Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag dishwasher leak in door.. am I missing a gasket?
    Top Expert:
  • Maytag Master
  • 76,673 Answers
Clean the door seal that is there, us a mold and mildew remover like LYSOL brand, the built up food and grim can cause the door seal to leak
Posted on Jul 08, 2010
We have a Maytag Model MDB7100AWB that is leaking from the lower RH corner. We have checked and repositioned the door gasket, and it helps but does not stop the leak. Any other suggestions?
make sure that the door is not hitting the surrounding cabinet or drawers. and check to make sure that the
dishwasher is not pushed to far back in the cabinet which will cause the door face of the dishwasher to hit the front of the cabinets and not seal all the way around,,
Nov 11, 2009 | Maytag MDB7100AWB Dishwasher
Maytag Jet Clean leaking through right side of door during rinse
It is important to examine the leak to see where it probably originates.
If the water is leaking from the right hand side of the door on your dishwasher, it is time to replace the gasket that seals the door when the door is latched.
Aug 10, 2009 | Dishwashers
Brand new dishwasher installed and water leaks out bottom of door
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note…If the main motor of your dishwasher is mounted vertically, beneath thecenter bottom of the dishwasher, the following instructions probablyapply to you. But if your motor is mounted horizontally, the pump isn'tserviceable--you need to replace the entire pump and motor assembly.
Themain tub seal is beneath the drain impeller. It prevents the water inthe dishwasher from leaking out near the shaft of the motor. To get tothe seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Overtime, door gaskets and seals harden and lose their ability to sealproperly. You can't repair the seals. You need to replace them ifthey've begun to leak.
Water-inlet valve Thewater-inlet valve, itself, seldom leaks. But, the water-supply linefrom the house and the rubber tube leading from the valve to the insideof the dishwasher may leak. Tighten or repair/replace these asnecessary.
The water-inlet valve could mechanically stick open.When that happens, the water continues to flow into the dishwasher,which then floods your kitchen. Turn off the water supply to thedishwasher, and replace the valve.
Hoses Behindthe lower access panel on your dishwasher are several rubber or plastichoses. If the leak appears at a connection, try a new clamp. If thatdoesn't work, replace the hose.
Dec 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
MAYTAG JETCLEAN QUIET PACK
hi Replacing the Door Gasket
If water leaks through the dishwasher door, the gasket is probably faulty. Open the door and examine the gasket. It should be soft and resilient. If it's worn, cracked, or hard, it should be replaced.
Once the gasket is in place, check it for fit against the door frame. It should fit tightly with no cracks or bulges between the gasket and the frame. If necessary, tighten or loosen the retaining screws, or refit the gasket in the clips or the door channel. Then run the machine through a washing sequence and check for leaks.
If you spot a leak, and the gasket seems to be properly in place, try adjusting the door latch. The trick is to position the gasket against the frame of the door without flattening the gasket or squeezing it too flat when the door is latched properly. Adjust the latch or the gasket until it fits snugly against the door frame.
Oct 10, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag dishwasher mdb5000awa leaking
Well did you check to see if the door seal is ripped or not on tight??? The door seal is the rubber strip that is used to seal the door shut tight, if this is wrecked in any way that might the the answer to your solution?
Dec 20, 2007 | Dishwashers
Leaking from the door
This has happened to us a few times. There is a gasket inside the door for a solenoid that operates the flap that opens to let dishwasher detergent out. The gasket went bad and water leaked through.
The only thing to do is replace the gasket. It's a $8 part. (A lot for a 1 inch square gasket!) They seem to last about 2-3 years.
Nov 09, 2007 | Maytag 24 in. MDB6100A Built-in Dishwasher
Leaking dishwasher
Are you washing cereal bowls or mixing bowls on the bottom rack? If so, are you placing them in front? Sudden leaks that form huge puddles can often be attributed to improper loading of the dishwasher. Most dishwashers don't have a seal across the tub front. The door closes over it and does a pretty good job of deflecting water back inside the wash cavity. However, if you place bowls in the front on the bottom rack rack they can divert the water right over the tub lip and onto the floor. This is usually the culprit that causes most leaks in dishwashers. Now, if you don't think you have a loading problem, remove the kick panel on the bottom of the dishwasher and check the drain line and pump housing for leaks. Check the door gasket for tears or cracks. Lastly, feel inside the bottom of the door with your hand. You should be able to feel the door insulation. If it is wet, then the problem could be a leak around your soap or rinse-aid dispenser. Depending on the model, some dispensers are mounted to the door with a gasket behind it. Sometimes this gasket can form leaks. I hope this helps.
Jun 05, 2007 | Maytag 24 in. MDB3700 Built-in Dishwasher
Maytag Neptune MDE5500AY Electric Dryer Logo
54 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
