Question about Sony KP-43T90 43" Rear Projection Television
Picture is blurry and i see green and pink shadows
  • 62 Answers
You need a light engine. please contact Sony and see if your still under the recall for that model.
Posted on Jul 08, 2010
Picture is very bluury before that it had 3'd like lines in pink and green
The convergence IC's are bad. "red and green lines" For the blurry,You coolent needs to be changed. The blue and green crt usualy turn brown and milky.
Sep 12, 2009 | Philips Magnavox 9P6034C 60" Rear...
Blurry picture images shadowed
Your filter capicators are proberally damaged, get a technician to have a look ate them, alsoe you might want to try your image adjustment.
Jan 23, 2008 | Hitachi 50UX57B 50" Rear Projection...
Shadowing and blurriness
needs a convergence board repair, not too hard to fix if you are handy with a soldering iron.
get the 2 convergence chips for this model @ partsstore.com
Mar 19, 2009 | Hitachi 50FX30B 50" Rear Projection...
Sony KP-61HS10 st start up blurry gets better the longer its on
You have loose solder connections on the convergence amps.This is a common problem caused by heat within the unit.If you can solder you can fix it.
Jan 12, 2009 | Sony KP-61HS10 61" Rear Projection...
Sony rear projestion TV has blurry picture.
sounds as if your convergence needs to be set. either through the menu on the tv or remote you need to get to the convergence set screen and you need to line up the crosshairs. this usually happens when the tv is moved or bumped.
Dec 31, 2008 | Televison & Video
Colour alignment off
Need to replace the convergence IC in the green vertical circuit. Check the 3.9 ohm resistors located in front of the IC.
Nov 02, 2007 | Samsung HCN436W 43" Rear Projection...
Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Oct 31, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-43T90 43" Rear Projection Television Logo
102 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
