I am facing frequent paper jam problem with fujitsu scanner fi-6130. But its an adf scanner it does not comes with flatbed.can you please help us..
    Problem Solver:
  • 6 Answers
If it has a manufacturing date of march of 2009 thru august of 09, then it has a defect with the glass mounting on the base assembly. unfortunately, i used to work fixing these things all day long. What is the manufacturing date of the scanner? See the rear label in the back to find out.
Posted on Jan 22, 2011
What is lifetime of scanner motor fi-6130
Hi Milena,
In order to assist you, please describe the issue that you're facing with the scanner.
regards,
TechSatya
Apr 07, 2014 | Fujitsu fi-6130 Flatbed Scanner
Fi-6130z fujitsu scanner jamming repeatedly
Hello Meg,
To troubleshoot your scanner issue, yuo are advised to perform the steps provided below:
1.Remove all documents from the ADF paper chute.
2.Open the ADF while pressing down the ADF open lever. If your has the imprinter option attached, please open the imprinter and then open the ADF.
3.Remove the jammed papers from the ADF.
4.Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, then please check the followings:
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is resolved.
5. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the values, replace Pick roller or Brake roller see if the error is resolved.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Nov 26, 2013 | Fujitsu Fi6130z Sheetfed Scanner
Error J1
Hello Sharon,
When a document jam occurs, "J" and "1" will display alternately on the function number display panel of the scanner.Please perform the following:
  1. Remove all documents from the ADF paper chute.
  2. Open the ADF while pressing down the ADF open lever. If you are using fi-6130 with the imprinter option attached, please open the imprinter and then open the ADF.
  3. Remove the jammed papers from the ADF.
  4. Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, please check the followings:
resolved.
5. Replace Pick roller or Brake roller, and see if the error is resolved.Check the consumable counter from the TWAIN driver screen or from the built-in Maintenance mode. When the counter exceeds the values, replace Pick roller or Brake roller.
Thanks & regards,
ScanCare
May 03, 2013 | Fujitsu Office Equipment & Supplies
Fi-6130 door is lock how to unlock
The ADF Lock Lever is broken and need to be replaced. you are recommended to contact a Fujitsu scanner expert for the replacement. Please let me know your location, so that I can refer you a Fujitsu scanner expert.
Thanks,
Scancare
Apr 30, 2012 | Fujitsu fi-6130 Flatbed Scanner
Fi-6130 scanner displays J1 paper jam after
Does the message shows after few pages scanning or is there any panel error message like J-1 on scanner start up?
If the issue occurs during scanner start up, then there are staple pins or dirt might be stuck inside the US Sensor panel inside the scanner. Cleaning and removing the objects will resolve the issue.
If the error occurs after few pages scanning, then you may have to check the Pick Roller, Brake Roller, Pinch Roller and US Sensor FX status. you may have to replace any of the above, if damaged or worn off.
Please check your device first and get back to me.
Thank you.
Regards,
TechSatya
Jul 19, 2010 | Fujitsu fi-6130 Flatbed Scanner
Fi-6130 not grabbing paper, displays Code: DS32002
My scanner is Fujitsu M4097D. I just have problem with ADF: Error Code DS32002: Paper jam in the ADF. Here is my solution: 1. Bend two white platin pieces down a little bit in order to "sensor" the paper scanned. This problem is occurred after I am scanning 50 thick pages. Until paper count 42, it is stopped with error code DS32002. Hope help anybody having this problem.
Jan 06, 2010 | Fujitsu ScanPartner fi-5120C Pass-Through...
Scanner Display Shows False Jam
You can try 1. reseting the scanner 2. uninstalling and reinstalling the software
PLEASE don't forget to RATE ME (FIXYA) for my help..........
Aug 15, 2008 | Fujitsu fi-5750C Flatbed Scanner
Fi 5750c adf will not initialise
Just something simple to try...check your software setting to see if it is set for ADF or Flatbed feeding. You said the light bar moves when power is interupted or the adf opened. But you never said if it is scanning in Flatbed mode. If the Flatbed scans, then check the software setting. Most of the flatbed/adf hybrid scanners start up defaulted to flatbed, so when you try to scan, the adf won't pull anything thru until you change to ADF mode.
Mar 13, 2008 | Fujitsu fi-5750C Flatbed Scanner
Computers & Internet Logo
129 people viewed this question
David Payne
David Payne
