Question about Maytag Performa PAV2200
How does the belt go around the barrel of the dryer and the little wheels under it?
    President:
  • 1,430 Answers
The dryer is viberating more that usual. I opened and checked the rollers under the barrel. They turn and don't feel loose but the entire moving parts assembly around the barrel is visibly shaking more...
I just had to replace the rollers and the front and back seals on my dryer because it was doing the same thing. You might also replace the belt while you are in there, if it looks worn. Mine runs good now.
Mar 28, 2011 | Dryers
Changing dryer belt on kirkland/whirlpool dryer took apart dryer but dont see where belt suppose to mount.
Hello. The belt goes around the tub and the tension pulley. In fact, it is always a good idea to replace both the belt and the idler/tension pulley at the same time. J.
If you want a schematic go to searsdirect.com and enter your model number. J.
Jun 27, 2010 | Whirlpool LER4634J Electric Dryer
What is small blue plastic wheel?
The small blue wheel, just next to the Motor, is the tension pulley, your belt should go around it, before going around Drum
May 31, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer
remove the 2 kick panel screws near the front panel by the floor swing the front panel upward and the top clips will release,then remove the 2 hex head screws under the top cover then swing the top cover up like a car hood and secure it so it doesn't fall and pull wires out,then remove drum and restring belt and then around the drum then around the tensioner and reverse the above procedure
Apr 15, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I have an older kenmore 70 series dryer. the belt broke and im trying to figure out where the pulley is supposed to go and how the belt is supposed to go
If you are referring to the tension pulley that keeps the belt tight on the drum, it is common for it to come loose when the belt breaks because there is no longer any tension holding it in place. Just follow these steps to reinstall:
1. Make sure the drive belt is looped around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place with your left hand, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H.
If you have any questions, please post back with your MODEL NUMBER (located on a nameplate around the dryer door opening) so that I may be able to confirm your dryer configuration. I hope this helps you.
Feb 24, 2010 | Kenmore Dryers
Need belt diagram for Performa PDET920AYW dryer
Flat side of the belt goes agaist the drum. The diagram is on the new belt
Aug 08, 2009 | Maytag PYE2300AY Electric Dryer
Belt/Drum Noise
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 15, 2009 | Asko T761 Electric Dryer
Dryer turns on - we hear the motor going - but the clothes do not tumble - the barrel isnt turning
Hi welcome to Fixya
You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
Thank You For Useing Fixya
PLEASE RATE ME
May 17, 2009 | Whirlpool LEQ9858L Electric Dryer
How to replace the belt for a whirlpool ler5620kq1 dryer
It is a very tricky task to put this belt on but I think I can work you through it. When you get the belt around the drum and get to the idler, push the belt under the idler wheel and through the forks of the idler pully assy. attaching it to the pully on the motor. Tension should be on the idler pushing the wheel up toward the drum. Hope this helps.
Apr 01, 2009 | Whirlpool LER5636P Electric Dryer
Putting dryer back together
from front with belt around drum ..gather slack and push under idler and around motor pulley right to left...recommend doing it before reinstalling front place rollers on front panel under front lip of drum and lift ..easier than trying to reach under front panel and will a little more slck in belt
Sep 13, 2008 | Kenmore 63012 Electric Dryer
Washing Machines Logo
67 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
