Question about Mabis HealthSmart Digital Blood Pressure Wrist Monitor, White
Reading are very high and vary from one minute to next
    Scholar:
  • 192 Answers
Congratulations and welcome to the wonderful world of home care.... Sorry if that sounded snippy.... I am a home nurse and you can take the numbers 400 times per hour and they will never be the same. HOWEVER they should not differ more that 10 points either way, for any of them....
Posted on Sep 06, 2010
Is 99 / 128 a high or low blood pressure reading
That's highish, the diastolic (lower) reading being the most significant. However a single spot reading does not tell the whole story as BP does vary quite a bit throught the day. See your doctor for the next step, as exercise levels, weight, family history, and other factors all go into it.
Aug 14, 2017 | Health & Beauty
Hi my son is 29 and has a blood pressure of 138 over 71 is this normal
138 is a bit high. Get him to a doctor.
Quick Answer
To read a blood pressure chart by age, locate your age range, then view the corresponding normal systolic and diastolic numbers, notes Disabled World. The chart offered by Disabled World features average blood pressure readings for 14 different age ranges. For adults between the ages of 25 and 29, a normal blood pressure reading is 120/80 millimeters of mercury. Average blood pressure increases with age.
Continue Reading
http://www.heartandstroke.ca/heart/risk-and-prevention/condition-risk-factors/high-blood-pressure
Nov 15, 2016 | Health & Beauty
Vizio 32 Inch, turn on completely fine for about 20-30 minutes. Then sound goes out accompanied by high pitch noise and picture has varying lines or colors through it. Won't power off, have to un
Are you a decent do it yourselfer? It sounds like it is the capacitors. What happens is they get hot and expand (the top of the Capacitor). The top will be dome shaped and it will look like the top is splitting open. You can buy (about $1.50 ea.) the capacitors at your local electronics store (not Radio Shack they usually don't have a high enough amp).
You will need to take the back off and look at all of the capacitors to see which ones are bad. Usually it will be 2 or 3 of the larger ones but there could be more. Next you will need a soldering iron with a fine tip and some wicking material. How could are you at soldering and de-soldering? before I go on.
If you let me know the model # of your set I can be a little more detailed also.
Sep 24, 2012 | Vizio L32 32 in. LCD HDTV
Low side and high side readings
pressure readings vary depending on temperature, humidity, and other factors such as coil condition (inside and outside coils) ducting, other mechanical issues. The is no absolute readings for any one type of system, that said a ball park reading with an outdoor temp of 90deg and an indoor temp of 78deg it would be around 65 to 70 psi low side and 150 to 210 psi high side.
Sep 21, 2011 | Ruud Matching Split Air Conditioner
I take 4 consecutive readings (within a minute) and get 4 widely varying readings. How do I get an accurate reading with this device?
4 consecutive readings in a minute? No wonder you're getting widely varying readings. Your wrist or arm is not having time to recover from the constriction of the cuff. Try doing only two and waiting at least 30 to 40 seconds in between.
The best way to do it, is take one reading in your left arm and the other in your right arm. If they match or are within a few points of each other, the cuff is probably accurate.
Also, on your next visit to your doctor, take your cuff with you. After they take your vital signs at the doctors office, properly apply your cuff and compare your cuff's reading with theirs. If they are within a few points of each other that's fine.
Feb 23, 2011 | Lifesource UA 767 Plus Digital Blood...
What is the reason of high oil pressure?
It may be a faulty reading caused by the oil pressure sending unit its on the vary back of the engine near the distubtor and you need a specily socket to fit over it to remove
Nov 23, 2010 | 2006 GMC Yukon Denali
Blood pressure reading is not consistent and accurate.
blood pressure reading is not really consistent. for example; the reading of client's blood pressure at 8AM it doesn't mean that you have the same reading on the next minute/ hour. because the blood flows is not also consistent.it varies on people..for example; he has a reading of 100/80 it doesn't mean he has 100/80 on the reading..it varies on what the clients doing prior to that reading.but on those client with cardiac problems it should really monitor the Blood pressure closely. for that simple negligence it would the client to enfarction
Aug 11, 2010 | Lumiscope Health & Beauty
Why my battery status says 1hr 30 minutes remaining only to say next minute that i have 5hr remaining, than it says 3 hr, only to say i have 4hr 28 minutes remaining?
90% of the reason is that ,depending on the working condition the backup of battery varies . What I mean is , if you are running a software which need high resources (example nfs games) then back up reduces and on the other hand if you are running a simple program like ms word ,paint etc maximum backup.
Hope you get the answer.
Mar 11, 2010 | Dell Latitude D620 Notebook
I have OMRON HEM-650, but it does not give accurate results. Can you give me suggestion on which one is accurate and easy to take with? the brand, the model...
None of the finger or wrist cuffs are accurate. The slightest movement of your finger or hand will give a false reading. There are a few nice cuffs for your are and they are all pretty good. Relax for a few minutes before you take your pressure and ake it in the same position each time. Hold still and don't take a deep breath while it's testing. It is normal to have 20-40 points difference from one reading to the next. If it looks too high, sit still for 2 or 3 minutes and try again.
Oct 06, 2009 | Omron HEM 650 Wrist Blood Pressure Monitor
Pressure reading for goodman a/c unit ssx16 5 ton unit
lp-860kpa hp-@2400kpa . For inverter a/c it will vary according to ambient temperature and max to those pressures
Jul 23, 2009 | Heating & Cooling
Mabis HealthSmart Digital Blood Pressure Wrist Monitor, White Logo
119 people viewed this question
Top Mabis Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
Dan Webster
Dan Webster
Are you a Mabis Health and Beauty Expert? Answer questions, earn points and help others
