Question about AOC 19LVWK LCD Monitor
When I Increase the Resulotion 1027 X 768 then display a message box " Inpur not support" and move arround slowly on the screen . my Motherboad is Mercury i installed the vga but problem is same plz solve my problem thanks
  • 62 Answers
This means, that your operating system is not set to the recommended resolution of your monitor. Your monitor has a "fixed" resolution where the image will look best. You can change the solution in Windows XP if you right-click on a free space of your desktop, then choose "Properties". In the new window, that comes up, select the rightmost tab. There you can use the slider to adjust your resolution. Just try some different resolutions until the message disappears.If you use Windows Vista or Windows 7 you can access the resolution window by right-clicking on your desktop and selecting "Screen Resolution".
Posted on Jul 18, 2010
I have Toshiba f30, its fans run slowly than normal. I remove, check, clean and replace thermal past them but nothing changing. Before when temprature increase, fans also increase their speeds but now they...
Ah! I posted an answer on your other question but I didn't get it right! Now it makes more sense. You cleaned up all and changed thermal paste on cpu. Might be a problem with a fan itself. Only thing that pops in my mind might be a problem with bearings, but if fan is fine i'm afraid thermistor on motherboad is fried.
Oct 30, 2013 | Toshiba Equium 100 PC Desktop
I am trying to set my Sanyo picture right side up. what setting do I go to?
Check Ceiling feature.
Press MENU button and ON-SCREEN MENU will appear. Press
POINT LEFT/RIGHT button(s) to move a red-frame pointer to
SETTING icon.
Language used in ON-SCREEN MENU is selectable from among
English, German, French, Italian, Spanish, Portuguese, Dutch,
Swedish, Russian, Chinese, Korean and Japanese.
Display
This function decides whether to display On-Screen Displays.
On ··· shows all On-Screen Displays.
Off ···· sets On-Screen Displays disappeared except;
? ON-SCREEN MENU
? "Power off?" message
? "No signal" message
? "Please wait...."
? P-Timer counter
Set a red frame pointer to item and press SELECT button.
Press POINT DOWN button to move a red-frame pointer to item
that you want to set and then press SELECT button. Se ting
dialog box appears.
Dec 11, 2010 | Sanyo PLC-XF46N LCD Projector
I broke the screen on my lap top and not sure what the resulotion is i have a hp pavilion dv6700
The DV6700 model carries the 15.4 WXGA High-Definition inch display, which outputs a maximum resolution of 1280 x 800.
Apr 23, 2010 | HP Pavilion DV6700T Notebook PC
No input signal, go to power save sony sdm-hs93
I f you see the message on the screen indicating 'NO INPUR SIGNAL', you need to check the VGA cable and both ends of the connectors also. Try this monitor with other PC also.
This SDM-HS73/93 have common problem: bad backlight assemblies due to poor workmanship in sodlering works, see my pictures below. You should also inspect the caps. This is not recommend for DIY.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS93/
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
Apr 18, 2010 | Sony SDM HS93 19" LCD Monitor
Dell monitor is flickering
If you have another computer, try hooking to it and see if it flickers on it too.
If you hit Ctl-Alt-Delete and choose Task Manager, does the box flicker there?.
Adjust the monitor ratio in the Display Settings/Display/ Display Adapter Properties, Monitor Tab, see drop down (increase screen refresh ratio to higher number).
Nov 10, 2017 | Dell E207WFP LCD Monitor
Not all the icons are displaying
you have to change your screen resulotion first right click on the center off the screen then click properties,setting now adjust the screen resolution to 1024by768 then apply it thats it.
Nov 02, 2008 | HP w1907 LCD Monitor
Cannot display this video mode optimum resulotion 1280*1024 60hz
Chances are that the video driver for XP and 2003 differs (even if only slightly). You might want to start the 2003 in "Safe Mode" first to lower both the Screen Resolution and Screen Refresh Rate to the lowest possible. Thereafter do an update on the video card driver compatible with 2003 from the Dell.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 30, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Screen resulotion
Make sure that you run the motherboard cd. It will have the video drivers to upgrade your video resolution
Dec 26, 2007 | Mercury P4VM800M7 Motherboard
Out of frequency
Are you referring to a problem with a Compaq (242697-001) 8-port KVM Switch or on your display (projector?)?
If it is a display problem, start your PC in Safe Mode and go to your Display Properties. In the Settings tab, lower down your screen resolution and color quality. In the Advanced button, Monitor tab, lower down your Screen refresh rates.
Reboot. Do the same and increase settings slowly (by increments) till you get the "out of frequency" message again. Pressing escape would revert you back to the last setting that worked fine.
Hope this be of some help to you, otherwise pls post back with a more detailed description.
Nov 01, 2007 | Compaq (242697-001) 8-port KVM Switch
AOC 19LVWK LCD Monitor Logo
124 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
