Question about Kicker KX1200.1 Car Audio Amplifier
My amp cuts off its a kx1200.1
My amp cuts off at a certant volume thats still pretty low i hear a click inside it and it cuts off until i lower it wut could it be all i have hooked up is a pair of pioneer impp nothin it cant handle so i need help from u techies any advise?????????
    Problem Solver:
  • 8 Answers
Check your ohms they may be too low
Posted on Jul 15, 2010
I have my PL-5 hooked up to an amp and speakers. The only way I can hear it is by turning the volume all the way up on the amp. Even doing that the volume is very low. The weird thing is with the amp...
You need to buy a turntable pre-amp, as the signal output is much too low to drive an amplifier. Or buy a DJ mixer, which has a turntable preamp built in, as does any "integrated receiver" which is basically a tuner/phono preamp/amplifier combo in one box.
Nov 17, 2017 | Pioneer Audio Players & Recorders
Volume in left earbud is suddenly very low
just do the volume the equalization. Once the Bluetooth is on just click the volume (+) until you hear a beep then click volume (-) until you hear a beep, this should equalize your volume. and give you equal sound from both of you earbud.
Oct 17, 2013 | LG Tone HBS-730 Bluetooth Headset- Black
My pioneer gm 5300t amp cuts off at loud volume and will not kick back on until it is turned down and cools off, what is wrong with it?
You are over heating it,You have your speakers wired up for a lower,(OHM) Rate then the amp can handle, That why it cut out when you have it turn up
Nov 10, 2012 | Pioneer GM-5300T Car Audio Amplifier
I have a 2001 chrysler voyager installed a kenwood stereo and when i raise the volume to where its lound the radio will turn off and on untill i lower the vol
My electronics savvy source says you may be overdriving the amplifier in your Kenwood stereo to an impedance-mismatched set of speakers, meaning that the speakers are impedance mis-matched to the Kenwood stereo, and therefore operate ok (but inefficiently) at low volume, but cut off completely at higher volume.
Fix: match the impedance of your speaker network to the specs on your Kenwood car stereo. Once this is done, you should be able to crank up the volume to the point of permanent hearing loss.
SAFETY CAUTION - sound levels above 85 decibels produce NIHL (noise-induced hearing loss).
http://www.dangerousdecibels.org/education/information-center/faq/
Oct 18, 2011 | Kenwood Car Audio & Video
Sleuthing a 300/4 low-ohm issue. 300/4 amp history: unknown. just connected today whole system yesterday/today: head unit, 300/4(to 4 polk 6.5" component speakers brand new) 1000/1 (4-W3's),...
Are you sure you getting enough power to push everything. I have seen when the voltage is too low coming in, the amps will shut down so they don't overheat. Once they've cooled off and the volume level is lowered they will kick in again. Low voltage and a heavy draw will create massive amounts of heat.
May 24, 2011 | Jl Audio 500/1 Car Audio Amplifier
Amplifier works at low volume levels. When volume is turned up it cuts out for a few seconds then there is a click and it comes back on and then cuts out again until the volume is returned to a low...
Try looking at the rear of the amplifier to see what the speaker load should be...it will be measured in Ohms...you will then want to look at the speakers to see what the impedance is on the speakers...if it is LOWER than what is on the back of the amplifier, then you have an impedance mismatch which is causing the amp to go into protect... If the speakers are in fact the proper impedance then you probably have a bad speaker...you can test this out by disconnecting one speaker and trying it,,,and then the other and so on...another thing to try would be to obtain another pair of speakers with the proper impedance to see if they work...now if you try all this and the amp still cuts out..them there probably is a problem inside the amp...I specialize in Vintage Audio so try these things first...if you have questions feel free to email at jcameo7270@yahoo.com
Dec 30, 2010 | Marantz PM7200 2-Channel Amplifier
When i turn my volume up to a certain point the power light on my amp will blink off and on and the subs will cut off...what could be some possible solutions? is the amp not suppose to be tuned up? it...
Sounds like you are showing too low of an impedance load to the amp. The E1200 is only stable as low as 2 ohms. If your subs are wired to show lower than a 2 ohm load then the amp will go into protection mode as the volume or gains are turned up
Dec 23, 2010 | Jl Audio E1200 Car Audio Amplifier
I hooked up 1 10" type r to my 600w sony xplode
How many ohms is the speaker? You have the amp bridged going into the sub? You have the negative of one side hooked up to the negative and the positive on the other side hooked up to the positive?
It says that it is bridgable at 4 ohms. What about the input? Set your stereo about half way up. Then turn your amps gain up slowly until it is where you want to listen to it normally. Not to loud. Then when you turn it up it isn't too much.
But it sounds like you have way too much power for one speaker. Especially a ten. It takes two tens to equal one 12.
Dec 17, 2010 | Sony Car Audio & Video
My new Acer Aspire one D 250 laptop has a very low volume output . All the volume controls are up including wave output but with no success
Right click on the speaker icon in the task bar, lower right hand corner of the screen.
Select "Adjust Audio Properties."
In the popup box, go down to "Speaker Volume." Click "Advanced"
In the new pop-up, make sure that "Laptop speakers" is selected. Click all the OKs you need to in order to establish that setting and clear out of "Adjust audio properties."
Now you SHOULD have much better sound from your speakers.
For some reason, my D250 keeps defaulting to "Stereo headset" which produces much lower volume sounds when a headset is not inserted. So low that you can't watch and hear a video through the speakers and understand what is being said. Once you switch to "laptop speakers" you'll be able to hear stuff. It won't be high volume, these things just don't put out high volume, but it will be reasonably audible, if this was the problem.
Nov 25, 2009 | Acer Computers & Internet
1000 w sony xplode works at low volume then red lights at volume5
Most likely one of your subs are blown, or the Ohm's are too low for the ampliphier. Try hooking up one speaker at a time to the amp and see if it does the same thing. If it shuts off on one of the two speakers, that speaker is most likely blown.
Apr 19, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Kicker KX1200.1 Car Audio Amplifier Logo
98 people viewed this question
Top Kicker Car Audio & Video Experts
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
