have you topped up the brake fluid level,if so unscrew it again and replace,is the brake fluid leval ok,the only other item that will keep light on is a faulty switch behind the pedal.get a can of silacone spray and spray it on the switch at the back of pedal and see if this works,put a cloth over the pedal to stop the oil dropping on the pedal.adrian,,,
it is usually under the dash, look for round cylinder about 2" long or a square one about the same size,it will have a connector plug on the top just pull the plug off & replace the flasher unit & replace the plug.....hope this helps.....cheers
hi, the light may have more to do with the fluid level in the brake reserviour, it may need topping up and if that does not also fix the loose handbrake then you will probably need to adjust it.
the switch down by the pedal is out of place not sure what the m-h-p is, either different levels of traction control or more likely suspension hardness
