Yellowish tinge Shortly after replacing a burned out projection bulb in my Sony KDS50XBR, the entire viewing screen acquired a yellowish tinge. No amount of adjustment was able to bring back the proper colors. To make sure it wasn't the incoming signal, I attached another tv to the cable and everything was fine. The picture and audio are fine, expect for the yellowish haze which makes everybody look like they've got jaundice!
  • Jera Apr 19, 2008
    Anyone with color issues dealing with Sony KDS-R50XBR1 & KDS-R60XBRI is strongly advised to view the following: http://esupport.sony.com/US/perl/news-it...
    Genius:
  • Televison & ... Master
  • 1,689 Answers
This normaly has to be the colour temperature of the lamp that you put in.
When you bought the new lamp, was it an original, or did you substitute it for a lower cost or different replacement that electricaly and mechanicaly fits?
Check out if the lamp is the original type. If so, you can try to call the manufacture tech support to get their opinion.
It is possible, but in your case I am not strong to think so, there may be the slight possiblity that there is a defect in the drive circuits for the video processing.
Jerry G.
Posted on Apr 19, 2008
    Brigadier General:
  • 6,966 Answers
Hi again,
Any development(s)?
For KDF-E42A10 When picture is black, a bluish fadded spot appears in the center of screen. When picture is white, a yellowish fadded spot appears in the center. Do I just replace the bulb?
no this is a problem with your Optical block your LCD chips have gone bad you need to replace this part to fix this issue the bulb will not solve this kind of issue
Oct 15, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Color of picture on all channels in yellowish
Your optical block, also known as a light engine, is going out. I actually just had mine replaced today!!!!
Dec 11, 2009 | Televison & Video
Circular yellowish tinge projected on screen. Outer edges white.
First, check your cables on the input side. If your using RGB, it could be a bad cable, If your using DVI or HDMI, it's more than likely the convergence chip and will have to be serviced. Try a DVD player as a source connected directly to the unit with a new cable; ie. HDMI, DVI, or component and check the picture. If it's still the same, it definately needs serviced. If you need further help, post a comment and I can help you further. Hope this helps.
Sep 21, 2009 | Audio Players & Recorders
Yellowish cloud in the middle
Replacing the Optical Block will cure the problem. Due to the cost of the repair i would call Sony at 1800-222-SONY and see if they could assist you in the cost of repairs. You would need to get a Authorized Service Facility out to confirm the problem and give you a estimate to in turn give to Sony. The amount they they will pay for is of course up to them but it is better than paying the entire cost yourself.
Hope this helps,
Skyassoc
Jul 22, 2009 | Televison & Video
Greenish/Yellowish
No easy fix for a TV. If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. As long as there's no burning smell, and the set is okay even when hot, after running for awhile, it's possibly bad connections on the convergence board. If you have some decent soldering skills and a familiarity with the insides of a TV, you may even save yourself a repair bill by getting some bad solder connections cleaned up. If its not the connections it could be the STK chips, or the board itself. Take care
Feb 13, 2006 | Samsung HCN653W 65" Rear Projection...
Televison & Video Logo
181 people viewed this question
Top Televison & Video Experts
