Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Model hc-p4752w has a burnt capacitor location number c449. Do you know the value of this cap
  • Samsung Master
  • 8,457 Answers
Check the value the next capacitor to it.It have the same Micro Feret and volt.
Posted on Jul 16, 2010
Burnt out EY34
EY34 is a location near a small blue capacitor that commonly burns up; Location number for the cap should be C514 and the values of it are 1,000 pf (pico farad) at 2 KV (2,000 volt rated).
Often if it is burnt it is the only problem and both Hitachi and Sony used the same identical part in several of their sets.
Let me know if you have questions.
sd tech
Sep 25, 2011 | Sony KP-53S65 53" Rear Projection...
Tv made a popping noise then turned off model HC-P4752W
Know how to solders?Ur power board is dead,capacitors puff up or burst open,must replaced these capacitors to get power back.Or buy and replaced the whole refurbish power board at Shopjimmy.com,Ebay.com.
Jan 21, 2010 | Samsung HC-P4752W 47" Rear Projection...
STK392-010
There are usually two one contains three amplifiers so there are two for the Red two for the Green and two for the Blue.
Mar 28, 2009 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47" projection TV distortion & yellow?
I think you have a fault on the chroma board and on the picture frame board. If you can trace it yourself try these two locations otherwise call out a competant technician. hope this helps.
Sep 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Convergence issues
Yes the HC-P4252W and the HC-P4752W are both P59A chassis so they both use the two STK392-010 Convergence amp iCs that are located on the sub deflection board
May 12, 2008 | Samsung PCL545R 54" Rear Projection...
Convergence issues
if youre having convergence issues with your samsung HC-P4752W you need to replace both convergence ICs numbers STK392-010 they are available at the following link and they provide free instalation instructions with pics so you can do the repair your self and they also give free tech support in case you need extra help. Its an easy repair takes about an hour from start to finish, Changing the convergence board wont help as the Convergence ICs are located on the sub deflection board and thats about 400 to replace the board compared to 50 to replace the ICs. Heres the link.
http://servicemanuals.vstore.ca/
May 12, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung hc-p4752w
Sounds like convergence amp ic's
i dont have any part number for that model.
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 14, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung hc-p4752w
Not sure of the part number most use STK392-110 or 120s . You will need to look at the ics in your set they will have the IC numbers stamped on them they will have STKxxx-xxx whatever that number is thats the sanyo part number for those ICs
Convergence Problem inSamsung HC-P4752W 47" Rear Projection
One of the convergence output IC's has burned out and needs to be replaced. If the IC opens up inside then it stops working without blowing any fuses or resistors. The IC should be replaced and the set realigned by someone with experience in convergence circuits.
Jun 22, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
95 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
