Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
KitchenAid Mixer is not rotating.
The KitchenAid beater shaft is not rotating. It seems like it is stuck. However the motor seems to be functioning.
  • 235 Answers
Hi MANILYNTHEOB. I’m sorry to hear about your mixer not working. Unfortunately from the symptoms you describe, your mixer has experienced a transmission failure. You don’t mention how old your KA mixer is or how hard it’s been used, but for your particular model, KA has a plastic gear designed to fail, instead of the whole mixer ‘going up in smoke’. And what it sounds like is that this fail-safe gear finally ‘failed’ (stripped) so that the power from your electric motor is not getting to your planetary (“elliptical rotating part”) and the agitator shaft. What can you do?
The good news is that this can be fixed quite easily (OK, maybe a little effort) by yourself, if you are a DITY type person, feel adventurous, and your mixer is not under warranty you can troubleshoot it yourself. Be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> then enter the visitor type “Consumer” and then enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model.
Turn to pages 4 & 5, titled: Case, Gearing And Planetary Unit for the disassembly and reassembly of your mixer, along with all the parts. Locate Illus. No. 58, Worm Gear Bracket & Gear, including Illus. No. 12, Worm Gear (23 teeth). I suspect this is the weak link in your mixers transmission and causing the problems. After clearing all the grease away, you’lll probably find that is has been stripped.
You can order a replacement gear and install it yourself. While you’ve got your mixer this far apart you can check for any other unseemly wear and tear on the on the gears and other components. Besides a replacement gear, and grease you might consider replacing the gasket, too. You should use a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call). Do not try to reuse any original grease as this should be filled with debris from the stripped gear.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. You should search for ‘food grade grease’. Prices can vary widely between vendors, so do your comparison shopping.
It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer, should you decide to go that route.
If you feel this repair is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping. Good luck, I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Posted on Jul 09, 2010
  • jlydon Apr 07, 2011
    I assumed that the nylon worm gear had failed since the symptoms matched. Ordered new gear, took the mixer apart and discovered that the pin connecting the planetary housing to the drive shaft had sheared. As long as everything was being disassembled I checked the worm gear. It was OK. Since I had a new one anyway and more new grease than you'd need to rebuild 100 mixers I replaced it and all of the grease and am waiting for a new $2.99 pin.
    Moral of the story is check the pin first!
Blade is stuck in shaft of kitchen aid
Get some CRC around the shaft and into the beater hole and wriggle it about until it comes free. Rasp the build up in the beater hole out with a round file and clean up the shaft on the mixer. Remember you are cleaning out the hole not trying to make it bigger than it was. In my experience it is a build up of flour in there bonding itself to the hole in the aluminium beater.
Aug 31, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
How to replace motor in kitchenaid artisan mixer
Sounds like a worm gear problem to me, it's impossible for the motor (armature) to move far enough to not drive the gear. There are driving pins in the system from fuse gear to paddle.
1) in the fuse gear
2) inside gearbox above planetary joining shaft to bevel gear
3) through planetary and shaft
There is also one joining the little gear inside the planetary to the shaft, doubt you'd break that one though.
Jun 30, 2014 | KitchenAid KSM150PS Artisan Series Stand...
One of my blades is stuck and I can't engage the release
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft
Jul 19, 2011 | KitchenAid KSM150PS Artisan Series Stand...
First time using bread dough beater It was hard to put on and am unable to remove
as far as possible.
5. Pull beater from beater shaft.
Jul 17, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Bread dough beater will not come off
as far as possible.
I have a Kitchenaid 550 watt 6 qt. stand mixer model #KB26GIXER. I tried to use it this morning and couldn't get the beater blade to lock in place. Isn't there supposed to be a spring and washer...
There is only one pin on the beater shaft to hold the beater in place.
There is no spring or washer on the shaft.
To Attach Flat Beater,Wire Whip, or Spiral Dough Hook, simply
1. Slip flat beater on beater shaft.
2. Turn beater to right, hooking beater over the pin on shaft.
Jun 25, 2011 | KitchenAid KP2671 Professional 6 Series...
Leaks oir or grease at shaft where beater attaches
eaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
If you still feel as though the mixer is in need of service, you may locate Kitchenaid certified repair centers through the following link: http://caservice.kitchenaid.com/
Jul 15, 2009 | KitchenAid K45SS Classic Stand Mixer
The dough hook is stuck in the beater shaft of kitchenaid mixer
It sounds like it got overloaded when you last mixed dough. It will only come off the way it went on. If it has been bent on, it may need a bit of gentle encouragement.
Jun 15, 2009 | KitchenAid KSM50PR Professional Series...
Kitchen aid mixer
take off the chrome ring around the rotator. remove the screws that were hiding under it. pull off the rotator and replace the "O" ring on the shaft.
Mar 08, 2009 | KitchenAid K45SS Classic Stand Mixer
Can't remove beater from mixer...
I took the advice from: http://forum.kitchenaid.com/forums/topic.asp?TOPIC_ID=6356
I put a wash cloth in a pot of boiling water and used tongs to wrap it around the beater shaft while the mixer was resting on its side. When the wash cloth was not too hot to touch, I put it back in the boiling water and did it again. I was then able to easily remove the beater.
Nov 28, 2008 | KitchenAid KITCHEN AID 5 Quart Artisan...
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
824 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
