Question about Xerox Workcentre M24 Color Copier
My xerox workcentre m24 is giving continuous paper jams at the duplex unit
  • thesignmama Jul 09, 2010
    Need help with paper jam in xerox duplex unit.
    Paper gets jammed no matter which tray I use. Also the top left corner of the jammed paper seems to be melting
    Genius:
  • 1,416 Answers
the problem of the paper jam is from the using material (paper) meaning that the paper does not release on time or there is a little paper at the front of the roller which will need to be remove
what to do to solve the paper jams problem is that the paper will need to be worm (i.e it will need to be dry or to change the set of paper) form some time and also for the blockage on the roller you will have to clean up the roller with care then the problem of paper jam will be solve .
thank you and thanks for using fixya .
Posted on Jul 09, 2010
  • Xerox Master
  • 6,826 Answers
Always make sure that the paper you use is new and fresh and flat.
Also, make sure it is of the weight recommended by Xerox.
Also, remove according to the following instructions:
Fig. 1
Top left cover
Gently open the top left cover while lifting up the release lever.
Fig. 2
If the edge of the jammed paper can be reached at the output tray, pull
the jammed paper in the direction of the feed-out area.
Fig. 3
If you cannot remove jammed paper, then inside the fuser unit, lift up
the green lever and remove the jammed paper.
Fig. 4
Duplex Module Cover
Open the tray 5 (Bypass) and gently open the duplex module cover.
Fig. 5
Remove the jammed paper.
Fig. 6
Tray 5 (Bypass)
Inspect the inside (paper feed entrance) of Tray 5 (Bypass), and remove
any jammed paper.
Removing paper Jam - 1 of 2
The rest is found in the instruction manual at the following address:
http://www.manualsmania.com/download.php?link=d3a1b9c8ad6d2699cbd2a625e51ea81ffca7ca9d
Posted on Jul 08, 2010
  • thesignmama Jul 08, 2010
    your solution did not work.
  • Duane Wong
    Duane Wong Jul 08, 2010
    It seems that Xerox made a mechanism that jams as I read other posts about this problem.
Xerox Workcentre M24 Color Copier - Keeps giving me an error to close the duplex door. I've closed it, and it seems to be all in good order, but the message will not go away. Any suggestions? Thanks.
It might be problem with your sensor.I will give you a sftware of the machine it is called it's pws.Note my e mail fazilatprinters@gmail.com email me your teamviewer software's id and the time i will share your pc through this software and repair your machine wia this software.i will tell you step by step and you have to follow me.I am giving you time on sunday at Pakistani Time 3:00 Pm
Mar 14, 2013 | Xerox WorkCentre M-24 Color Copier
Xerox workcentre 5765 paper jam message but no paper is jammed
Check all the paper detecting sensors once more, may be there is something over the sensor.clean all the sensors with VIDEO 90. if after that problem persist please restart the machine and go for software and firmware upgrades.
GOD BLESS YOU
Oct 20, 2012 | Xerox WorkCentre 5765 5775 5790 Fuser...
Xerox ws m24 drum counter reset?
how we can reset counter of drum unit m24
Nov 20, 2010 | Xerox WorkCentre M-24 Color Copier
I have xerox workcentre xd105f, can't make copies,paper jam
P will flash on the screen when the paper tray is empty, paper misfeeds or the paper tray door isn't closed all the way. Make sure both (if you have 2 paper trays) are loaded, that the paper isn't folder and wrinkled, and ensure that the tray doors are closed firmly. Then hit start on the workcentre to continue any unfinished jobs.
Jun 19, 2009 | Office Equipment & Supplies
159 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
