Question about Cuisinart DLC-7SFP Pro Food Processor
Cracked plastic sheath on the motor drive shaft
DLC-7 SuperPro has a cracked sheath and the blades, detachable stem won't fit on it anymore. I've ordered a replacement motor shaft sheath, but I have no idea how to remove the old and and put the new one on.
Any suggestions?
Thanks.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 8 Answers
The shaft is spinning inside the sleeve. So is should not be hard to remove. With a DLC-7SP, I grabbed the spindle with some pliers, channel locks might do well and put a handle of a screwdriver between the pliers and the top deck and pried. Second attempt and it pulled up easily. Place the screwdriver beside one of the top deck screw covers to transfer force directly to the motor. Otherwise top deck would probably break.
Clean the old shaft to remove any contamination.
New one can be driven on with a hammer and block of wood.
Posted on Jan 29, 2011
Blade of cusinart dlc 7 superpro food processor will not spin when food is in the bowl- works when no food is in it. Is it is the stem? How do I replace it?
It'll probably cost more to fix than replace. If you have a collection of blades, maybe find one in working order on a shopping site and meld the two together. Happy hunting! Happy New Year!!!!
Jan 01, 2015 | Food Processors
Replace the motor shaft cover on cuisinart dlc 7
I have a DLC7pro from around 1982 that I just replaced the sheath on.
To remove the sheath I use a small pipe cutter and took the sheath off in approximately ½ inch sections. Once the circular cut was complete I used a plier to pull off the section. - This method worked GREAT! Be sure you get ALL of the white plastic off and be sure to remove the ½ inch brass "ring" which is part of the old sheath. Also, make sure no plastic "crumbs" are in the base of the shaft where the new sheath will sit. You will see that the metal shaft has a flat side. With a sharpie marker, mark the metal shaft near the base to indicate where the center of the flat side is.
When you look at the replacement sheath, you will notice flat sides on the outside of the sheath. If you look inside the sheath, you will see two "nubs", these nubs form a flat inner side of the sheath . Unfortunately these nubs do NOT line up with the flat outside sections. Use a sharpie marker to mark the center point of the two inner nubs. The inner flat side HAS to match up perfectly with the flat side of the shaft. The marker helps you do that.
Line the inner flat side of the sheath up with the flat side of the metal shaft and push the sheath on your hand as far as it will go. It should go about an inch from the base.
Put the base on a mat on the floor ( you don't want to damage your floor) . Next you will need a hammer, piece of 2x4 wood and BRUTE STRENGHT! - Please note that once you hammer this, even just one strike and the sheath will NOT come off. Put the 2" side of the wood against the top of the sheath. Using more force than you think you should need - strike the wood to hammer the sheath all the way down. It should take 3 - 5 very hard strikes. If the base of the sheath rubs on the bottom of your workbowl - they will fuse together, so be sure the sheath is seated as far down as you can get it. Again, it takes a LOT
Dec 06, 2010 | Cuisinart DLC-10S Pro Classic Food...
Cuisinart DLC-7--blade stuck--cannot remove from bowl.
First off, is it a BLADE that's stuck, or a DISC?
If it's a disc, and the disc is blocking your access to the center post, put a ziploc baggie full of ice on top of the disc (right in the middle) and let it sit for about half an hour. That should shrink the plastic enough to pop it out.
If it's a blade, you can try the ice trick, or you can try Pam (or another food grade cooking spray) to loosen it up, and then just try to take the workbowl off like you usually would (aka, DO NOT grab the blade, or you'll risk cutting yourself--you can just pull up on the bowl, and the blade should pop off.
If you need further help, you can always contact Cuisinart--their phone number (according to their website, www.cuisinart.com ) is 1 800 726 0190
Good luck! :)
Aug 31, 2009 | Food Processors
Cuisinart DLC-8 Plus Motor Shaft Cover broken.
I had the same problem: Cuisinart sent a "replacement" sheath for my DLC-8E which turned out to be the wrong one. When I replaced mine,which was cracked, none of my blades would fit over the new sheath! I "solved" the problem by purchasing a new DLC-8E motor base on Ebay for only $9.99!
Mar 09, 2009 | Cuisinart Food Processors
How to attach Cuisinart blades DLC 8 to DLC7 stem
The DLC-8 blades and the DLC-7 blades are not compatible. To attach the stem, first attach the stem to one of the compatible blades - the stem should day "DLC-7" for the DLC-7 blades - by inserting the first two tabs of the stem into the first two ridges of the blade connector - the left-most tab should be sticking out past the end of the blade connector - then slide the stem into place so that all tabs fit securely into the blade connector. Next, place the end with the blade up and insert the stem into the middle of the workbowl. There is a video for all Cuisinart food processors on the Cuisinart website.
-Tha Mp3 Doctor
Jan 01, 2009 | Food Processors
Sure, you can find it on amazon, here: Amazon com Cuisinart Motor Shaft cover. Hope this was helpful. have a nice day
Nov 16, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Food processor
I phoned the 800 number at Cuisinart (800-243-8540) and the person who answered the phone explained to me what to do: Fill the bowl with the hottest tap water I have (but not boiling) above the entire blade (including the part that fits over the shaft). He said to pulse a few times, then try to pull it off, but not to expect it to work right away. He said to do this until it comes off and that it could take 1/2 hour. I did what he said, and the blade came off after the first pulses. But also, the water was pouring out all over the counter--leaking between the bowl and the base (possibly because my old work bowl is also cracked, but I'm not sure).
I was told that the problem would happen again, and that I needed replace the blade and the shaft (which is cracked, as he guessed), both of which are available from Cuisinart.
Oct 07, 2008 | Cuisinart DLC-5 Food Processor
Cuisinart Food processor
Go to the cuisinart website and you can buy replacement parts. You will have to buy the entire shaft not just the top but it is still good!
Mar 25, 2008 | Cuisinart DLC-10S Pro Classic Food...
Cuisinart DLC-7SFP Pro Food Processor Logo
812 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Donni Steen
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
