Question about Sunbeam Heating & Cooling
A/c goes from cool to hot. filter is clean. fan working good. level in window. no obstructions.
  • 478 Answers
AS long as this one doesn't have a heat setting.The compressor is dead as the bypass valves are opening if under warrenty tak it back.
Posted on Jul 08, 2010
99 cadillac deville runnin hot
Look for the silly stuff. Check for things blocking off the radiator, coolant level, water pump belt, etc. If none of those help, check the cooling fan, coolant temperature sensor, fan relay and fan fuses. If everything there is working, consider a stuck thermostat, an obstruction in the cooling system itself or a failed water pump. Kind of a long shot but engine timing can also make it run hot. Hope this helps.
Jan 27, 2017 | 1999 Cadillac DeVille
Why isMy Acer aspire gettting really hot, would replacing the battery help?
Sometimes, the computer gets really hot because the "ventilation" (cooling) system (fan, etc.) is not working properly. Normally, if it gets too hot, i.e. to an unacceptable level, the system will shut down. Or, it will catch on fire.
Yes, it's known that some battery will get too hot ... and potentially damage the system. So, if you already know that the cooling system is working properly, then try replacing the battery.
May 28, 2014 | Acer Aspire One PC Notebook
Mini Cooper temperature gauge goes to red zone when idle
check coolant level could be too low allowing air in the cooling system causing air pocket in engine around the engine coolant sensor.coolant sensor needs to be in hot coolant so it will cause the cooling fan to come on at a set temperature.make sure coolant correct level and the coolant level in the cooling overflow jug should be at full cold mark.the cooling overflow jug should never be empty,if you see empty cooling overflow jug air got in the cooling system so make sure when engine cold every time raise hood make sure cooling overflow jug coolant level at full cold mark.if jug stay empty you have cooling leak.so replace radiator cap,if coolant level all good,i would replace the engine coolant temperature and thermostat.when your car come to a long stop or driving along long line of slow moving traffic the engine coolant blower motor should running if not have vechicle code scan for faulty coolant fan motor control module.or ecm problems.
Sep 01, 2012 | 2005 Mini Cooper
KSCS25IL the control panel shuts off and then beeping begins. when i unplug it and start it again, control panel lights up again for a few minutes but then goes dark again. the refrigerator and freezer...
Check the condenser probe's not too hot, clean the grill and make sure all fans are working ok. Check inside isn't frozen up obstructing airflow.
May 17, 2012 | KitchenAid Refrigerators
Where the two doors meet it is hot why?
Pull the refrig out and remove the rear panel . Check the fan there to see if it is working and the blade is not obstructed . If not working , and the blade is not obstructed , replace the fan motor . Also make sure the coils in front behind the kick plate are clean of dust , lint , etc . The cooling fan not working will cause the center door strip to get very hot .
Jun 13, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
Hot strip between doors
First , remove the bottom kick plate , and vacuum the coils . They have to be clean of dust , lint , pet hair , etc . Then pull the refrig out , and remove the lower panel , to expose the compressor and cooling fan . This fan HAS to be working , to cool the compressor AND the coils . If not running ( fan ) , check for an obstruction of paper , insulation , etc , and remove the cause . If not being obstructed , and not running , replace the fan motor . Afterwards , be sure to reinstall the back panel , as this panel , helps pull the airflow across the coils , and compressor . The strip between the doors , has part of the coils behind it , and will get hot , if the coils in front are dirty , or , the fan behind the refrig is not working .
Dec 04, 2009 | Whirlpool Refrigerators
The window unit is turned on, but doesnt seem to be very strong with blowing cold air . is there something that can be checked on the unit? something that can be replaced on the unit-like a filter? since...
first make sure the filter and coils are clean, then be sure you have it set for recirculate and not outside air allowance, and if ou wait til the room is very hot it will take a while to cool that room down to a comfort level. the fan and temperature control should both be at maximum if the room is very hot.
Jun 25, 2009 | Heating & Cooling
How do I clean air filter on the Panasonic PT-50LCX64?
I feel bad for you having such problems with the vendor and the technician too.
The location of that filter could be a small window in the back cover itself. could be a plastic window to the left side of the unit and is only a piece of plastic poliuretane kind of black sponge about 5 by 3 inches size .
What im interested telling you about the shut down condition and is maybe even most important than where is the air filter (who is one of the more than ten posibilities why the tv goes to shut down.
Note:
if the air filter is totally obstructed i would give one of ten probabities of suspicious why the tv shuts down:
first because the tv's air duct is not really isolated. The fan can eat air by any side of the air filter base as i said if the filter is totally obstructing which is really extreme. besides maybe the other 2 fans could help to cool down the unit in that case scenario. In my experience Most time the air filter holds tons of dust but is not totally obstructing the air passing, and really some other problems are in the set.
This is the really critical to know: if any of those fans stopped or maybe any sensor is overheated or the lamp is coming to dead or who knows.. a diagnosis is needed for this symptom really common in DLP technology.
Apr 18, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Home Air Condition cooling problem
Hello. If your outdoor coils are dirty it's a good chance the indoor coils are dirty also. Clean the indoor coils and flush out the condensate line.
I know it's tempting to feel the air and try to decide if the unit is working properly but, you need to use a thermometer and while the unit is running check the temperature at the return air vent and then check the temperature at the supply vent closest to the unit. Remember to let the thermometer set for about 5 minutes before reading.
You should be looking for about 15 degrees F cooling between the return and supply.
If your coils are clean make sure the outdoor fan is operating properly. The air coming out of the outdoor fan should feel warm, almost hot. If not you may need to check your pressures. Good luck and let me know what you find.
Feb 03, 2009 | Ruud Central System Air Conditioner
Displayed massege to check air flow
With most projectors there is a foam air filter behind a grill that is the opening to the cooling channels. A fan ensures air flow to cool the lamp, etc. This filter prevents dust from gumming up the works (and depending on design) may prevent dust getting into the optics. As the filter gets dirty it gradually cuts off the air and at some point a protective circuit kicks in and turns off the lamp.
If the projector is on you will feel a stream of hot air coming out of the exit vent. Projectors vary in terms of amount of air flow, so its difficult to define what is normal for a specific model. However, you can simply hold a hand in front of the vent and see if there is air flow (It will be hot air so, careful). If there is a "good" stream of air things are fine, but if only a very light flow is felt the filter may be dirty.
If the filter has not been cleaned or replaced recently make sure the projector is turned off and cooled down then take off the inlet cover and remove the filter. Clean or replace per the instructions for the projector (and periodically as defined .. but taking into account the operating conditions). Once cleaned turn on the projector and feel the "normal" air current for future reference.
Heat is one of the major causes of projector failure, so make sure cooling vents (inlet and outlet) are not obstructed and filters are kept clean
Oct 02, 2006 | Hitachi CP-S240 Multimedia Projector
Heating & Cooling Logo
Top Sunbeam Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
