Question about Haier Heating & Cooling
I have a haier window unit. i have a display on the control panel of "E1". the green light is on attached to the power cord. the only way i can get the display is if i press the power button down and plug in at the same time. the unit is one year old.
    President:
  • 1,070 Answers
Welcome to Fixya
Sir,
E1 means indoor ambient temperature Sensor Error...
Outdoor Power model Error /Compressor High Pressure Protection .Unplug Power Code and may need to Contact Service Personnel for Further Repair..
Try washing out out side coil. Check voltage when unit is running.Compressor, Capacitor maybe weak.
Here is Service manual for Heir Click here[Read it Carefully to Get an Idea-You should need Acrobat Reader to Read this Guide]
Check Page 48 to Know Function and all Page for Further Information....
I hope you got an idea Now...Thanks for Contacting Fixya
Posted on Jul 08, 2010
My air conditioner showing on the display is E1
The E1 Error Code The most common reason for an E1 error code to be displayed on your air conditioner's front panel is to remind you that the unit's air filter needs to be cleaned. Many models will automatically notify you of this via an E1 error code display after the unit has been operated for a predetermined number of hours. For example, many Sharp models will display an E1 code after 720 hours of use. Alternatively, you could have dirt or moisture in your front button controls, causing them to stick or not function properly. This can be a common problem with many models of Haier air conditioners, but the issue is not restricted to any one manufacturer. Your air conditioner could also have a defective thermistor, which is part of the thermostat.
For Samsung, the room thermistor needs replacing. This is a device that senses the temperature in the room.
How to Fix an Air Conditioner When It Gives You an E1 Code eHow
Jan 24, 2016 | Heating & Cooling
Ac won't turn on after cleaning and E1 appears on control panel
E1, The e1 error code could mean multiple things. The most common fault with the unit is a stuck button on the access panel. Gently push each button in and out to ensure none of them are stuck. The panel may have malfunction due to moister. See that the unit is installed properly, and then leave it off for a few hours so the moister can dry up. if these two things dose not work then the temperature sensor could be bad. Heir 1-877-337-3639
Oct 01, 2014 | Haier 5200 BTU Window Air Conditioner...
Goes on when it wants to and it displays E1
can give the model of that aircon
Split type
E1 Indoor and outdoor communication abnormal
possible damage main PCB at outdoor units due to power supply problem.
Apr 08, 2014 | Haier HWR06XC6 Wall/Window Air Conditioner
Unit shows e1 and will not turn on how do i reset it plus i have no remote for it
The only way to reset this is to unplug or remove power to the unit, wait 30 seconds and return power, If this does not work changing the control/display board would be the next step.
Jul 27, 2011 | Haier ESA3087 Thru-Wall/Window Air...
I have a Haier room air conditioner that has been running for about a month. The E1 light comes on and will not go off. The unit cannot be powered off using the power button, only by disconnecting. After...
Here is a tip that gives a further explanation of that E-1 code. The causes of the E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening with your window air conditioning unit and give you some things to try to help you get your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Aug 29, 2010 | Haier Heating & Cooling
E1 error code on air conditioner
I called haier about this error code. E1 indicates that a button on the control panel or the reomote is stuck. I was instructed to unplug the unit and push each button at least 5 times, one at a time. Plug the unit back in, and this fixed my problem with error E1 and the unit works fine.
Jun 23, 2008 | Haier HWS08XC1 8,000 BTU Window Air...
Haier E!
E1 means one of the buttons on the touchpad is pressed in. The remote will still operate the unit. You might have to pull the panel of, and check all the buttons. If all seems fine replace the control board. might not be worth it thou..
Aug 08, 2007 | Haier HWC08XC1 Wall/Window Air Conditioner
Heating & Cooling Logo
32 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
