When I copy, document comes out backwards
I have a Lanier LD232c at my office. When I copy a multi-page document, the top page is on bottom and the bottom page is on top. How do I fix this?
  • 4 more comments
  • juliesmce Jul 12, 2010
    If I copy a multi page document with a cover page, when it copies, the cover page comes out on the bottom, with the last page on top.
    Didn't work.
  • juliesmce Jul 13, 2010
    I do not see an option for face up or down under input/output. Sort option is activated.
    I think making the copies come out face down will work, I just need to know where this option is.
    It is not hooked up to be a printer. It is a copier only. It does not come out of the middle section, the copies come out of the left side.
  • juliesmce Jul 14, 2010
    Fixed!!!
  • 313 Answers
Hi you need to press the 123/user button on the top left of the display this gets you into setup press for the copier and here you will see the sections for paper and default setting you are looking for the duplex it will be set up tor top to top or top to bottom see which it is set on and change it to the other setting
Posted on Jul 12, 2010
Testimonial: "Fixed it!!!! Thank you!"
  • 1 more comment
  • Andy Bell
    Andy Bell Jul 13, 2010
    Hi
    sorry didnt get back I think I read your problem wrong thought you were duplexing (back to back) If your output is for more than one copy make sure you have the sort function activated otherwise it will stack the copies and give the result you have also check the output is coming out face down. you can check these in the user tools via the 123/user button. then input output tab. hope this helps A
  • Andy Bell
    is your unit the copier or the printer version..does it have the scanner unit on if so the 123/user button is on the left hand side at the top of the control panel here you will find the copier-printer user settings system settings is where yu find the paper eject settings..you can also get it to print to the internal tray this will give you the correct paper output..you may be able to set it up via the print properties if you are printing from a computer..
  • Andy Bell
    Andy Bell Jul 14, 2010
    ok thats answered the reason for the output.. you need to go into the user tools via the 123/user button and look for copier output change the paper exit to the internal tray this will sort your problem
How do I adjust print margin in service mode
I figure it can be done on the computer settings for the printer.
Jul 16, 2015 | Lanier Ld228c Ld232c Ld238c Copier Fuser...
Ld238c replace fuser
Its a maint. light, no need to replace unless quality problem. -Carl
Mar 22, 2014 | Lanier Ld228c Ld232c Ld238c Copier Fuser...
How do I change margin setrtings foe Lexmark P4350
If you are preparing to print a document that you have created in Microsoft Word, you may be concerned that all the text on the page will print exactly as you see it on your screen. This is not always the case. You can adjust your print margins to ensure that your text prints on each page exactly the way you would like it to appear.
Opening Your Document
Open your Microsoft Word document by double-clicking the Word icon on your desktop. If you do not see the icon on your desktop, then you can locate it where it is buried on your "Start" menu. Click "Start," followed by "All Programs." Then click "Microsoft Office," followed by "Microsoft Office Word." A new document will open on your screen. Click the "Office Button," followed by "Open." Scroll through the files listed, and double-click the one you would like to print. It will open on your screen.
Check Your Margins
By default, your page margins are set to 1-inch margins on the top, bottom, right and left of your page. You can check your margins or change them by clicking "Page Layout," followed by the "Margins" button.
Select New Margins
Select a different margin size, such as "Narrow," which indicate 1/2-inch margins, or "Wide," which indicate one-inch margins on the top and bottom and two-inch margins on the left and right. You also can select "Moderate," which indicate one-inch margins on the top and bottom and 3/4-inch margins on the left and right. Finally, you can select "Mirrored," which indicates one-inch margins for the top, bottom and outside. The inside margins are set at 1 1/4 inches.
Print Your Page
Print your page. Press "Control" plus the "P" button. The printer dialog menu will come up. Make sure that "All Pages in Range" is selected. Press "OK." If your printer cannot print your new margins, then a new menu will pop up telling you to adjust your margins.
I hope you find it very helpful. Best regards.
Aug 22, 2011 | Lexmark P4350 All-In-One InkJet Printer
Trying to fax, scan or copy and anytime I try the erro message Document in ADF press OK to discharge document
Hi sdrnjen977,
Here's what you can do to address the issue and clear error message: Document in ADF.
If you press the Stop button during scanning, Document in ADF. Redo operation after checking document in ADF and pressing OK. appears on the LCD. Press OK button so that the remaining document is automatically fed out.
Removing the jammed document from the Document Tray:
1. If printing is in progress, press the Stop button.
2. Turn off the machine.
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF, then open the Document Feeder Cover.
4. Raise the Paper Release Lever, then remove the jammed page from under the roller to the Document Feeder Cver side.
5. Pull out the jammed document from the ADF.
6. Press down the Paper Release Lever, close the Document Feeder Cover, then turn on the machine.
Removing the jammed document from the inner side of the Document Cover:
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF.
4. Open the Document Output Slot.
5.Open the Document Cover.
6. Insert your hand into the Document Output Slot, then while pushing up the paper output rollers inside the Document Output Slot with your fingers, pull out the document from the inner side of the Document Cover.
7.Close the Document Cover.
8. Close the Document Output Slot, then turn on the machine.
Hope this helps.
Thank you for using FixYa.
Jun 30, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Put the last page in first and the first page in last.
Jul 08, 2010 | Lanier UNKNOWN
How do I clean the transfer belt on my Lanier LD232c (same as Ricoh Aficio 2232)?
The transfer belts on these generaly cant be cleaned if you know how you can just remove the transfer belt unit and take the cleaning unit ou this is positioned on teh leaft hand side just under the belt at the top there is screw take this out then press the small brown lever and and pull teh unit out carefully make sure you press the lever in as jif you dont you can damage the belt..vac this out and wipe the blade with a soft dry cloth.. if you are savy with the machine the main area to clean is the alloy or chrome roller at the top.. you will have to take the belt off to clean this.. the id sensors read off this to get reg and colour calibration right so it coulld cause problems if this is dirty..let me know if this helps or if you need more info..Good Luck A
Jun 29, 2009 | Lanier Office Equipment & Supplies
Scan in color
Press the "Scanner" button. The new screen includes a button for "Scan Settings". Press that button; the next screen offers, among many options, a pair of buttons for "Tex/Photo" or "Full Color". Make your choice, then press "OK" and you're back to the main scanner menu and you scan as normal.
Everything is easy, when you know how. <s>
Frank
May 07, 2009 | Office Equipment & Supplies
Brother mfc8860dn what do you mean by sort button
The sort button is one of the 6 buttons on the bottom right side of the control panel within the series of buttons in the COPY controls. When making multiple copies of documents with more than one page, it tells the MFC to sort the multi-page coping jobs into the correct order of the original document rather than the seperate individual pages.
Mar 07, 2009 | Brother MFC-8860DN Printer
Lanier copier 7313 AG
The clutches arnt too bad putting them in however... I own this model as a home copier but parts are hard to come by and to get a tech that knows how to repair is harder.
Sep 18, 2008 | Lanier 1205 Copier
95 people viewed this question
k24674
