Question about Dell OptiPlex GX280 PC Desktop
SATA Hard Drive Type The Dell Optiplex GX280 Takes?
What SATA Hard Drive Type Does The Dell Optiplex GX280 Have?
Will A 'Western Digital Caviar SE WD1600JS 160GB SATA II' Hard Drive Work In It?
It It SATA 1 or SATA 2?
Thanks In Advance.
P.S. I Have 13 That Need Hard Drives, They Have P4 HT 2.8Ghz And 3.4Ghz CPU's (mixed)
  • 1 more comment
  • Nathan
    Nathan Jul 08, 2010
    NEW QUESTION!!!
    how do you update the bios?
    (i have never had to do it before)
    do you burn the update to a cd/floppy and boot from it?
  • Nathan
    Nathan Jul 09, 2010
    @Leecom72
    I Just Checked All Of Them, The BIOS Versions Range From A00 to A08, i have been on dell's website and can't find the bios update. also some of them don't have the option to boot from a usb device.
    I Have Resorted To Using A SATA DVD+/-RW on the hdd SATA port And 160Gb IDE Hdd on the CD IDE connector! lol
    P.S: i just won a hdd on ebay, '160GB Western Digital Caviar SE WD1600JS' it says it is SATA 2 but will work SATA 1 with a jumper???
    if not i will just update the BIOS as you said.
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?V...
  • Nathan
    Nathan Jul 20, 2010
    it does work and i havent even had to change any jumpers. thnx
  • Dell Master
  • 4,806 Answers
It makes no difference providing the computer motherboards support SATA interface.
SATA 1 and 2 drivers are in the BIOS. If all the computers have SATA 1 you can upgrade the BIOS to latest version via Dell's support website.
Regards.
Posted on Jul 08, 2010
Testimonial: "thanks, ill look into that. how do you update the bios? (i have never had to do it before) do you burn the update to a cd/floppy and boot from it? Cheers again!"
  • 3 more comments
  • Lee Hodgson
    Lee Hodgson Jul 08, 2010
    It would depend on the file type that Dell provides. They can come in different formats. Some BIOS updates require you to format a floppy disk or a USB drive that requires you put the files on them or a Windows based update like an .exe file.
    Dell's website will give you all the information on what to do and how to do it either on their website or a text file which will explain it.
    When you download the BIOS update the information on how to update it will be provided with that. Just make sure that you are downloading the correct BIOS update for the particular computer you want to update.
    If you have a different model Dell then make sure you download the BIOS update for that model. If all the computers you have are the same model then all you need to do is download one file and use that to update all the computers you have.
  • Lee Hodgson
    Just another quick note:
    SATA hard drives don't have jumper settings on them, only IDE drives have them. You have to set the boot order in the BIOS.
  • Lee Hodgson
    Lee Hodgson Jul 09, 2010
    Yes it should work.
  • Lee Hodgson
    Lee Hodgson Jul 20, 2010
    I told that it would work. A SATA 2 drive in a SATA 1 board just makes the SATA 2, SATA 1. Think of it as a downgrade for the drive.
    Regards.
  • Bob Sloan
    Bob Sloan Aug 31, 2010
    SATA drives do indeed have jumpers, but they aren't for configuring slave/master or Cable select options. They are used to change the data transfer rate from 1.5 to 3.0 gb per second.
    This however doesn't apply to your particular problem unless your hard drive wont read due to the higher rate of transfer relevant to your hard drive vs the data input capability of your SATA bus.
  • 748 Answers
They came in different flavors, so the easiest way would be to look inside and discover if it has SATA connectors or ATA only.
SATA and SATA2 are compatible, you can connect a SATA2 disk to a SATA-only motherboard, usually there's a special jumper on the HDD to set the mode.
Testimonial: "1: i know they have sata hard drives, i just bought 50 dell desktops that needed hdd's & memory. 2: Thanks!, i didnt know that sata hard drives have jumpers to set sata 1 or 2. Cheers :) (i only realy used ide hdd's, only ever gor the odd sata + that was before they started with the new sata interfaces) thanks again! :)"
Just installed a new hard drive in a Dell Percision do I need jumper settings for the second drive
depends entirely how they are connected. you have posted this under SATA har drive, sata hard drives do not require any kind of jumpers.
Dec 06, 2010 | Western Digital Caviar SE WD800JD SATA...
I bought a Dell Optiplex 745 with no hard drive. I bought a second hand WD800JD SATA hard drive with no CD's and installed it. The computer does not recognize it so I cannot load an OS. Can you help?
make sure that the leads are in there correct slots
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Dec 04, 2010 | Western Digital Caviar SE WD800JD SATA...
I want to set this up as a slave drive in my Dell Inspiron. What are the jumper settings to do this
this is a SATA HDD, so to make it a Slave drive, it will need to be on the SATA-1 or later controller (The Boot Drive should be Sata-0)
Mar 19, 2010 | Western Digital Caviar SE WD2500JD 250 GB...
Western Digital Caviar SE WD800JD SATA Hard Drive Boot: Couldn't find NTLDR could this be bad drive installed xp a couple times now works ok but when i shut it off Couldn't find NTLDR comes up
Yes it looks like a Hard drive problem.
This error means that NTLDR is missing somehow from your computer,hard disk problem usually or virus.
You can go to that page and follow the instructions exactly as he says and will not have to install windows over and over again
http://www.tinyempire.com/notes/ntldrismissing.htm
Jan 02, 2010 | Western Digital Caviar SE WD800JD SATA...
Solve Bad sectors Problem?..????
irst connect your drive to computer then check its drive letter meand c: or d: or e:
then go to start > run> then type "cmd" then go to drive letter then type "chkdsk /r"
then it cheks your harddisk for eror.
Jun 09, 2009 | Western Digital Caviar SE WD1600AAJS 160...
Installing SATA WD 160 GB Hard Drive
You may not have a SATA system - Western Digital has the other type of hard disk drive available.
Apr 07, 2008 | Western Digital Caviar SE WD1600AAJS 160...
Dell OptiPlex GX280 PC Desktop Logo
1,820 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
