Question about Philips Magnavox 27MS343S 27" TV
My tv want turn off unless you unplug it from the outlet good picture everything else want shut off with TV or the remote
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 117 Answers
It has a bad trans. or chip
Posted on Jul 09, 2010
Why does my sharp tv 32k-x1000 picture turn offand wont come back on unless i unplug it then replug in outlet
Main system control memory IC fault. Replace it.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 28, 2014 | Sharp 32K-X1000 TV
Conia plasma.no buttons work on the tv and the picture does not appear when you turn it on.it shut of one day.the aerial works and the tv has power.
How long have you owned the television. What is the exact model of the television. Once I have more information I can help you further.
Thanks,
Lee
Aug 26, 2008 | Televison & Video
My tv is not working right with picture.
Press the TV button on the remote, make sure the TV is plugged in, check the electrical outlet to make sure it is live if the TV does not turn on. If these actions do not solve the problem, press the Power button on the front of the TV. If the TV turns on, replace the batteries in the remote control and reset it by pressing the number 1 button for 60 seconds. If necessary, reprogram the remote.
Unplug the TV for two minutes, then plug it back in if the buttons on the remote don't work. Make sure the remote is in TV mode.
Change the settings on the sleep timer if the TV turns off unexpectedly. Unplug the TV and wait five minutes before plugging it back in if necessary.
Check your antenna connections and cables if the sound is okay but the picture is poor. If all the connections are good, adjust the sharpness function.
Jul 21, 2011 | RCA 20F512T 20" TV
Lost picture. When using main power button, the
Tries unplug,replug the tv an hour later might work.But this a temp.fix,must replaced the backlight video board sooner or later.
Dec 22, 2009 | Planar PDP-42BK 42 in. Plasma HDTV
LCD TV is hooked thru cable box. When you use the
Try this (may not work):
1. UNPLUG power from TV at wall outlet.
2. Turn ON the TV (with no power cable plugged in).
3. Plug power cable back in (at wall outlet)
4. Turn ON TV (don't use remote this time).
Hope this works!
Sep 03, 2009 | Televison & Video
TV power light comes on but no picture/no sound
chip on ic board repair shop might replace it and reprogram if the tv is worth the fix
Feb 05, 2009 | RCA Televison & Video
Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
Jan 25, 2008 | RCA HD56W58 56" TV
TV turns itself off after a few seconds, no picture at all
As far as fixing goes, you might as well get a new TV... Unless its a LARGE EXPENSIVE HOLY $%^# TV, It will cost more to fix, than to just buy a new one, unless its under warranty, which being an older model as that (or so im reading) It may not be covered.
Try unplugging the TV, and while unplugged, hold down the power button for a full minute (yes, with the plug NOT in the wall) after a minute, plug it back in, and try. Its a hard reset. If it still does not work, and you've tried different outlets, It's probably a repair issue, and you'll need to get someone to fix it, or just junk it :-/
Nov 11, 2007 | Sylvania SST4322 32" TV
Tv won't turn-on
ITS THE PICTURE TUBE ITS BURNT OUT - OR THE GAS HAS LEAKED OUT ANYWAY U NO LONGER CAN USE IT
Aug 22, 2007 | Hitachi (3223424A)
Tv cycling on and off
Phillip you have a problem in the main power supply or in the High voltage shutdown circuit. Now the longer you wait to have this fixed the more its gonna cost ya Unless your a tech then get a schematic and measure the voltage on the hv shutdown pin on the video junglke ic when the set shuts down If the voltage at the time of the shutdown sodent spike up then you know your problem is in the power supply. Good luck
May 27, 2006 | Sony Grand WEGA KDF-50WE655 50" Rear...
Philips Magnavox 27MS343S 27" TV Logo
46 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
