Question about Amana DLE330RAW Electric Dryer
Amana DLE330RAW Elec Dryer starts then shuts off & wont turn on
Amana DLE330RAW Electric Dryer will not keep running. it will run for like 5 min or so then will shut off. if we go to turn it back on it will hum and not restart. if we give it a half hour or so it will work again. What do you think it could be.
  • Amana Master
  • 43,501 Answers
There can be many reasons why your dryerAmana DLE330RAW Elec Dryer starts then shuts off & - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryerAmana DLE330RAW Elec Dryer starts then shuts off & - 2_bing.gifng
Dryer Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jul 12, 2010
Motor will not run
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 19, 2011 | Amana DLE330RAW Electric Dryer
I replaced the thermal fuse because there was no heat. Now the dryer over heats and shuts off. Everything checks ok on ohm meter. The timer works in the "no heat" mode. Could it be the timer...
after you changed the thermal fuse did you clean out the dryer and the vent line?if not you blew the fuse again and it will keep doing this until you clean out the duct that the lint filter slides into,vac and blow out the motor and the cabinet where the motor is and blow out the vent line,if it's a long run remove the vent line from the back of the dryer and blow it out with a leaf blower.the dryer went over 300 degrees from lint buildup and popped the thermal fuse,it's a safety so the dryer doesn't run hot and start a fire.if the dryer is running and sfter like 20 minutes it shuts down and won't start for a while until it cools down then the motor is bad also probably from the dryer running to hot from the lint build up.
Apr 08, 2011 | Amana DLE330RAW Electric Dryer
Wont come on
At May be No guides are always there to provide technical support to troubleshoot Amana DLE330RAW Electric Dryer Problems which is free of cost. You can also get Amana DLE330RAW Electric Dryer, Dryers Help from archived solutions related to repair, maintenance, upgrades and installation problems.
Dec 16, 2010 | Amana DLE330RAW Electric Dryer
Dryer keeps flashing door open - and won't run
The door switch is bad...
heatman101
Sep 17, 2010 | Amana DLE330RAW Electric Dryer
DRYER WONT TURN ON. IT WAS RUNNING. TIME WAS UP AND CLOTHES NEEDED MORE DRYING. WENT TO TURN IT BACK ON AND ITWOULD NOT START.
1. Check the circuit breaker for your dryer
2. check to make sure the door switch is operating correctly (this is a safety device that prevents the machine from turning on if the door isn't shut or if the switch is defective.
3. Recheck
May 26, 2010 | Amana DLE330RAW Electric Dryer
I have a gas Amana Heavy duty dryer LG5309w it starts and after 5 minutes it shuts off...any suggestions?
If the dryer has a sensor dry function, look inside the drum and locate the moisture detector. It'll probably look like two metals bare. Clean it real good with rubbing alcohol. If that doesn't fix your problem you'll need to work on the dryer.
Oct 16, 2009 | Amana DLE330RAW Electric Dryer
Dryer will run for about 20 minutes then it cuts off.
Are you able to restart the Amana dryer right back up when it shuts down? If you can, there is a short issue. If you have to wait a few minutes and you might even hear a faint click, then it will start, your motor needs replaced.....If Ic an help further, I am here.....
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Amana DLE330RAW Electric Dryer
Will run for about 1 min then stops
might be that the Drum is stuck, can you turn it by hand...it is possible that the drum has just got stuck, or maybe you have a drive belt problem . I hope this helps
Sep 27, 2007 | Amana DLE330RAW Electric Dryer
Amana DLE330RAW Electric Dryer Logo
233 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
