clean the oven,
you can try and hold the door closed by hand and push the self cleaning button.and it might work
if that does nothing for you there might be a problem with the door switch.
the other likely problem is a bad clock timer/main control panel
Jan 31, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire model ftr18b freezer works, fridge is only cool
Info relating specifically to the Frigidaire FRT18B5ABB:
1.Refrigerator unplugged remove the bottom back panel. (Access cover with label. The rectangular shaped panel on the back, at the bottom) Place the screws in a container.
Also remove the Kickplate Grille in the front, and the defrost pan.
2.Use the wand tip on your vacuum cleaner, and vacuum this area out. Pay special attention to the condenser coils, and the fan. Use care as you don't want to bend the fan blades. After you have vacuumed up as much as possible, see if your vacuum has where you can attach the hose to blow air through it. An air compressor, hose, and air nozzle would be REAL handy right now! Blow the condenser coils, and all areas clean of any gunk. (Hair, spider webs, etc.) If this is not feasible for you, you'll need some sort of long, thin, dust 'bunny', and have to dislodge this 'gunk' physically. Then vacuum.
3.BE SURE to replace the bottom back panel, (Access Cover)! It is a VERY necessary item! If your fridge doesn't have one at present, make a temporary one of cardboard, and tape it on. This access cover is needed.
If your refrigerator side is only cool, and your freezer is cold, you may have a problem with the Cold Control, (Temperature Control), or the Defrost Timer. (Timer-Defrost)
http://disruptit.com/manualgateway.cfm?pdfwanting=34242&username=anon&AV=123345&I=99.169.118.45
Jul 05, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Control panel on oven not working (clock/heat time, etc..) (model fgf326a)
HI, this control(clock/timer), will need to be replaced at this time. this code represent a control fault within the chip set(logic). this control has failed.
Jun 01, 2009 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire Dryer (electric) wont start
it could be the door switch or the control timer .
Oct 19, 2017 | Frigidaire AEQ6000ES Electric Dryer
Dryer will not run
dryer starts sometimes if you hold in button. frigidaire gallery series model # GLEQ942CSO. serial # XD350164472. flat panel control board.
Mar 31, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Kitchen Ranges Logo
1,246 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
