Question about LG L196WTQ-BF 19" Monitor
How to replace LG L196WTQ-BF Computer light bulb
  • 11,361 Answers
Are you sure that the lamps (4) are bad and not the backlight inverter circuits.
Service manual: http://elektrotanya.com/?q=showresult&megnev=LG%20&megnev2=%20L196WTQ-BF%20&kategoria=monitor&kat2=schematics
Not all the LCD lamps can easily be removed, some of them you have the completely disassemble the screen to get the lamp asemblies out. Need to do voltage checking and caps inspection first, it should have 5vdc for the logic and 16~18vdc for the inverter circuits
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jul 09, 2010
Lg 1752s goes into power saving mode when pc is turned on
Hello Alan,
That is actually not power saving mode, the flashing power light indicates the power supply is not starting up correctly and keeps shutting down and trying again. This is a very common symptom of a failure of the capacitors on the power supply board. The L1752s uses the AIP0157 power supply board which is the same board the is used in several LG monitors such as the L196WTQ and L194WT. Here is a link to a repair guide for the L196WTQ that shows what capacitors to look for and replace on the power supply board to bring the unit back to life.
http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/
I hope this helps, if so please rate my solution.
BuddyMc
May 15, 2012 | LG L1915S 19" LCD Monitor
How to open a lg monitor 196wtq
Here is a link to a dis-assembly and repair guide that should get you going.
BuddyMc
Feb 14, 2012 | LG Computers & Internet
When I came home today the blue monitor light was on, but there was no picture. When I moved the mouse to get the monitor up, the light went out. I've tried unplugging it and plugging it into...
Here is a link to a repair guide for the LG L196WTQ. It sounds like you have a power supply failure and the guide shows how to open the unit, check the power board and then what to replace if you do find bad capacitors.
Problems like wavy or flickering picture, flashing power light, slow to display the picture or no power at all are all symptoms of a failed or failing power supply board.
BuddyMc
Jul 25, 2011 | LG L196WTQ Monitor
Monitor will not awake from sleep mode. Pilot light is amber when asleep. If the monitor is turned off pilot light goes from amber to off or black or nothing. Turning the monitor back on the pilot light...
That means your monitor is not receiving a signal from your video card.
A couple things to check:
*Make sure your cable is ok - unplug and replug the cable to see if it is a loose connection. Or try a different cable.
*Make sure your computer is not in sleep mode - Move your mouse or otherwise ensure your computer is awake and sending a video signal
*If you have another computer, try the monitor on the other system and see if it works.
Sep 03, 2017 | LG L196WTQ-BF 19" Monitor
How do i dismantle L192WS LG monitor ? please help
We have a full disassembly and repair guide for this model monitor posted on our site at:
I hope this helps, if so please rate our solution.
BuddyMc
Jan 01, 2011 | LG L196WTQ-BF 19" Monitor
My monitor, Flatron L196WTQ-BF, just quit working one day. I have tried to get it to work, checking power, moving to different computers, etc, but it won't light up at all. The on/off switch remains dark...
It sounds like you have a failure in the power supply board. We have a free repair guide posted on our site at: http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/ that should get you back going again. The guide shows you how to remove the case and what to look for to identify the problem. Look it over and see.
CCL_Tech
Corporate Computer
www.ccl-la.com
Sep 04, 2010 | LG L196WTQ Monitor
LG L196WTQ monitor just quit working. won't turn
Look in the power supply section first for bad caps, post back what you find inside, pictures will help a lot to guide you through, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 24, 2010 | LG L196WTQ Monitor
LG Flatron L196WTQ-BF Monitor will not power on
Here is a link to a How To on this monitor (and similar) they offer cheap parts as well.
http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/comment-page-1/#comment-136
Nov 12, 2009 | Computers & Internet
My LG L196wtq-BF went black this morning. No light on the power switch. How do I get the back off the monitor?
We have some dis-assembly guides on our web site at: www.ccl-la.com/badcaps.htm There are not for your exact model but they should help.
Buddy
Corporate Computer
www.ccl-la.com
Aug 31, 2009 | LG L196WTQ-BF 19" Monitor
LG Monitor L196WTQ-BF ..weird image stuck on desktop??
The "image" you are talking about: Is it there when the monitor is off? If so, you are correct--it's broken and must be replaced.
Is it on the desktop when you start the computer and does it stay there no matter what program you are running. If the answer is "yes" then I'm afraid the answer is the same.
Jul 15, 2009 | LG L196WTQ Monitor
LG L196WTQ-BF  19" Monitor Logo
378 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
