Question about Sharp CD-BA150 Shelf System
CD Player returns NO DISK code
A friend sent me a home recorded CD. I put it on and got teh message TOC CD. Since then, the CD player will not recognize commercially bought CDs and will not play them, returning a message NO DISC.
The system is useless and will only play Cassette tapes. How do I get it to "read" commecial CDs?
Willow Arune
  • Willow Arune Apr 19, 2008
    When in doubt, restor to primitive means...
    Thinking abou this, I thought that the problem started with a home recorded disk. The TOC, I found from the Web, reffered to TABLE OF CONTENTS. A home disk might not have this. So I removed the unit from the shelf and - upsidedown, tapped the outed cover. Hit, really,hard enough to rattle things.
    The sound you might hear behind me is the Paris Swing of Django Reinhardt playing nicely in the background, on a CD in the CD player.
Had similar problem, first things first.........clean lens with isopropyl alcohol on a Q-tip. to do this, you will have to remove cover and likely the disc tray. worked for me.
Posted on Sep 21, 2008
  • 975 Answers
Looks like the OPTICAL LEN part D.O.A. on you , I suggest to replace the OP LEN , AND SHOULD BE ABLE TO PLAY. hope this helps
Posted on Apr 19, 2008
Cd player shows toc err
google the name clarion error code toc
Feb 23, 2014 | Clarion Car Audio Player
Toc error 14
On questions like this it would help if we knew the manual was or was not consulted.
And if it was NOT, why.
C14 / TOC Error The unit did not read the TOC information. Insert other discs.
http://www.cdrfaq.org/faq02.html#S2-19
[Extract]
"If you write data to a disc and leave the session open, the TOC -- which tells the CD player or CD-ROM drive where the tracks are -- is written into a separate area called the Program Memory Area, or PMA. CD recorders are the only devices that know to look at the PMA, which is why you can't see data in an open session on a standard playback device. CD players won't find any audio tracks, and CD-ROM drives won't see a data track. When the session is finalized, the TOC is written in the lead-in area, enabling other devices to recognize the disc.
(Something to try: write an audio track to a blank CD, and leave the session open. Put the disc in a CD player. Some players will deny the existence of the disc, some will spin the disc up to an incredible speed and won't even brake the spindle when you eject the disc, others will perform equally random acts. The TOC is important!)"
Mar 02, 2011 | Sony RCD-W500C 5-Disc CD Recorder
Whats the difference between the teac rw-cd22 and rw-d250
I have a Teac RW-CD22 and it keeps telling me there is no TOC> I am unable to record a disc.
Dec 04, 2010 | Teac RW-D200 / RW-D250 Dual-Deck CD Player...
Sharp XL-HP515 CD Player won't play. Displays "toc read"
take it apart and clean len with a qtip an rubbing achol on face and mirror sides(top and under
Oct 09, 2009 | Philips CDR770 CD Recorder
TOC eror
The TOC error is the same error seen on computer disks, TOC is the table of content, this has to be read before the the unit will know the details of tracks etc......
If every disk inserted (not just burned discs) has this error, the laser is faulty or out of alignment. Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 01, 2009 | Kenwood Sirius KDC-MP522 CD Player
Emerson 3 disk CD player - CD spins - message
im not sure what toc read means, my cd player says that im guessing it means its loading, any ways take the d player apart an clean the lens wit a cuetip that should work, or the cds may be to scartched to read
Oct 15, 2008 | Audio Players & Recorders
TOC error message
Unit displays TOC error when I inserted two new cds I purchased.
Nov 05, 2007 | Audio Players & Recorders
What does toc err mean?
TOC is table of contents. Typically if its on a recorded cd try burning a cd from antoher computer and try it, if it works its most likely that your burner or software or ccd's your using are bad. Also is it a MP3 disc your trying to play? If so then you MUST burn it as a MP3 cd. You cant just burn MP3's to a CD and it read them. If this is the case thats why you are getting the TOC error because its not writing to the CD whats on the CD on the TOC area of the disc.
Sep 14, 2007 | Kenwood KDC-MP228 CD Player
TOC Error
I had the same problem with my KDC-M7024 CD player. All I done was put a cleaning disc into the player and let it play for 2-3minutes. The disc has a small cleaning brush on it which spins around like a normal CD would and as the bristles pass over the laser it removes any dust.After that it worked fine but i still have to run the disc through every 3-4 months or the problem persists.
Dec 07, 2006 | Kenwood KDC-M7024 CD Player
419 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
