Question about Sharp AR-5316 Advanced Digital Imager Copier
PAGE SETUP SITTING - Sharp AR-5316 Advanced Digital Imager Copier
My machine frequently log and show the copier swtich capital H and do not function of any other swtich . How can repariing the xerox machine properly. thank you. Debasish
Posted on Jul 13, 2010
Where is the IP address located on my Lexmark s515 printer
Printing a network setup page
A network setup page lists the configuration settings of the printer, including the IP address and MAC address of the printer.
  1. Load plain paper.
  2. From the printer control panel, navigate to: button_home_0.jpg > Setup > button_select_0.jpg > Network Setup > button_select_0.jpg > Print Network Setup Page > button_select_0.jpg
Nov 30, 2013 | Lexmark Office Equipment & Supplies
How do i set the voicemail for a avaya 518-457-701
Refer To Voice sitting manual ... Check for Menu, Setup, to change Date and Houre and setup Utility
Sep 28, 2010 | AT&T Lucent Merlin SP 34 Phone
Only printing last page of all documents sometimes says printing but doesn't even print
please your open the programmes and open the page
and give a control p comand and select to page and apply print
and s
econd time you go file menu in printer page setup is open
and even page select and setup ok
and third time you go my computer in printer open
and penter setup page setup and youyr printer select and apply.
ok
Sep 15, 2009 | Lexmark X4690 Wireless InkJet Printer
My epson rx420 only prints the left hand side of any document ??? Can any one help please . many thanks
have you set the page setup in document is same with page setup at print setup. Some new epson printer use paper sensor to measure the paper width. If page setup wider than actually paper inserted, the printer will print only half page. example : Your document 10 cm wide, page setup 20 cm, and you insert 10 cm paper wide. It will print only half of 10 cm, 5 cm.
Jun 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
Date received at top of page.
you cant you are going to have to go get a time/date stamp machine and put each one through it
sorry i couldn't of more assitance but your machine does not allow for that feature
May 04, 2009 | HP LaserJet 3050 All-In-One Printer
Color prints not working
have you gone to file> page setup>printer>properties>paper/quality hope this helps regards Jim
Jan 22, 2009 | HP DeskJet 990cxi InkJet Printer
Router will not reconize 3rd computer
It is possible that the router has a wireless security enabled into it. The laptop needs the security key for it to connect to the wireless network. You can check the security enabled in your router from your router's User Interface page.
To access your router's page; launch IE from a computer that is working through the router. Then on the address field, type 192.168.1.1. It will open a window asking for a username and password. The default password to get into the router's page is admin.
Then, once you're in the router's User Interface, the main page that will open is the SETUP, beside it is WIRELESS tab. Click on it, then verify the wireless network name or SSID. Whatever name configured on it, is the name the laptop should connect to.
Then, there is a subtab under the main tab WIRELESS. The sub-tab is called, Wireless Security. Click on Wireless Security tab and then look for the netwok key enabled. Take note of the key which your laptop will be neeeding.
Hope this helps!
Nov 28, 2008 | Linksys Wireless-G WRT54G Router
I am trying to install an HP 7460 wireless printer to my HP cpu via a linksys router. My password for the router is 7 letters, and the printer says it has to be 8 letters. How do I change the router...
When accessing the router’s web-based setup page, a log-in screen will appear asking for the router’s password. The router’s default password is “admin.” You should change the password for security purposes.
The router’s password must be changed to:
  • Prevent unwanted users from accessing the router’s web-based setup page.
  • Enable Remote Management.
The router’s IP password can be changed by:
  • Running the router’s setup CD.
  • Changing it on the router’s web-based setup page. For instructions, please follow the steps below.
Changing the Router’s Password
Step 1:
Access the router’s web-based setup page.
NOTE: If you are using Mac to access the router's web-based setup page.
Step 2:
When the router’s web-based setup page appears, click Administration.
Step 3:
Enter the new password on the Password and Re-enter to confirm fields.
Sep 26, 2008 | Office Equipment & Supplies
I am trying to use my scanner for the 1st time and I scanned 24 pages which took quite a long time and at the end my computer advised that these pages are now sitting in c:\documents &...
I guess that was the way the unit is setup and programmed. I expected to have the scanner setup to automatically send the documents directly into my e-mail, as this unit is in my home office and that would be the only place I would ever want them to go. Then I could forward them on very easily. I had to attach every page of the 24 pages separately into 3 e-mails. So I did accomplish the task. It would be nice to adjust it for future scans.
Thanks anyway:o)
Bernice
250-616-8760
Jun 27, 2008 | Samsung Office Equipment & Supplies
Printable Area
Hi, If you open Word and go to "File" and "Page Setup" and choose the "Paper" tab you can change to many different paper types.
See how you go and let me know.
Nov 21, 2007 | Epson LX-300 Matrix Printer
Sharp AR-5316 Advanced Digital Imager Copier Logo
29 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
