Question about Gateway NV7915u Notebook
Touchpad doesn't respond - Gateway NV7915u Notebook
    Master:
  • 497 Answers
Go to this Gateway Webpage and Do any/all Updates related to you system.
http://support.gateway.com/support/drivers/search.asp?st=pn&param=NV79
Posted on Jul 08, 2010
Buttons on microwave
testing every step and fix it. God bless you see the diagram attached
Microwave Buttons Don't Work
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_23_47_pm.gif1_24_2013_5_24_54_pm.jpg
Jan 24, 2013 | Goldstar MV-1501 Microwave Oven
Dot s touchpad not responding
Use an usb mouse to select control panel and then select device management. From there you need to select the mouse and from there select the mouse and right click on it. Select to uninstall the device. Then close all screens and shut down computer. Unplug the usb mouse and restart the computer. If after it completes loading and it doesn't work the you will need a new touch pad. But if it does work it means windows had an corrupt update which caused the problem. Thanks Igor!
Sep 29, 2012 | Computers & Internet
My Beko MW5104 is frozen and does not respond to any settings. It is permanently on at spin/end with the green light on. I can switch it on and off. I have unplugged it from the mains and switched it off...
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
My touchpad doesn't work on my aspire one D255 netbook. The wireless mouse works but the touchpad doesn't respond to any touch. How can I make the touch pad work? Is there a function?
Hi!
If the touchpad worked well before and suddenly doesn't work any more, it is most likely it was stopped by pressing the key combination FN F7. To be sure please press the same combination again and check if it works.
If it still not work, please check if the touchpad drivers are installed on you netbook.
To do so, please open device manager. (opening the device manager could be done in more different ways, e.g. click START button and, depending on your operating system enter devmgmt.msc in the Run box for windows XP or in the Search programs and files box in windows 7).
Now, under mice and other pointing devices you should find your touchpad.
If the touchpad is not listed in device manager, drivers for it have to be installed.
Drivers for your netbook's hardware are on the acer support page.
Hope it helped,
Bogdan
Aug 28, 2011 | Computers & Internet
Touchpad stopped working cannot move pointer arrow around screen
Just check for the key combination on your key board (ex. Fn + F4 or F5..depends on the what key was designed for the touchpad), the touchpad might be locked.
If it is not locked, reinstall the touchpad driver, but it this still doesn't work, boot to Safe Mode to check if it does. Touch pad still not responding in Safe Mode would mean hardware failure.
Hope this helps.
Jun 26, 2011 | Computers & Internet
Touchpad not working acer aspire 5732Z
Hope this helps.
Jun 16, 2011 | Computers & Internet
My samsung n148 touchpad is not working, i updated the drivers, but still not working... pls help....
Check if you accidentally locked the touchpad through the keyboard. If it is not locked, try to boot to Safe Mode and check if it responds, if not, just try to reinstall the operating system. If it still doesn't work then it needs repair.
Hope this helps.
Jun 03, 2011 | Computers & Internet
On my acer 5742-7645 my touchpad has stoped working?
Just check for the key combination on your keyboard (ex. Fn + F4 or F5..depends on the what key was designed for the touchpad), the touchpad might be locked.
Hope this helps.
May 27, 2011 | Acer Aspire 5742Z-4200 Notebook
Touch pad is not working?
Hope this helps.
May 25, 2011 | NEC Versa FX Notebook
My HP Mini 110 touchpad mouse is frozen. Pls help
Hello
If the touchpad does not responds then make sure that the touchpad lock switch (just above the touchpad) is not turned off.
If this doesn't work,Restart the computer and repeatedly tap the F8 key (you need to press F8 before windows starts to load) You should see a menu "Select Last Known Good Configuration" and press Enter.This should solve the problem if not,try to download the synaptics drivers for any of the Mini 1000 series laptop edition as you have a Mini 110. It does works.
Apr 12, 2011 | HP Computers & Internet
Gateway NV7915u Notebook Logo
288 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
