Question about Premiere Ranges SCK34 Gas Kitchen Range
My oven gets too hot. flame doesn't shut down
I have a smaller size stove due to the amount of available space. No matter what temp I set it to it just keeps getting hotter and hotter. I set it to 350 and waited for it to heat up. When I went ot put my brownies in it seemed to hot so I used my thromometer and seen the temp was 425. I figured the thermostat was off so I reset the temp to 250 and when I checked again it was hotter still. no matter what I did the flame never shut down. Would this be the thermostat causig the problem ???
    President:
  • 1,430 Answers
The problem is the temperature probe has failed. This is inexpensive usually and easy to replace. This link should help
http://appliancehelponline.com/oventempprobe.html
Posted on Jul 08, 2010
Need to adjust down the amount of gas coming into oven
I would advise do not use like this as it could be getting too much pressure in the system or the burners could be burnt out. I know of a house that burnt because of a problem like this and they kept using the stove. I don't know the name of the gadget but please get it checked out. there is a valve that is preset at the factory
Jan 17, 2016 | Kitchen Ranges
I have a new (less than a year) Brown gas stove that has been installed and running reasonably well until recently: the problem is that the oven pilot always goes out once the oven is turned off. In the...
It may be the thermocouple assembly...this is a device that senses that the pilot is in fact lit...it looks like a copper tube with a smaller tube coming off of it and the smaller tube goes to the gas valve and the larger part of it sits just above where the pilot flame is..this allows it to get hot telling the valve that there is a pilot and that it is ok that the valve turn on providing the gas to start oven..if this part goes bad then the pilot will not stay lit..themocouples are available from most hardware stores and are usually universal
Jan 22, 2011 | Ovens
Having just converted my Vulcan Endurance G36L Range from Nat. Gas to LPG Using the following parts recommended by Vulcan : New 1/2 psi pressure regulator, 6 size 51 hood type top burner orifices,1 size...
The oven safety valve has to be cranked down for propane.themobilian_815.jpg
Get a good fitting wrench and tighten this spud down and open the air shutter on the burner.
This video shows how to tackle a crank down and flip type LP conversion whilst yours might be a bit more fancy it still must be adjusted like any other stove:
Jan 10, 2011 | Vulcan G36L Gas Range
Heard popping noise and circuit to stove blew. could not set time or oven temp when reset breaker
Hi
Sounds like your oven heater failed. Not sure if its a fan oven or static type. If you hear a fan inside the oven then its classed as a fan oven
Nov 16, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
Xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Electric oven. temperature problem
Change the temp sensor.
Feb 21, 2009 | Maytag Ovens
Simpson 2001 series upright electric stove oven does not get hot only gets warm
It could be the oven element (behind the cover plate in the back of the oven), or the fan not blowing the heat into the oven.
Aug 19, 2008 | Ovens
Too hot
Hi, not sure if you ever received a reply, but there is a setting known as "bypass" on commercial thermostats, if you took the cover off to replace it, you can access this screw, it is part of the body of the thermostat, either to the left or the right of the knob shaft, usually has a "B" stamped, or molded into the body. What this setting does is when the thermostat reaches temperature, it would normally close, shutting off the supply to the burner, thus the temp would begin to fall, by the time it opened back up, the temp would have fallen too much, causing a large temp swing. The bypass setting opens or shuts a passage that "bypasses" the thermostat main valve, keeping just a little burner, making the swing, or fluctuation smaller. So, you probably have a setting too big, causing your bypass flame to be too big, raising, or keeping the temp too high, try turning it in (cw) to lower it slightly, a small turn makes a huge difference, so go easy. Hope that helps, and thank you.
May 08, 2008 | Bakers Pride Y-600 Gas Single Oven
Premiere Ranges SCK34 Gas Kitchen Range Logo
171 people viewed this question
Top Premier Kitchen Ranges Experts
Paul Carew
ray gallant
Terry
Terry
Are you a Premier Kitchen Range Expert? Answer questions, earn points and help others
