Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
Wd connected with a usb to laptop, not responding, pls help ,steady white light on
  • Rockme
    Rockme Jul 08, 2010
    If it is the first time of use try formating the portable drive but bear in mind that formatting will erase everything on the drive. If you have things on the drive which you dont want to lose try restarting the computer as this might be the cause. If this does not work try a different usb port as the particular usb port might not be responding. Hope this has been helpful. take care
  • 748 Answers
Try it in all the USB sockets available in your laptop. Try it in a desktop computer. Try a different cable.
Sometimes the USB connectors in a laptop are unable to deliver the full current rated in the USB specifications, and the drive can't start.
Also cables sometimes add to the problem, as they have too thin wires causing too much voltage drop.
Posted on Jul 08, 2010
I dropped my WD Passport 750gb drive. When connected the light comes on and blinks at times, I can also feel the disk spinning, and it makes some sounds like 'sparks'. After a while (3-5 minutes)...
Test the drive for problems using Data Lifeguard Diagnostics for WindowsPlease refer the link below:
http://wdc.custhelp.com/app/answers/detail/search/1/a_id/940/c/130/p/228,195,255
hope this helps.
Feb 11, 2013 | Western Digital 750GB WD My Passport...
WD 1TB light is on but not blinking and can not be read
You can try to open the hard drive cabinet and to put the hard drive into another cabinet in order to see if the problem comes from the unit itself
Feb 05, 2013 | Western Digital 1TB WD My Passport SE for...
I am not able to connect my passport to my pc..lead light is steady n it showing in my pc like device is malfuctioned....wht to do ,,plz help asap
Try each of these methods step by step if solved in any step get backup ASAP
the good news is: if the LED is ON you may have a chance
1.Use Minimal cord, detach all other USB's, check your power2.Turn off power options3.Try Restarting your system4.Carefully Try system restore3.Download & update Firmware software from WD website4.You may need to Install SmartWare_Windows_Upgrader first5.In any step if the hard drive was recognized back up your data immediately6.if none of above You will need experts having PC3000 to get your data back
the bad news is that: if the LED is OFF or PC3000 doesn't recognize your hard drive you may need a new exactly the same hard drive with the same SN to replace it's board to get your data back.
unlike other brands which use laptop hard drives, that can be plugged into a PC directly, WD uses it's own board with access services on the hard and if the board is damaged you may have a serious problem.
this is a problem I have been through.
unfortunately the "lovely WD my passport" is Totally Not Reliable and you can not count on it.
May 01, 2012 | Western Digital My Passport Essential...
When I plug my 1TB WD external hardrive into my laptop the light with the lock on it lights up and my laptop doesn't respond to it at all.
It says it is password protected...
U need to unlock the HDD from the computer which was installed initially...
U need to unlock the drive with the help of the password that is used in the software supplied along with it....
Dec 08, 2010 | Western Digital My Book Essential 1TB...
Please tell me what wrong with my WD passport, it work normal when i connected it to computer, but when it is connected to laptop, it does not work, it does not get any power (no light indicated). Thanks
USB ports carry electricity, as well as data.
While the USB ports on your desktop are OK, the USB ports on your laptop are not sending enough voltage/amperage to power your device.
There exist 'Y-cables' that connect to TWO USB ports on the laptop, and draw power from BOTH ports, to push more power to the device. Try such a cable.
Oct 28, 2010 | Western Digital WD Passport 250GB Portable...
Western Digital Essential 1TB flashing white light & not responding. When you plug it in it you get a solid light, it spins for about a minute to two minutes & then the white power led starts...
hi i had the same problem, this is what i did. turn off the power supply and smack it about a bit then try it this should work!
i swear it worked for me, i think my kids must have dropped it which stuck the drive smacking it realised it.
Jun 22, 2010 | Western Digital My Book Essential 1TB...
WD My Book 1TB Ethernet seems to hang my USB ports on my notebook
Update your firmware, i had the same problem, i updated the firmware and everything works fine now.
Jul 04, 2009 | Western Digital Computers & Internet
Steady light on abs and airbag montana 1999
hi again thank u for responding to my email..i did bring my van to the shop and they found out that i need a new break pad..and im hoping that is the only problem..once again thank u
Jun 17, 2009 | 1999 Pontiac Montana
Linksys wireless broadband router and wireless access point
Hi I would love to help you with all the resources and knowledge I have, however, this would require online chatting kind of. You either reach me using the live chat feature of Fixya or just add my msn id in your messenger : sandeepbakshi@hotmail.com. Whenever I am online, I would assist you. Again, if the above given suggestion is not possible, please give me the following details: 1. exact model no (on the bottom panel) 2. firmware version (if possible) 3. no. of hard wired PCs (directly connect) 4. No of wireless computers 5. ISP 6. any other device connected to the router 7. status of internet on the hard wired PCs 8. status of wireless computers 9. The status of lights on the router (dont forget to specify the labels on top of the lights to make things clearer) thank you
Mar 10, 2007 | Linksys Wireless-G WRT54G Router
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
241 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
