Question about Garmin GPS 48 GPS Receiver
"Upload ...Not Present" message. Nothing else on the screen. I replaced the internal battery last spring used it all summer. Have just checked internal and external batteries and all are fresh 3v internal and new AA four batteries. Upon startup the screen says "Upload" "Not Present" and there is no menu. I have tried hitting Page and Menu, etc. nothing happens. I tried leaving it out and on for 3 hours to see if it would find itself and satellites. I tried connecting to the computer and uploading the internal program the port was not found. Tried this a number of times and a number of ways. I have tried leaving it on to search for 3 hours and have tried to connect to my computer to reinstall the software but that does not work. The internal battery was replaced with a new one last year. I have fresh batteries in the unit. What is the problem? How do I fix it? Thank you. I love this unit and would like to keep it going. I have fixed two others for friends who needed the internal battery fixed. They use it as a backup. I have tried the Auto Locate procedure about 3 times. I have also tried clearing by holding the PAGE + Power. Then tried autolocate. Message "Upload... Not Present" still remains. Also have tried clearing by holding the MARK + Power. Then tried autolocate. Message "Upload... Not Present" still remains. Now I am wondering if this message has to do with an interrupted connection with EasyGPS from last winter. I was uploading waypoints, and thought it had completed and may have turned off and disconnected the plug before an operation was completed in saving waypoints off the Garmin 48. I do not know this for a fact, but that was the last operation I recall doing last fall, before starting the GPS up again on the boat this spring. I have also tried to connect the unit to Easy GPS via the serial port, thinking perhaps it would complete whatever it is trying to do. I have tried uploading routes and downloading routes via EasyGPS send and recieve and it does not seem to work. I wonder now if the interface setting has been reset, by my pressing PAGE+power and Mark + Power earlier. I would not mind that if the menus came up properly, but that is not happening. Is there some other way to kick it out of this mode? I turn it on and there is the message "Upload...Not present" and none of the menu buttons work to get it into the normal startup screen mode..... I've tried Quit, Page, Enter, Goto, Mark, Power (off and on), and none of the get the computer out of this mode and back into the normal menus for startup. I've removed the antennae and checked all the contacts and that seems fine, and reinstalled. Is there some small reboot button inside that I can jumper? I have tried taking the internal battery out and letting it sit for three days and it still does the same thing. Any suggestions would be appreciated
4 Suggested Answers
  • 4 Answers
SOURCE: GPS 60 unit shows "Searching the Sky" status message all the time
The "New Location" fix above brought my GPS 60 back to full operation. I did reload the GPS software from Garmin but the recovery depended on well charged batteries and as above: turn the unit on
press MENU button
scroll to "New Location"
wait 10 minutes for the GPS to recover.
Posted on Apr 02, 2008
  • 3 Answers
SOURCE: waypoints and nav log
Based on your description I would suspect that the internal memory battery is depleted and needs to be replaced. This battery is required to retain waypoint and route information when the input power is low or turned off. The battery is soldered onto the main circuit board and needs to be replaced by a technician having good soldering skills and access to instructions for the disassembly and reassembly of the unit. There is a list of dealers on the Northstar website. Review the list and make a couple of phone calls to see which ones will do bench work on this unit.
Posted on Jul 13, 2008
SOURCE: Garmin 48 memory loss
I have fixed several Memory battery low for the Garmin 48 .
Posted on Oct 15, 2008
Magellan Triton 400 locks on opening screen can not do anything have to remove batteries to turn off
This is caused by a corrupt file in the internal memory of the 400. The software to fix this problem is on the website www.exploristforum.com under Repair and Services section.
JG
Nov 08, 2016 | Magellan Triton 400 Handheld GPS Receiver
Harley trouble codes
p511 = Throttle actuator control power management failure of throttle control actuator
p2107 = EFI Module Processor Internal Fault
May 01, 2014 | 2009 Harley Davidson FLHRC Road King...
Two years ago, my mower (cub cadet lt1042) wouldn't start. Replaced the solenoid switch and it worked the rest of that summer and the first half of last summer. The middle of last summer, I mowed part of...
hard to say, I would make sure the inline fuse is good, then use a vehicle and jump start the mower. I am sure you know how to ensure the mower is ready to start, so we won't cover the pto,brake,etc. Good Luck Tim
Mar 26, 2011 | Garden
Maintanance
regularly change the engine oil every 1500 km or every 2\3 months whenever required, and also regularly check the tyre air presure \,that will help your bike to give a good mileage, regularly get a check up for your bike
May 22, 2009 | 2004 Suzuki RM 125
Grill won't light. We press ignitor switch, and nothing happens
Have you replaced the ignitor? Also check the spark and make sure that it is sparking where the gas is coming out
Apr 24, 2009 | Kitchen Ranges
Date not appear on screen
Your internal back-up battery is empty, please replace the internal battery and date will apear.
Rob
Feb 08, 2009 | Panasonic Lumix DMC-FX3 Digital Camera
GPS 12 "upload not present"
I have a Garmin GPS 12, which has worked perfectly over the last 10 years until a few days ago. It was on and working fine, I marked a waypoint, turned it off and put it in my pocket. 45 minutes later I pulled it out and when I tried to turn it on it only showed the message "UPLOAD NOT PRESENT". Nothing I did would get it to show me anything different (I tried all kinds of button sequences...holding some down for many seconds, pressing multiple at the same time, etc.). The only thing it would do was turn on and show me that message, or turn off. I called Garmin and they said they could repair it, but that would require shipping it to them. They said it would cost $59 (which included the repair and shipping back to me, but I was responsible for whatever it cost to ship it to them). I asked if they would be able to save my routes and waypoints if they "repair" it, but they couldn't guarantee that. I told them that I heard "reloading the firmware" or "uploading the newest update" might fix it AND keep my routes and waypoints. They told me that might work. I didn't have the PC interface cable that was necessary in order to connect it to my computer to update it, so I asked them what it would cost to buy one from them. They said it would be $38.09 through them, but that I could get it cheaper on the Internet (part # 010-10141-00). Then they said they actually may have some of them sitting around in a box somewhere (I'm assuming they meant used cables). They checked around and found one and shipped it to me at no charge! It arrived in a couple days. Then I just plugged it into one of the serial ports in the back of my computer, plugged the other end into the GPS and turned it on, went to Garmin's website: http://www8.garmin.com/products/gps12/download.html and downloaded version 4.60. I'm not sure what version was on my GPS originally (I obviously couldn't check anymore since it wasn't working), but the user manual that came with it said "Software Version 4.03 or above". It asked me to unzip the downloaded files and stored them on my hard drive at C:garmin. I opened up the file named 460_UPDT.TXT and followed the directions listed there (which are slightly different from the directions listed on the website's update page). One of the steps said to "Turn on your GPS and ensure the Serial Data Format is set to "GARMIN". You can find this setting in Setup Menu -> Interface." I couldn't do this since mine only displayed the message "UPLOAD NOT PRESENT", so I just ignored this step. I opened up the file named UPDATER.EXE and had it "auto-detect" when it asked me which serial port I used. The message on the GPS screen changed to "UPLOAD IN PROGRESS" and it only took about 4 minutes until the upload was done. The GPS screen then changed to the start-up screen where it acquires satellites and asked me to enter my country and state. Everything seems to be back to normal and all my routes and waypoints are still there. Even better, it didn't cost me anything but time.
May 31, 2008 | Garmin GPS 12 GPS Receiver
Garmin GPS 48 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
