Question about iLO (2 GB) MP3 Player
Copying to device
I've copied music before with out a problem. Now when I try to copy the computer will say an error occured. The next time I click on copy, the conputer will say ready to copy. The next time I click on copy ,it won't show anything, but when I release the left click button, the computer will show for an instant "copy in progress" but it doesn'y copy. There is still plenty of room on the player to copy the music that I want on there.
  • 8,596 Answers
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jul 05, 2008
How do I download songs on my eclipse mp3 player
Things You'll Need
Microsoft Windows 7 computer with an open USB port and iMesh installed
USB cable compatible with Eclipse MP3 players
Instructions
  • 1 Plug a USB cable into the Eclipse MP3 player. Plug the other end of the USB cable into an open port on the Windows 7 computericon1.png.
  • 2 Click the "Start" button on the Windows 7 desktop taskbar and click "Computer" in the menu that appears. Click the "Music" item located in the left pane of the "Computer" window that appears. Double-click on the "iMesh" folder. For Windows 7, XP and Vista. Recommended. Download Now.
  • 3 Click the "Start" button on the Windows 7 taskbar and click "Computer" and then double-click on the "Removable disk" icon that represents the Eclipse MP3 player device. A window will appear displaying the contents of the Eclipse MP3 player storageicon1.png area.
  • 4 Right-click on a music file in the "iMesh" directory that has the "mp3" suffix, and click "Copy" in the menu that appears.
  • 5 Right-click on empty space in the "Removable disk" window and click "Paste" to copy the music file to the Eclipse MP3 player device. Repeat for each file you wish to download to the Eclipse MP3 player.
    To copy multiple music files at one time to the Eclipse MP3 player, press and hold the "Shift" key on the keyboard. Click once on each file you wish to copy. Right-click on one of the highlighted MP3 music files and click "Copy" in the menu that appears. Right-click on empty space in the Eclipse "Removable disk" window and click "Paste."
Oct 21, 2014 | Audio Players & Recorders
How can i get itunes to download on my phillips gogear 4gb?
Transfer music via Windows Media Player 10:
  1. Hook up your GoGear with the PC via the supplied USB cable.
  2. Make sure you connect your GoGear micro also to the main power supply.
  3. Launch the version of Windows Media Player 10.0 installed in your computer. Note: Once the device is connected to the computer, all playback or radio will stop.
  4. Check and make sure that the Create folder hierachy on device option is enabled in Windows Media Player. Go to Tools>Options. Select the Devices tab and then highlight GoGear Audio and click Properties
    Click OK to close the windows.
  5. Click Sync.
  6. In the Items to Copy pane, in the drop-down list, click the playlist, category, or other item that you want to copy.
  7. Click the check boxes next to any files you want to copy.
  8. In the Items on Device pane, in the drop-down list, click to select PhilipsGoGear to copy files to.
  9. Click the Start Sync 051028091952_1760.gif button.
  10. The Player verifies that there is sufficient storage space on the device to copy the selected files. If there is sufficient space, the files are converted (if necessary) and copied to the portable device.
  11. Repeat steps 2-5 for any other items that you want to copy to your portable device.
  12. Once the transfer is completed, close the Windows Media Player
  13. Unplug the GoGear from the PC and enjoy the music on your GoGear.
Transfer music via Windows Explorer:
Note! You cannot transfer pictures via Windows Explorer, for pictures use Windows Media Player.
  1. Connect your GoGear with the PC via the supplied USB cable. Make sure you connect your GoGear also to the main power supply.
  2. Launch Windows Explorer.
  3. Drag and drop your music files into the music folder of your GoGear.
  4. Once transfer is complete unplug the GoGear from the PC and enjoy the music on the go.
Jun 10, 2010 | Philips GoGear Flash MP3 Player
How to download music from computer to my philips gogear audio player
  1. Hook up your GoGear to the PC via the supplied USB cable.
  2. Plug your GoGear into a power outlet with the supplied AC adapter/charger.
  3. Launch Windows Media Player 10.
    Note: Once the device is connected to the computer, all audio or radio playback will stop.
  5. Click "OK" to close the windows.
  6. Click the "Sync" tab.
  7. In the "Items to Copy" pane, from the drop-down list, click the playlist, category, or other item that you want to copy.
  8. Click the check boxes next to any files you want to copy.
  9. In the "Items on Device" pane, from the drop-down list, click on PhilipsGoGear for where to copy files to.
  10. Click the "Start Sync" button.
  11. The Player verifies that there is sufficient storage space on the device to copy the selected files. If there is sufficient space, the files are converted (if necessary) and copied to the portable device.
  12. Repeat steps 2-5 for any other items that you want to copy to your portable device.
  13. Once the transfer is completed, close Windows Media Player.
  14. Unplug the GoGear from the PC and enjoy the music on your GoGear.
Note! You cannot transfer pictures via Windows Explorer, for pictures you need to sync them using Windows Media Player.
  1. Connect your GoGear to the PC via the supplied USB cable.
  2. Connect your GoGear into a power outlet with the supplied AC adapter/charger.
  3. Launch Windows Explorer.
  4. Drag and drop your music files into the Media/Music folder of your GoGear.
  5. Once your music has been transferred to your GoGear disconnect it from your computer and you are ready to listen to your music.
if this it was helpful rate my solution and vote me thanks
Jan 06, 2010 | Philips GoGear HDD1830 MP3 Player
How do I download music on my mp3 player? I bought the mp3 player(gpxml638b) and it did not have any soft ware. I have the wire to plug from mp3 to computer, but how do I start downloading music?
Sir,
1. Turn on the MP3 Player by holding the PLAY/PAUSE button.
2. Take the USB Cord and plug the corresponding ends into the MP3 Player and a Computer.
3. When connected the LCD Display will either say “USB” or “MTP”.
4. Press the “M” (mode) button to switch between “USB” and “MTP” mode.
“MTP” mode will only work, when your player is connected to Microsoft
® Windows® XP and Windows® Media Player 10.
The MP3 Player will only work in “USB” mode when it is connected to Windows® 98SE, ME, or 2000 Professional.
1. Start Windows Media Player 9 and connect the MP3 Player to your computer.
2. Click “Copy to CD or Device”.
3. In the drop-down list, on the “Items to Copy” pane, click the play list, category, or other item that you want to copy.
4. Clear the check boxes next to any files you do not want to copy.
5. In the drop-down list, on the “Items to Copy” pane, click the device that you want to copy files to.
6. Click the ‘Copy’ button.
7. Repeat steps 2-5 for any other items that you want to copy to your unit.
1. Start Windows Media Player 10 and connect the unit to your computer. On your player’s display it should say ‘MTP’. If not, then while the unit is connected press the ‘M’ (mode) button to change from ‘USB’ to ‘MTP’ mode.
2. If you have not set up synchronization between your computer
and this device, the Device Setup Wizard starts. In the Device Setup Wizard, select Manual.
3. Click Finish.
4. Select Library option. On the right pane select Sync List.
5. From the left pane you can select the Play list or Library and you will see the content songs in the center pane.
6. Select the songs from the center pane, drag and add them to the Sync List.
7. Click the ‘Start Sync’ button in the Sync List pane.
8. Repeat steps 4-7 for any other items that you want to copy to your unit.
Thanks
Good Luck
Aug 17, 2009 | GPX ML648B MP3 Player
I dont know how to download music to my mp3 player
excerpt from manual @ nextar.com
Q. How do I copy/transfer files to my MP3 player?
A. There are many ways to copy /transfer music to your player. Here¡¦s a common and simple way to do this process using Windows Explorer. Follow the instructions below: -Connect the disk storage (MP3 player) to your computers USB port. If the computer pops up a window asking what do you want windows to do? Click cancel. -Right click on My Computer and click on Explore. A split window will pop up and display the contents and drives on your computer. Look for the drive Removable Disk (E:) [The letter drive may vary depending on your computer] This is your MP3 player. -Next, drop down My Documents and click on the My Music folder. If you store your music files in a different location then find that folder. -Take a file from the My Music folder or where ever you store your music files, click on the music file drag and drop it into the E: Removable Disk on the left of the window. A window will pop up and display the progress of the copying. Repeat the process until your player is full. You have completed the file copy/transfer process!
May 06, 2009 | Nextar MA933A MP3 Player
File system err on spi digital audio player
Click menu and scroll to the setup screen and hit reset.
then go back to the music it will say file error then use the right button to browse to next song and you will see your songs. If however in the music you don't see any songs (number 1of 64 or whatever) then you have to reload your songs.
Next, if that does not work. Go to setup select format complete, (note this will reformat the player) then go to your computer (in explorer) and copy the music right to the music folder (only songs don't copy folders into the music folder on the device.)
then go back to setup, select reset and go back to music menu. You may still have a file error just hit the next button and there are your songs.
Feb 10, 2009 | Audio Players & Recorders
Write protected flash memory
do you know its a problem occur
when device ejected harshly
try to plug it may solve your problem
or try this
go to my computer> properties>hardware > device manager >universal bus driver>right click on it> update driver>
then1
1.yes this time only> next 2.choose advanced option>next 3don't search i"ll update from........>next4.click on show campatible> next> next 5. now it updated then restart you computer
your problem will now soved
Oct 22, 2008 | iLO (2 GB) MP3 Player
Cannot copy files (music, photo etc) from int memory to memory card
i'm having the same problem. can't transfer files onto memory card. when i try, it says "no entry". someone please help.
Jan 03, 2008 | Samsung SGH-D820 Cellular Phone
Sandisk sansa m230 512mb
Open the device under My Computer. Your music is in the Music folder. Select the songs to copy, right click on one and select COPY. Select the destination folder on your computer and right click an select PASTE. This should copy all of your music to your PC. If you are receiving an error about "administrator rights" you need to change the Windows User account to the Administrators account. Please add to the question, if you need more assistance. Best of Luck.
Sep 26, 2007 | SanDisk Sansa m230 MP3 Player
iLO (2 GB) MP3 Player Logo
24 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Jon Piercy
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
