Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirpool whir;pool 1998 side by side. Fl home only used 6 months a year, compressor not working, fan is, not hot to touch, no humming or clicking noise. just dead any idea's thanks
  • Anonymous Mar 31, 2014
    Hot point refrig 1998 has side handles .
    Genius:
  • 1,073 Answers
Check the overload and relay on the compressor if the fan at the bottom is working then it sounds like the relay overload combo or the compressor is the problem
Posted on Apr 19, 2008
Ive got power, hot and cold to my existing pump and shower, but the pump doesn't start, just makes a whirring noise.
Above Ground Pool Pump Won't Start or is Humming & How ...
? 6:16
https://www.youtube.com/watch?v=RH78q36liks
Apr 15, 2014 - Uploaded by Above Ground Pros
Above Ground Pool Pump Won't Start or is Humming & How to Fix It ... Pool Motor - Humming-Loud Noise ...
How to fix your pool pump from humming - YouTube
? 2:43
https://www.youtube.com/watch?v=3v2v6aDDq9A
Mar 25, 2013 - Uploaded by James Hayward
Do you have a pool pump not priming (pumping water) andmaking a humming noise ... not only give a ...
pool pump makes humming noise and does not pump - Trouble F
Dec 08, 2015 | Home
This unit was purchased new 61 months ago. First instance of any problems, ever, today it seems food isn't being kept frozen solid. We suspect the compressor is having a problem. There was no sound...
Yes it is a very big concern.It sounds to me like your condenser is dirty and the compressor gets hot and goes off on overload.You can tell by putting your hand NEAR the compressor.Be careful as the compressor can be very hot
Sep 14, 2010 | Frigidaire Freezers
Fridge humming and hot to touch between fridge/freeze (side-side)
It sounds like your compressor is going bad. The part you mentioned being hot is normal.
Jun 25, 2009 | Refrigerators
Whirlpool side-by-side won't get cold, compressor clicks on-off.
Sounds like the start relay OR the compressor is no good. Have a service tech look at it, because there may be a capacitor in the circuit, which could be dangerous for you to fool with.
May 28, 2009 | Whirlpool Refrigerators
Comppresor stoped working
Go to the back of the machine and take the lower rear plate off. Taking this plate off will expose the compressor. Check to see the compressor is humming or is hot. If niether take off the relay (located on the side of the compressor) Shake it and if a loud rattling noise is heard replace it. If no rattling noise or the compressor is hot or humming then the compressor is bad.
Jan 15, 2009 | GE Profile PFS22 33" Artica French Door...
Frigidaire humming freezer not cold enough
For the 25 year old freezer: a replacement compressor of the same BTU rating can be obtained and used as a replacement BUT at 25 years old I DO Not recommend the expense of a compressor replacement.
To the owner of the six year old freezer. The buzzing noise is more than likely the compressor cycling on its overload protector. This is an indication that the compressor has failed. In this case also I do not recommend replacing the compressor. If it was in warranty the manufacturer would bear the cost. Replacement compressor come with a one year warranty.
Sep 01, 2008 | Frigidaire FRS26R4A Side by Side...
Whirl pool side by side refrigerator problem
It looks like the Capacitor Start Relay is failing.  It is located either on the starter Relay or mounted on the side of the compressor compartment.  It sould have two wires on it, one orange and the other probably white.
Oct 22, 2007 | Whirlpool ED2FHEXN Side by Side...
Compressor and water are hot!
re-charge the freon. this will cool it down.
May 31, 2007 | Hotpoint HSS25GFP Side by Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
60 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
