Question about Toshiba Computers & Internet
Loud fast beeps on boot.( Toshiba Qosimo F45 )
Very loud... It seems to quit when i press the Esc key a couple of times but it still beeps a lot. The only other problem is notice is that the windows logo key will only open Start Menu it does not work with shortcuts like windows + E for explorer.Reminds me of a stuck key...
External USB keyboard works fine except right after booting the
icons on the desktop keep flashing very fast like the tab key is stuck
after I press the Esc key a couple of times it stops and works normally.
I am guessing its the keyboard or maybe the motherboard is failing.
Thanks,
Quasimoto
  • cambridge539 Jul 09, 2010
    Update 6-8-2010 7:02 PM
    I found out how to remove the keyboard and it tested good with the keyboard removed : D
    I will just replace the keyboard.
    Thanks for the tips guys.
    Quasimoto
    Quasimoto
  • 748 Answers
Looks indeed as if the TAB key was stuck or malfunctioning. The most common cause for such behavior is a liquid spilled on the keyboard, a bit of which got between the layers of the keyboard membrane films and causes intermittent semi-short between conductive areas.
A trace of liquid caught between plastic films is hard to get rid of, as it practically sealed and doesn't evaporate.
If it doesn't go away, you may need to replace the keyboard, which is not very expensive fortunately,
Posted on Jul 08, 2010
  • Stan
    Stan Jul 09, 2010
    Glad to be of help, as always :)
  • 487 Answers
Hi, could be motherboard, but you will get a loud beep when you have a memory problem. Try replacing memory chip before motherboard. Hope this helps, regards
How to Insert Boot Media?
Mostly you wil have to adjust the BIOS of the computer to boot from USB or DVD media.
When booting most computers mention the button(s) to press to get into BIOS:
--A Function key (such as F1, F2, or F3)
--The Esc key
--The Delete key
On some PCs, entering the BIOS may require pressing another key or a combination of keys. Keep your eyes open for an on-screen message that says something like: --'Press F1 to enter setup'
--'BIOS settings: Esc'
--'Setup = Del'
--'System configuration: F2'
If you don't catch it the first time, simply try again. Your computer's documentation may also tell you which key to press.
3. When you know the right key, start the computer again and press the key when the first screen pops up: You may hear a confirmation beep or see a new message. If you timed it correctly, you'll be in the BIOS within a few seconds.
Good luck,
A.Misset
Oct 18, 2016 | Computers & Internet
How to boot into safe mode
Windows can boot into safe mode by hitting F8 during boot up, but the time window for that is very small.
If you use a USB-Keyboard, it's a little bit tricky to press the Function key during the small "time-window". You can just press F8 a lot of times in a very fast sequence and ignore the beeps at every keystroke.
Do not hold down the F8-key permanently, because it will cause a keyboard-error and leads you into the BIOS.
Hope that works for you !!
Oct 19, 2014 | Lenovo ThinkStation Computers & Internet
Keeps beeping at boot
beeping in some computer is a factory installed indicator for a malfunctioning part on your computer. One possible issue on your laptop is a stuck key on one of your keyboard keys. Have your keyboard keys checked. If the issue is in relation with the universal charger, the laptop may not be recognizing it at first boot due to incompatibility with your laptop or the charger itself is damaged. Have them checked by a local technician to avoid further damage.
Oct 19, 2014 | Fujitsu Siemens Amilo M7400 Laptop...
Acer 5742g Beep at boot up
I have a problem that looks like this one.
At boot up, after the POST, each time the HDD led blinks, the laptop produces a loud "beep", and refuses to boot, as if this phenomenon prevented the HDD to be read.
If I press the power button, it stops beeping. When I release it, it starts beeping again.
If I press F8 at the beginning and then ask for a normal boot, It boots normally. Anyway, in windows, I have some strange activity, like I would continually pressing Alt+Tab. If I press Esc, it stops immediately and then all seems to work fine.
Any clue?
Jul 26, 2012 | Acer Aspire 5742G
Fan to loud. Cannot find option to set the CPU fan go to off at a higher temperature
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS
scroll to PC health status press Enter you should see some of the temperature settings available you could disable the shutdown at the current the Temperature
after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
cmos is located in BIOS
hope this helps
Jun 02, 2011 | ASUS M2NBP-VM CSM Motherboard
I made in bios a setup to boot fast and when i open the laptop the bios option it doesnt appear anymore , it is starting windows. how can i repare it .how can i acces the bios again?toshiba L655-S5058
1. Turn on computer by Holding down power button while pressing the ESC key.
The machine will beep, then display:
Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
May 04, 2011 | Toshiba Satellite L655S5058 Notebook PC
My e525 laptop starts up, and after the big "e" logo the screen goes blank.* Whenever I press a key there's a loud beep. How do I fix this? *As far as I can tell the screen is blank, but it's...
Try this... 1. Remove the battery 2. Remove the memory for about 5 minutes 3. Re-insert the memory 4. Press ESC for about 3 minutes while putting the power adapter. 5. Then turn on without battery.
Mar 11, 2011 | Acer eMachines 520-2890 Notebook
Loud beeps at start up dell inspiron mini
Beep codes for the Inspiron Mini are as follows:
Beep Code Possible Problem
One Possible system board failure — BIOS ROM checksum failure
Two No RAM detected
NOTE: If you installed or replaced the memory module, ensure that the memory module is seated properly.
Three Possible system board failure — Chipset error
Four RAM read/write failure
Five Real Time Clock failure
Six Video card or chip failure
Seven Processor failure
Eight Display failure
Jun 10, 2010 | Dell Inspiron Mini 10 Notebook
Toshiba satellite 1415 S-173 BIOS entry key
Try this...
Toshiba® 335 CDS ESC Toshiba Protege ESC Toshiba Satellite 205 CDS F1 Toshiba Tecra ESC then F1 or F2 Toshiba Notebook [Newer models]
2. Release ESC key
3. Press F1 key
Nov 04, 2009 | Toshiba Satellite 1415-S173 Notebook
THE BEEPING ON THE NURIT 2085 MACHINE IS TOO LOUD CAN I TURN THAT DOWN
Easy fix. Hit (Menu/Esc), Scroll down to #3 (Merch Options), Enter, Scroll Down to #3 (Buzzer Set), Enter, Press #1 (Off). The annoying beeping should go away.
Apr 07, 2009 | VeriFone (M19755014US1) Magnetic Card...
Computers & Internet Logo
405 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
