Question about GE 106585 Upright Vacuum
Why would my vacumme spit out stuff instead of **** in stuff?
I changed the bag, and belt myself and now it just spits everything out
  • 1,498 Answers
Hi camille,
Sounds like your belt needs to be installed as a figure '8' to reverse the direction.
Mike
Posted on Jul 08, 2010
It is picks stuff up from my carpet put then it spits it back on the carpet after a few more passes; bag is not full so that is not the problem
The belt that turns the brush bar is probably stretched and worn. Once this happens, you will lose suction. When they get worn they stretch, thus causing it to spin on the bar itself. Just simply replace the belt with a new one that fits your machine.
Good Luck!
Jim
Jul 31, 2011 | Vacuums
No suction and spit stuff out
This often happens when the hose is clogged leading from the bottom to the bag part. If the bag is full, that can be it as well. Good luck.
Mar 25, 2010 | Bissell Vacuum - Momentum Cyclonic 1 ea...
Vacuum cleaner not picking up and sometimes spits ouit dirt
Check to see if bag (or if not bag then chamber is full).
Check to see if filter is clean.
If your vacuum has a bag, check to see that it is properly mounted.
Sorry I couldn't be more specific but it would help if you would specify what type of vacuum you have, whether you are using the hose or just the floor part, and where it is spitting the dirt from.
Hope this helps. If not, let me know the answer to the above questions and we'll go from there. Good luck!
Mar 13, 2010 | Vacuums
My son used it to vacuum up needles from Xmas tree. It is now spitting out dust and not picking up. I changed the bag but does not help
I could not find the manual for the vacuum. I went to the Oreck site and found an online manual for my machine. I was able to take the hose apart and clean out the blockage. Also when I turned the base upside down and rotated the roller, I was able to clean that out too.
Jan 09, 2010 | Oreck XL2000 Bagged Upright Vacuum
Vacuum doesn't work on bare floors!
does it have a bare floor setting that shuts off the beater bar? if the brush is revolving it will scatter dirt instead of picking it up
Aug 23, 2009 | Dirt Devil Reaction Twin Cyclone Upright...
Hoover powermax s3530 spitting out dust
recently had same issue with friends. remove the filter and see the other thin filter there that goes to your motor compartment.. remove that and clean it. also check inside your tubes make sure not partially clogged.
Apr 17, 2009 | Hoover Powermax S3530 Bagged Canister...
Vacum will not pick up
Due to the way carpets are made - new carpets sometimes have a lot of loose fiber. This is NORMAL and it may take 3-5 times to vacuum the carpet till it goes back to normal. Spitting out fuzz balls is a bit weird. Make sure you have the belt installed right - see video on www.goodvac.com. but the fact that belts keep breaking I am assuming that you have them installed right. Give it a few more belts and if the problem presists - let me know.
Rocky
Dec 26, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Bissell powerforce
I just got done fixing a unit with this problem. After a bit of time, dirt will build up in the lower unit and clog the vacumm tube. Symptoms: No air flow coming out of the vacuum. Motor is hot. Stuff is spitting out of the front Motor wouldnt start it had over heated. You should remover the roller and clear the clog by hand. Let the motor cool down and it should start once it had cooled down.
Mar 07, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
GE 106585 Upright Vacuum Logo
85 people viewed this question
Top GE Vacuums Experts
Gerry Harvey
Gerry Harvey
T bone 1963
Are you a GE Vacuum Expert? Answer questions, earn points and help others
