Question about Lanier UNKNOWN
When I copy, document comes out backwards
I have a Lanier LD232c at my office. When I copy a multi-page document, the top page is on bottom and the bottom page is on top. How do I fix this?
    President:
  • 2,666 Answers
Put the last page in first and the first page in last.
Posted on Jul 08, 2010
How do I adjust print margin in service mode
I figure it can be done on the computer settings for the printer.
Jul 16, 2015 | Lanier Ld228c Ld232c Ld238c Copier Fuser...
Ld238c replace fuser
Its a maint. light, no need to replace unless quality problem. -Carl
Mar 22, 2014 | Lanier Ld228c Ld232c Ld238c Copier Fuser...
Xerox Copycentre C20: Copier doesn't scan top 1-3 inches of page. Happens intermittently. When this happens, it moves everything else on page to the top of the copy, cutting out what should be
The document feed rollers may be dirty/worn which is causing the paper to come into the scan area late causing your document cut offs. use a clean, lint-free cloth dampened (not moist) with water and clean the document feed rollers. Confirm they are dry then, try scanning multiple pages and see if they pull through without stalling. If they do, it's time to replace those rollers.
Aug 27, 2017 | Xerox CopyCentre C20 Black and White...
How do I change margin setrtings foe Lexmark P4350
If you are preparing to print a document that you have created in Microsoft Word, you may be concerned that all the text on the page will print exactly as you see it on your screen. This is not always the case. You can adjust your print margins to ensure that your text prints on each page exactly the way you would like it to appear.
Opening Your Document
Open your Microsoft Word document by double-clicking the Word icon on your desktop. If you do not see the icon on your desktop, then you can locate it where it is buried on your "Start" menu. Click "Start," followed by "All Programs." Then click "Microsoft Office," followed by "Microsoft Office Word." A new document will open on your screen. Click the "Office Button," followed by "Open." Scroll through the files listed, and double-click the one you would like to print. It will open on your screen.
Check Your Margins
By default, your page margins are set to 1-inch margins on the top, bottom, right and left of your page. You can check your margins or change them by clicking "Page Layout," followed by the "Margins" button.
Select New Margins
Select a different margin size, such as "Narrow," which indicate 1/2-inch margins, or "Wide," which indicate one-inch margins on the top and bottom and two-inch margins on the left and right. You also can select "Moderate," which indicate one-inch margins on the top and bottom and 3/4-inch margins on the left and right. Finally, you can select "Mirrored," which indicates one-inch margins for the top, bottom and outside. The inside margins are set at 1 1/4 inches.
Print Your Page
Print your page. Press "Control" plus the "P" button. The printer dialog menu will come up. Make sure that "All Pages in Range" is selected. Press "OK." If your printer cannot print your new margins, then a new menu will pop up telling you to adjust your margins.
I hope you find it very helpful. Best regards.
Aug 22, 2011 | Lexmark P4350 All-In-One InkJet Printer
hi you need to press the 123/user button on the top left of the display this gets you into setup press for the copier and here you will see the sections for paper and default setting you are looking for the duplex it will be set up tor top to top or top to bottom see which it is set on and change it to the other setting
Jul 08, 2010 | Office Equipment & Supplies
How do I clean the transfer belt on my Lanier LD232c (same as Ricoh Aficio 2232)?
The transfer belts on these generaly cant be cleaned if you know how you can just remove the transfer belt unit and take the cleaning unit ou this is positioned on teh leaft hand side just under the belt at the top there is screw take this out then press the small brown lever and and pull teh unit out carefully make sure you press the lever in as jif you dont you can damage the belt..vac this out and wipe the blade with a soft dry cloth.. if you are savy with the machine the main area to clean is the alloy or chrome roller at the top.. you will have to take the belt off to clean this.. the id sensors read off this to get reg and colour calibration right so it coulld cause problems if this is dirty..let me know if this helps or if you need more info..Good Luck A
Jun 29, 2009 | Lanier Office Equipment & Supplies
Brother mfc8860dn what do you mean by sort button
The sort button is one of the 6 buttons on the bottom right side of the control panel within the series of buttons in the COPY controls. When making multiple copies of documents with more than one page, it tells the MFC to sort the multi-page coping jobs into the correct order of the original document rather than the seperate individual pages.
Mar 07, 2009 | Brother MFC-8860DN Printer
Lanier copier 7313 AG
The clutches arnt too bad putting them in however... I own this model as a home copier but parts are hard to come by and to get a tech that knows how to repair is harder.
Sep 18, 2008 | Lanier 1205 Copier
Lanier UNKNOWN Logo
Top Lanier Televison & Video Experts
Electro Med Services...
Are you a Lanier Televison and Video Expert? Answer questions, earn points and help others
