Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
I have Coleman Spa model 550 DK Twilight 2001. Recently I replaced motor and pomp unit for new one. Everything worked fine for one day,then it stoped and display shows code OH.Please help me.Andy.
  • 2,272 Answers
OH = Sensors reading 112-118 Degrees. The OH error code is show due to overheat. A dirty or worn out filter can cause several error codes to be displayed. “OH” (over heat) because water is not moving quickly enough through the heater vessel and the high limit detects too hot of water temperature. Check the filter. The spa is most likely heating up past the set temp due to a pump that is most likely running continuously due a filter cycle setting being set for too long. But if there is nothing overheating and water is cool then this error is related to control board of the spa,In other case the filter has to be checked also checked the fitting of new pump to the filter.If the pump is not fitted properly then this can result. If in-case you get SN error then this is related to temperature sensor. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jul 08, 2010
  • andymazurek Jul 10, 2010
    Hi,I checked filter ,its OK.Despley shows mi FLO, then Econ.When I press Mode it shows StAn.
    Help please.
My Suzuki GS 550 L wont start
check the cdi box i think thats your problem if so buy a dyna s 3 for it works great on mine
Sep 13, 2012 | 1982 Suzuki Gs 550 L
Key will start car, but will not lock/unlock car
check battery in key/check under back seat lock /unlock motor there/key not programmed to lock doors
Mar 11, 2011 | 2001 Mercedes-Benz E-Class
My Coleman Evcon heating and air unit will not blow air
bad blower motor. recommend a new blower motor and capacitor.
May 28, 2010 | Coleman Heating & Cooling
I recently had my screen crack on my Hp 550...How do I know if a LCD is compatable? Will any LCD made by HP work if it is the same size (15.4")? How do I find my model number
If you are referring to an external LCD monitor, any LCD monitor will work as long as the connectors are the same. VGA to VGA or DVI to DVI, otherwise you have to get an adapter.
To know what kind you have, if your display ports is 3 rows of 5, that is a VGA port. If it is 3 rows of 8 holes, that's a DVI.
Now to find the model number without turning it on, on the bottom of the laptop you can find a service tag. PRODUCT will tell you what the model number is. Also, you can find this info on the battery.
Hope this helps! Please don't forget to rate the answer. Thank you!
May 07, 2010 | HP Business Notebook 550
Squirell cage blower motor runs all the time
Relay. You may just have it wires wrong but relays are easy to replace. Rus
Jun 14, 2009 | Coleman Heating & Cooling
Replacement fan motor for coleman mach3..need wiring diagrm
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Apr 14, 2009 | Coleman Mach III Air Conditioner
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
133 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
