Question about Frigidaire FAA065M7A Air Conditioner
Air Cond. Freezeup problem
After running for an hour or two front will develop ice
    Sergeant:
  • 338 Answers
Sounds like one of two things either you have an airflow problem or low on charge. have you cleaned the filter? Cleaned the outside condeser coil? The evapartor coil? Is the inside fan blowing air out? to clean the outside condenser coil take a stiff hair brush and go up and down on the coil not sideways. Then use a water hose to clean out the dirt and etc. next take the brush and clean the inside oil go up and down not sideways because you will bend the fins on the coil. I would use a squrite bottle to rinse it with. I hope this helps!!!
Posted on Jul 08, 2010
I have a 2006 ls impala with 126k on it. The last couple of days the computer in the dash,right after it's cranked, will say be careful of ice and the ac won't blow cool air. After a mile or so the...
Chances are the outside air temp sensor is defective. If it tells the computer outside air is below 32 degrees, you will get the warning and the air cond will not work because you don't need it.
The sensor is usually in the area in front of the radiator.
Jun 02, 2013 | Cars & Trucks
Where is low port to recharge ac?
Near the firewall you have both air cond pipes coming out. There is a black cap on the larger of the two alum pipes. It is under the air filter housing and should be able to see it without removing the air filter housing. That is the low pressure side.
The high pressure should run along the chassis rail and near the radiator there is another black cap on a smaller alum pipe.
Remember always yes always vacumm the air cond system for at least 3 hours to dry out the air cond system correctly. If you don't if will only work for a short time before playing up again.
Some shops don't do this and wonder why a car keeps coming back for more gas. Good for them bad for customer.
Jun 16, 2011 | 2003 Ford Ranger Regular Cab
I have an LG 110 volt model-LWHD1200FR this is the 2nd summer we have used it and have always kept thermostat set to 60 deg. The last couple weeks the front coils have been caked with ice, what would cause...
Clean both the cond and evap coils if they don't let the air through
that can cause icing
Check for strong air flow front and rear
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 07, 2010 | LG Electronic Window Air Conditioner
Ice maker has slowed down almost to a stop We get about 3 sets of ice a day used to fill up the tray a
ck the freezer tempt / if around 15 deg It's not cold enough and ice producton will be slow .clean the cond coil this will help and make sure the cond fan is working . it may also need the charge adjusted ( loss of refergerant ) . or possible cold control . and look for ice build up in back of freezer .. this would slow the air flow . .. **** hope some of these help . ****
Jan 16, 2010 | Amana ABB1927DE Bottom Freezer...
Keeps freezing up
Two things will cause freezeup.
Lack of airflow.
Low refridgerant.
Lack of air flow could be due to :
dirty filter
Dirty coils
closed vents
Evaporator fan not operatriing properly. (also known as blower in HVAC units)
Dec 12, 2008 | Heating & Cooling
1994 Previa A/C problem
Look to see that the A/C condensate drains are working. You should see water dripping out from the front & the back whilst the A/C is running. If no water; clean the drain tubes. Also, you need to be running the A/C on the RECIRC mode (the little car with an arrow doing a u-turn inside the car); if not, you are air conditioning outside air, and the unit is icing up from too much humidity. Sort of like running your fridge with the door open...
If neither of those items correct your issue, you may need to replace the A/C thermister; but, that is a very rare failure.
Sep 09, 2008 | 1996 Toyota Previa
Central unit freezeup when on
If you are running the unit in the A/C mode with the fan in the automatic position it could be the cause of the freezing of the coil. Try operating it with the fan in the on position and see if the problem goes away. When in the automatic operation the fan shuts off when the cooling unit shuts off and air circulation stops. Hence no defrosting of the cooling cycle in the off cycle. In the evenings when the outside temperature drops after sundown the pressures in the system drop in proportion dropping the temperature of the cooling coil sometimes causing ice formation on the cooling coil.
May 22, 2008 | Weather King 10AJA2501AH Air Conditioner
Kenmore freezer and fridge is not cold - not frost build up - compress anf fans are all running
You need a qualified technician for this problem.
- Your unit may have leaking try to check for oil traces.
- The system maybe restricted, system reprocess is needed for this unit.
- If the unit is no frost try to check if there is an air circulation inside the unit. If no air is present then check your fan motor inside.
Jan 11, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frigidaire FAA065M7A Air Conditioner Logo
75 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
