Question about Samsung PN42A450 Plasma TV
Pn50a450p turns off and on 1 to 10 times per day
Pn50a450p turns off then imediatly back on, 0 to 10 times per day, no corolation with viewing time or heat.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa.It seems to be an issue with the X, Y-main board however; control board should also be checked. As the sound is working fine so it means that power supply unit is functioning properly. Check for any bad/bulged capacitors on these boards. These boards are located on the right side of the unit and to check them you’ll have to open the back of the unit and then blow the dust off with a blow dryer. Once you have opened the back also check for any blown/bulged capacitors.All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 08, 2010
  • 8 more comments
  • jimhjimh Jul 08, 2010
    Hi Rylee,
    Thanks for helping. I don't see any bulged caps,
    Jim
  • Rylee Smith
    Rylee Smith Jul 08, 2010
    Jim,
    Thanks for your reply. If you are unable to see any bulge caps. then try to clean the boards inside and then plug the unit back in to check if everything is working fine.
    I will try that but it may be a day or two before it shuts off again, if it's not fixed. The boards are almost dust free
    Thank you, Jim
  • Rylee Smith
    Then there should be a capacitor thats going bad or some other component on the power supply board. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Hi Rylee,
    I checked All the caps again and they all look fine. I don't mind replacing a whole board if I could determine wich one.
    Jim
  • Rylee Smith
    You can plug it in different outlet so that we can know what has gone bad.
    Rylee,
    are you suggeting the outlet is the cause?
    Jim
  • Rylee Smith
    It might be and I am suggesting to check it
    Rylee,
    OK I'll put it back together and let you know when something hapens or doesn't hapen.
    Jim
  • Rylee Smith
    OK Jim, please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
Honda VFR 400 timing marks
Hi, Johannes for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Honda VFR 400 timing marks Google Search
400GreyBike View topic NC30 camshaft timing check
1989 1992 Honda VFR400R NC30 Service Manual Moto Data Project
https://www.partsfish.com/page/oem-parts-for-honda
Honda VFR Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 13, 2018 | Honda Motorcycles
13 days is how many hours,minutes en seconds?
There are 24 hours in a day, 60 minutes in an hour, 60 seconds in a minute, so there are:
24 hours per day
24* 60 = 1,440 minutes per day
1440 * 60 = 86,400 seconds per day
13 days = 312 hours 0 minutes 0 seconds
or
13 days = 18,720 minutes 0 seconds
or
13 days = 1,123,200 seconds
Jul 18, 2014 | Watches
Setting the time
Press PROGRAM 0 and dial Year Month Day (w) Hour Minutes (a) STORE where the time is in 12 hour format, the w is day of the week, with Sunday being 0 and a is 0 for AM or 1 for PM
Nov 11, 2009 | Lands Phones
After downloading songs on my Sansa View, some of the tracks are bad. I've tried to delete the bad tracks but Sansa View won't let me. Also, when a bad track appears the Sansa View freezes. Sometimes it...
have you consulted customer service on this? It sounds to me like it might be a drm issue, where drm is a form of licensing that stop you playing files without the license.If it is that kind of problem Sansa should recognise it straight away and then you'll know what to do. in the meantime you could try doing a reset as per the instructions that came with the player or go to the website and download the manual.
Sep 10, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
1988 cutlas ciera starts but stalls imediatly has 34 lbs fuel pre
If you have a V-6, your fuel pressure should be 40 to 45 lbs. If you have'nt done it already, replace the fuel filter and try again. Make sure the pressure does not leak down to near 0 lbs, the pump should hold near the pressure it produces.
Good luck, let me know.
Regards,
May 12, 2009 | 1987 Oldsmobile Ciera
My Phone Fell down in the Water what do i do ?
Turn off the phone imediatly if its still on. open up the phone by taking off the covers and unscrewing them. bring a hair dryer and dry the board then when its completely dry, use a toothbrush to brush any resedue off of the board. then spray it with any type of alcohol product and brush it again with the toothbrush. cover the phone and turn it on.
Jan 03, 2009 | Nokia 6600
Ignition Timing
How to check and adjust the timing
Disconnect the tan/black wire EST (electronic spark timing) by-pass connector located near the heater housing in the engine compartment on the S/T series, or near the distributor on all other V-6 models. Do not disconnect the four- (4) wire connector at distributor. Connect the timing light to the No. 1 spark plug wire. Check timing and adjust to "0" degrees BTDC. With the engine off, reconnect the EST by-pass connector and clear the ECM trouble codes by disconnecting the battery.
Aug 19, 2008 | 1991 Chevrolet Corvette
Samsung PN42A450 Plasma TV Logo
60 people viewed this question
Jerry Greenberg
Jerry Greenberg
