Question about Dometic RM2652 Refrigerator
I just replaced the converter in my motorhome and everything works but the fridge won't work on house electricity, only gas ???
  • 905 Answers
The old converter may have blown out the control board for your 'fridge. This is quite common if the voltage exceeds 15.5 volts, and when there is a ripple voltage (AC voltage component) riding on top of the DC voltage.
Gas / LP mode is the default for this fridge, a fail safe mode.
You can find the service manual for your fridge here.
Posted on Jul 08, 2010
Fridge worked fine last camping season, this year light comes on in the fridge in AC mode, but won't get cold. It is a 3 way fridge in our motorhome, and we have always used it in electric mode only. I...
Also keep in mind that these units are very sensitive to being leveled; even a minor tilt will cause them to quit cooling. These units are not equipped with compressors as are home refrigerators which are not quite as fussy as the evaporative type.
Aug 04, 2011 | Thetford Norcold RV Cooler/Freezer
Our electrolux fridge in our motorhome sometimes works and sometimes doesn;t on either electric or gas but works when the engine is running would changing the mains board cure the problem we have had...
Not sure exactly what type of fridge your talking about here, as heading says dometic, your comments say electrolux, but I will say this. If it works good with engine running then I'd be looking at my charging circuits and auxiliary batteries circuit. Look for a battery isolator in the circuit as well.
Jul 31, 2011 | Dometic RM2452 Refrigerator
I have a 1984 class c motorhome on a ford e350 frame. I have no fuel at the carb. I pulled the output line on the electric fuel pump in the rear of the vehicle. ran the pump; no gas. I pulled the input...
I know this might sound odd but try replacing the ignition switch. I have a 86 c class e 350 and could not get the front fuel pump to run for the longest time. After changing everything else, I decided to change the ignition switch, and believe it or not the front pump came on and started working the way it is supposed to.
Jul 07, 2011 | 1983 Ford Econoline
Our motorhome battery that runs the house section drains within 2 hrs of use. it seems to drain the main battery which runs the motor as well. what can we do so this will last longer? we would liekt o run...
Your motorhome should have a converter in it. It takes 120 volts from the shore power hookup and converts it to 12 volts to run your heater and coach lights as well as recharging the house battery. You should make sure it is working properly. You should also have the house battery tested to make sure it's good. The engine battery should not connected to the house battery when the key is off. If it is there is a wiring or relay problem.
Apr 16, 2011 | Ford Econoline Cars & Trucks
I have a dometic rm 4605 aes fridge in my motorhome priblem is wont work on gas can not hear auto ignition spark when turned to gas works ok on 12v & 240v
G'day I have a Dometic RM4605,184LT FRIDGE, AES what setting on gas would you have the fridge set. Settings are between 1 to 5 for max cold in the fridge I did run the fridge for two hours on number 4 setting but it was still 10 degrees in the fridge and -0 in the freezer.
Thanks
Jan 23, 2011 | Dometic Refrigerators
I know this is a vague question. (trying to help out hubby) I am currently at work, however, our norcold elect/gas fridge/freezer in our mallard camper stopped working properly. the lp gas light is lit,...
Don't be despirate.
You need a little more knowledge ... I'm here to give it.
Your RV refrigerator requires 12 volts to operate; on gas or on electric ... it needs 12 volts - period.
Now then, your frig will get 12 volts from your 'power converter' AND/OR your battery. You do have a battery in your unit, correct? If not - why not? Get one. (Your power converter cannot provide all the 12 volts you potentially require in all circumstances. It is there to charge the battery, which CAN supply all the 12 volts you require. The converter can probably put out 15 amps - your battery can put out 100 amps or more (@ 12 volts DC). Relying only on the converter for your 12 volts will cause over heating and will eventually destroy the converter. Batteries are about $100.00 - converters are about $300.00.
As you know, your frig will run on gas if you are plugged in or on generator ... that allows your frig to get the 12 volts required to run the controls.
What about electric operation? If you are plugged in or on generator, you can run on electric because your Norcold has 12 volts from the converter and/or battery.
Whats going on? Your absorbtion type refrigerator requires a heat source to boil the ammonia mixture to create "heat removing" (you can't really cool anything ... only remove the heat from it!) You can heat the ammonia with a flame or with a electric CALROD. However, the control panel that drives the whole operation runs of 12 volts.
You have a battery and generator and are plugged in and it still doesn't work? You will find a fuse on the control panel in the compartment accessible from the outside of your unit. Check/replace the faulty fuse and you will be back in business.
I hope this helps you and hubby with your Norcold Frig. Thanks for your interest in FixYa.com. If you found this solution to be helpful, please vote. Thanks
Aug 02, 2010 | Refrigerators
Motorhome fridge works on gas but not electric
I thik that whoever advised you of an underlying problem is very muich correct. It sounds like you are getting quite a bad short somewere in your system. I would strongly advise not turning things on as you may fry your entire electrical system. I would also get it checked by a qualified electrician. I hope this is helpful.
Nov 04, 2009 | Refrigerators
I have a Dometic fridg in my 2005 motorhome and when I start my f
You need to unpush the gas button on the front control. If the gas button is pushed in, then it is trying to run on gas and with the tank empty, it is unable to light. That is why the check light is coming on. If you turn the gas side off and have it on auto, it should switch to the AC side and work fine.
Hope this helps,
Jeff
Jul 05, 2009 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
172 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
