Question about Panasonic Lumix DMC-FX7 Digital Camera
Older camera - do not know how to turn it on?
Is this the same camera as DMC-57 -
or is this camera obsolete - I have charged it
the only thing I get - it says- no valid image to play.
    Novelist:
  • 178 Answers
If this is an old camera, that means it probably has an old battery. you can try a new battery that is the one recommended by the manufacturer. dont buy a similar type for these cameras are very specific in these requirements. if that still doesn't work , contact www.teleplancamerarepair.com for a repair. if the camera is older than 7 years it is safe to say you should get a new one.
Posted on Jul 08, 2010
Battery doesn't indicate charging on the DMC-SZ10
It could be one of the USB connectors in the camera is not connected anymore. You need 2 contacts to send over the pictures (data) and 2 contacts to charge the battery. I would not worry about that. Just charge the battery in the external charger. I't won't be worth the cost you have to make to repair this. It is not likely your USB cable is defect, because the same contacts are used for power in the charger. Still you could try another USB cable, because the one you use now, could just work in the charger and just not in the camera.
Jan 03, 2014 | Panasonic Lumix Dmc-zs10 Zs10 Digital...
Long time i didnt use my cam before its working but now i checked it now bt no power even i tried to recharge my battery bcos that 1 still new.let me know if y have suggestion ubout it.thANKS
You can try a new battery or make sure the older one is getting charged by the camera. Remember the camera needs to be in the "OFF" position when you try to charge it.
Oct 06, 2013 | Panasonic Lumix DMC-FH1 / DMC-FS10 Digital...
Just finished charging the battery of my Panasonic DMC-LX2. Attempted to turn on my camera but it doesn't work. The battery is completely charged and this has never happened before.
Hello....I have the same issue with my Panasonic Lumix DMC-FS5 camera we bought 3 years ago. All of a sudden the camera doesn't work. I have had many cameras and I have never seen this before. I will think twice about buying a panasonic again.
Dec 12, 2010 | Panasonic Lumix DMC-LX2 Digital Camera
When i turn my camara it tell me.... please turn camara off and then on again.. so i do it and it tell me the same thing i dont know what to do or were to take it
It seems your camera's Battery is not holding a charge, you need to replace it with another one.
Also this issue usually comes due to the lens getting stuck and is unable to come out, so please try charging your battery and check for any dust/foreign material stuck in the lens preventing it to come out properly.
If the problem still persists, take your camera to an authorised service centre.
Good luck
Mar 16, 2010 | Panasonic Lumix DMC-FZ30 Digital Camera
Lumix dmc-fs5 digital camera not turning on without charger.
Some Panasonic cameras only work with Panasonic batteries...part of Panasonic's plan to dominate the world! Is your replacement battery an off-brand?
Feb 19, 2010 | Panasonic Lumix DMC-FS5 Digital Camera
I have a Panasonic DMC-FZ30PP digital camera. I used it today and it worked fine. I turned it off and turned it on 1 hour later and it was dead. There is nothing in the way of a screen or even a beep. ...
Cry. Check with Panny to see if there is any sort of reset that you can perform to the camera to restore operation. If nothing , then your camera has died prematurely. Not a good thing but it happens.
Sep 09, 2017 | Panasonic Lumix DMC-FZ30 Digital Camera
Panasonic DMC-FX07 Digital Camera won't turn on.
Check your batteries, but otherwise it could be a power board. It could cost between $90 - $125 to replace the board
Dec 31, 2008 | Panasonic DMC-FX07 Digital Camera
Not uploading pictures
I think I know what the problem is, first off the computer must be able to communicate with the
camera/device irregardless of the drivers. The camera is plug and play and so is the computer
unless you are using an older version of windows like 98 or 98 second edition. If you are 98 etc load
the old drivers. But if you are 2000, millineum, or xp then the drivers are automatic for the usb ports.
The panasonic dmc-fz7 is kind of a freak in that it is not a true plug and play device. Sometimes
you have to declare the new hardware. It may have once worked but for what ever reason the hardware may not jive with what the pc thinks it sees if anything at all.
Solution: Go into the Control panel , add hardware wizard, with the camera hooked up to the usb
port and the camera turned on. In the device manager you should get the appropriate message, "new hardware detected" actually it should say dmc-fz7 etc. From there it should be apparent that things are working normally....Good luck. Probably a power glitch or who knows. Mostly its a problem with panasonic plug and play software which they corrected a year or so later with the newer cameras...
Dec 22, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Panasonic Lumix DMC-tz1
lens mechanism needs cleaning ( moisture ) and possible alignment ( jarred ) ; charge or replace batteries , before getting estimate ;
Jul 31, 2007 | Panasonic Lumix DMC-LC33 Digital Camera
Panasonic Lumix DMC-FX7 Digital Camera Logo
26 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
