Question about Canon L220 Plain Paper Laser Fax
Changing outgoing name on fax
I need to know how to change name that appears on the top of the fax when the receiver gets it at the other end - we have had a business change hands and we have kept the same hone number and need the name changed - can you help its for a canon L220 fax
    Sergeant:
  • 287 Answers
The MANUAL should answer your question
Posted on Jul 16, 2008
Changing forwading Fax ID address from fax Canon JX200
This information appears at the top of each document you send.
1 Press [Menu].
2 Use [{] or [}] to scroll through the menus and select <DATA REGISTRATION>, then press [Start/Copy] twice. The LCD displays <DATE & TIME>.
3 Use [{] or [}] to select <UNIT TELEPHONE #>, then press [Start/Copy].
4 Enter your fax number (up to 20 digits) using the numeric buttons, then press [Start/Copy] twice (see page 9).
You can enter a space to make your number easier to read.
5 Enter your name (up to 24 letters) using the numeric buttons, then press [Start/Copy] (see page 9).
6 Press [Stop].
Registration ends and the fax returns to standby mode.
Nov 19, 2011 | Office Equipment & Supplies
I have a Brother Intellifax 1270e and am wondering if I can program it for outgoing faxes only.
See manual section 5-1
http://www.manualnguide.com/dl/11582/
you want to set receive to manual so that any incoming faxes will have to be manually received.
To change to this setting press "receive mode" until manual appears.
Let me know if this works for you.
Mar 10, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
I dont know who to change the phone number on the out going cover page so the receiver has a fax number to send back papers sent
If you don't have a User's Guide, go to the Brother web site and download it. But as a quick fix, you can access the menu function and navigate to settings and find the outgoing fax number place. Then you can change the number and name as you desire.
Jan 24, 2010 | Brother IntelliFAX 1570MC Plain Paper Fax
How do i change my fax number
Changing the Fax Configuration
1 Click Start/Programs or All Programs/Accessories/ Communications/ Fax, and then click Fax Console.
2 In Fax Console, click Configure Fax on the Tools menu to start the Fax Configuration
Wizard.
3. On the Transmitting Subscriber Identification (TSID) screen, type the identification information (usually your fax number and your name or business name) in the TSID box. This information will appear in the header area of the faxes you send and identifies your
fax machine to the person who receives your faxes.
Aug 16, 2009 | Dell 942 All-In-One InkJet Printer
HOW DO I CHANGE THE NAME(OF FAXER) ON OUTGOING FAXES?
Try MENU,*, w9 to get into Initial Programming then scroll to the "Name "you wish to change
OR try
Program, I(capital letter I ), ENTER to access initial programming then again scroll to nam you wish to change.
Mar 15, 2009 | Muratec F360 Plain Paper Laser Fax
Sharp AR-275 copier with fax module. Need to edit sender ID
push custom or system setting button, push key operator programs on lcd, type in 00000 from number pad, hit fax settings, fax default settings, own name/number set. hit ok button at top when done then CA button to return to main menu.
Mar 04, 2009 | Sharp AR-275 Copier
Change name that appears at the top of outgoing faxes
press Menu
press 5 then 2
select the "fax header" option
when your name appears, enter your name using the keyboard.
the keyboard is similar to cell phone keyboard.
press enter
enter the fx number when your are prompted
press enter when finish.
if you still haev problem, please click on the following link for HP Officejet6110 users' manual.
Feb 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Changing a name
This model number appears to be a copier. Are you sure you have the right model?
http://safemanuals.com/zearch_634.php
Aug 25, 2008 | Sharp AR-F152 Fax
Fax confirmations
i have read the manual end to end and I don't think you can.
Only thing I see is this.
Customizing your settings using the Lexmark Fax Solutions You can adjust the fax settings in the Lexmark Fax Solutions. These settings apply to the faxes you send or receive.
  1. Click Start onestep.gif Programs onestep.gif Lexmark 7100 Series onestep.gif Lexmark Fax Solutions.
  3. Click each tab and change the settings as desired.
  4. Press Save Settings after you finish your updates. Nothing is saved until you press this button.
  5. Click Close.
The following table contains the Setup and Settings tabs for the Lexmark Fax Solutions.
On this tab
You can
Personalize
  • Enter your company name and fax number.
  • Enter your name, company name, phone number and address as you want them to appear your cover page.
  • Select a cover page for your fax.
Send
  • Choose to use error correction.
  • Choose to use fax header.
  • Select a maximum send speed and a print quality for outgoing faxes.
  • Choose whether to scan the entire document before dialing the number.
  • Select when to print a fax usage report.
  • Select when to print a fax activity report
Select when to print an activity report is the only close item I can find. Nothing whatsoever about a confirmation report.
Feb 25, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
A change in admin settings
see that the printer shows ready for copy, then try to go to admin menu
Sep 25, 2007 | Konica Minolta bizhub C250 All-In-One...
Canon L220 Plain Paper Laser Fax Logo
193 people viewed this question
old marine
old marine
