Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
I have Coleman Spa model 550 DK Twilight 2001. Recently I replaced motor and pomp unit for new one. Everything worked fine for one day,then it stoped and display shows code OH.Please help me.Andy.
    Genius:
  • 1,478 Answers
The OH code indicates 'Over Heat' but typically doesn't mean the whole body of water has overheated. It usually means the water inside the heater is overheating.
If your tub uses a mechanical pressure switch check to see it isn't stuck in the closed position. In some modes of operation a stuck pressure switch will allow the heater to come on or stay on even when the pump stops moving water through the heater.
This can cause the water in the heater to overheat and trip the OH error. If you happen to be standing there when this happens it sounds like water starting to boil in a tea kettle.
If your tub uses two heat sensors instead of a pressure switch it's possible your heat pump (or the low speed function of Pump1) is intermittently failing to start. The tub will call for heat and engage the heater but the pump doesn't move any water. The heater starts to boil just like above.
You can troubleshoot a heat pump/low speed pump problem by setting the tub to filter continuously (if possible). This is usually indicated by 'FC' in the filter mode settings on digital controls. If you have a mechanical timer you simply set it to run 24 hours.
Since the pump never stops running on FC or 24 hour operation it will never have to stop and restart. If you run for several days to a week on 24 hour operation without experiencing an error try setting it back to the normal mode of filtering a few hours a day. If the OH error returns it is almost certainly a pump failing to start when the tub calls for heat.
It is also possible you have a bad OH sensor or even a bad circuit board. The board could be reading the sensor incorrectly or it could have a heat relay that sometimes sticks in the closed or On position.
Take care.
Posted on Jul 22, 2010
    Guru:
  • 302 Answers
Please check the following link, it has detailed info about the OH code.
http://en.allexperts.com/q/Hot-Tubs-3536/2009/12/Coleman-OH-Error-Code.htm
Regards.
Posted on Jul 21, 2010
  • 2,359 Answers
OH or OHS stands for
Overheat protection.
The spa has shut down.
One of the sensors has detected that the spa water is 110°F.
DO NOT ENTER THE WATER. Remove the spa cover and allow water to cool. At 107°F, the spa should automatically reset. If spa does not reset, shut off the power to the spa and call your dealer or service organization.
The cause:
The temperature is over the factory preset 107F temperature setting.
and/or
One or more protection sensor(s) is out of range/defectve.
Spa cover will over the circuit if you are pumps setting is set to
FILC Continuous filtration
Reduce filtration cycle will help reduct over-heating condition (example:during summer time with temperature already in 100F).
The factory pre-programmed cycle two times per day at 2 hours duration.
What's your current setting now?
Reduce it to keep the temperature down and reduce energy usage,
Here's the display list for two pump system.
For two or three pump systems:
FIL2 Two hours
FIL4 Four hours
FIL6 Six hours
FIL8 Eight hours
Avoid FILC. It will shorten the service life or your pump.
Please email me if you have more question.
Please give me a positive feedback after you fix this problem.
Posted on Jul 20, 2010
  • Vincent_G
    Vincent_G Jul 21, 2010
    Are to able to dial down the FILT setting down to twice a day for 2 hours duration?
    Is the Spa cover OFF?
    Check the water temperature. If it's in fact under 107F and the system is shutting itself off then the sensor is out of specification.
  • 6,993 Answers
please what's the code displayed on the unit?
I look forward to your reply.
Bye for now.
Posted on Jul 18, 2010
Have an older Coleman mobile home furnace (Mdl 8665D766). Both blower fan and booster motor work fine; however, during heating, booster motor will keep constantly running after system cycles through
The booster motor? Do you mean the inducer motor that helps push the exhaust? If the inducer motor won't shut off when the thermostat is satisfied and everything else does shut off, it sounds like the contacts on the relay that powers the inducer are at fault
Feb 03, 2018 | Coleman Heating & Cooling
My chrisler crossfire 2004 will not start,i already checked the rcm and the interlock switch by the clutch pedal but everything seems to work fine.by turning on the ignition all lights seems to work fine...
No get the immobilizer checked as the motor will crank untill the battery is flat as the ecm will not be getting the code to tell it to allow the motor to run
Aug 16, 2017 | Bosch 1985 - 1994 Classic Saab 900 Turbo...
My Suzuki GS 550 L wont start
check the cdi box i think thats your problem if so buy a dyna s 3 for it works great on mine
Sep 13, 2012 | 1982 Suzuki Gs 550 L
Key will start car, but will not lock/unlock car
check battery in key/check under back seat lock /unlock motor there/key not programmed to lock doors
Mar 11, 2011 | 2001 Mercedes-Benz E-Class
My Coleman Evcon heating and air unit will not blow air
bad blower motor. recommend a new blower motor and capacitor.
May 28, 2010 | Coleman Heating & Cooling
Replacement fan motor for coleman mach3..need wiring diagrm
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Apr 14, 2009 | Coleman Mach III Air Conditioner
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
715 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
john h
Craig Butler
Craig Butler
wadingriver
wadingriver
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
